Caryle Racing
Old 03-10-2012, 03:48 PM   #1
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Line Lock on M6
Anyone using a line lock on M6 SS? Which brand, how do you like it, and what features does it have? ie - Power up and enablement switches. Do you have pics of where you put switches?
calbert1999 is offline   Reply With Quote
Old 03-10-2012, 03:50 PM   #2
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Yes. SJM linelock. Great product. Main power is below steering wheel, the rest is in the cruise control.
Old 03-10-2012, 03:53 PM   #3
calbert1999
Camaro SS Lover
Wow. That's a good way of doing it instead of having a secondary switch.
Any specific reason why you chose SJM and not another brand?
Old 03-10-2012, 04:01 PM   #4
1badtie
1badtie's Avatar
Drives: 2010 Camaro 2SS RS
whats a linelock do
2010 2SS RS --- SOLD
MODS-
Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb
Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs
1badtie is offline   Reply With Quote
Old 03-10-2012, 04:03 PM   #5
UF4LIFE102SS
Drives: 2010 2 SS
Mike does all the leg work when it comes to everything he buys so i went with what u used.
Old 03-10-2012, 04:04 PM   #6
UF4LIFE102SS
Drives: 2010 2 SS
Originally Posted by 1badtie View Post
whats a linelock do
The right way to warm up tires at the drag strip.
Old 03-10-2012, 04:09 PM   #7
calbert1999
Camaro SS Lover
Nice, way to do it. Why have a bunch of holes drilled everywhere if you can use existing switches.
whats a linelock do
Read how it works:
http://www.sjmmanufacturing.com/cam_brk_2010.html
YouTube Video:
I wouldn't do it any other way.
Old 03-10-2012, 04:16 PM   #8
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Ill be installing my SJM kit here soon... any wiring diagrams while using the cruise switch??
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 03-10-2012, 04:19 PM   #9
calbert1999
Camaro SS Lover
SJM has two styles. Any difference between the SJM or Hurst style solenoid? Or just the bracket hardware? Which bracket did you guys go with?
Old 03-10-2012, 04:28 PM   #10
UF4LIFE102SS
Drives: 2010 2 SS
Not the Hurst.
Old 03-10-2012, 04:30 PM   #11
calbert1999
Camaro SS Lover
Not the Hurst.
Any specific reason or just preference? I was aware of the Hurst, and no other brands, that's why I asked the question.
BTW - Thanks, for feedback appreciate it.
Old 03-10-2012, 04:36 PM   #12
UF4LIFE102SS
Drives: 2010 2 SS
No problem. Like before Mike is the answer man. Pm mikepage0007 if u want to know what he thinks. Love to answer ?
Old 03-10-2012, 04:37 PM   #13
UF4LIFE102SS
Drives: 2010 2 SS
Did u get the pm?
Old 03-10-2012, 05:07 PM   #14
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
sjm is steve, he sells his brand and also the hurst...i see no reason to pay more $$$ for the brand name as he stands behind his stuff and you can speak with him in person...also as others have stated..extreme performance has installed ours into the cruise control...turn cruise on-hit brake pedal and hold down real hard -push in cruise control button on left side steering wheel and hold in while releasing brake pedal- your front brakes are now applied....give gas release clutch spin tires, release cruise control to release front brakes...using the line lock will usually throw a code for the traction control , but will reset on its own...rear tires spinning and front are locked up confuses the computer, just like a dyno does...don,t sweat it..also remember that more pressure pushed on brake pedal relates to how much pressure is holding front wheels ...if you only push moderately hard , your car will try to roll as giving gas...any questions , you can pm tyer@extreme performance, he is a vendor here,, we changed a diode or something here as 1 was discontinued or something...but easily done...forgot to mention , but i heard steve{sjm} actually does the engineering for bogarts and is responsible for the machining that is required for the 17inch bogarts to fit our camaro,s...i also picked up all the parts for UF4LIFE102SS and 2 other camaro,s from radio shack for the cruise control personally for under 10.00
mikepage0007 is offline   Reply With Quote
Line Lock... whos got it ? MustangKiller Suspension / Brakes / Chassis 15 01-27-2012 11:35 AM
Line Lock Loc Launch Control Kit? SLO RYDE Suspension / Brakes / Chassis 28 11-30-2011 12:17 AM
tci line lock jam3 Dragstrip and Launch Techniques Discussion 22 08-23-2011 01:22 AM
Line Lock Beescuz Dragstrip and Launch Techniques Discussion 0 03-18-2011 04:08 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 12:58 PM
