Old 03-10-2012, 05:08 PM   #15
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
here is 1 of the orig threads back when we were searching..http://www.camaro5.com/forums/showthread.php?t=116940
mikepage0007 is offline   Reply With Quote
Old 03-10-2012, 05:18 PM   #16
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Hey Mike, thanks for accepting my request to pipe up here. Very much appreciated and a fabulous explanation of how it works, and sharing schematics for using the cruise as the switch.
calbert1999 is offline   Reply With Quote
Old 03-10-2012, 08:14 PM   #17
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Originally Posted by UF4LIFE102SS View Post
Yes. SJM linelock. Great product. Main power is below steering wheel, the rest is in the cruise control.
Did u get the pm?
Got it... thank you!!!
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 03-10-2012, 08:29 PM   #18
Coop
Drives: 2010 Camaro 1SS
I went to the SJM website and like the price. Think I will order.
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 03-10-2012, 09:16 PM   #19
Cheesehead1
Cheesehead1's Avatar
Drives: 2011 2SS/RS RJT
Do you have to open any brake lines to put one in?
CAI Inductions Cai, GHL Catback, MGW shifter, Phadt Trailing arms, 20% tint, Skip shift elim, Heritage grill, Black tail light bezels. best time 12.85 @ 110 2.04 60'
Cheesehead1 is offline   Reply With Quote
Old 03-10-2012, 09:26 PM   #20
mikepage0007
Drives: 2010 camaro
the line lock solenoid attaches to the brake system on the passenger fender, you will need to bleed the system after instaling...the brake lines for the front wheels are sent thru the solenoid before entering the brake block...so there is removing lines and installing new lines...
Old 03-10-2012, 09:27 PM   #21
Cheesehead1
Thx.
Old 03-11-2012, 09:30 AM   #22
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Cool
Fishdadddy is offline   Reply With Quote
Old 03-12-2012, 10:19 PM   #23
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I'm rocking the SJM. Quality is top notch and I have installed many line locks. This is by far the best. I did have to make a couple tiny mods for it to fit with the convertible strut tower brace, though. http://www.camaro5.com/forums/showthread.php?t=167705
SUX2BU is offline   Reply With Quote
Old 03-12-2012, 10:22 PM   #24
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
SJM here too. Works flawlessly.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 03-12-2012, 10:54 PM   #25
calbert1999
Camaro SS Lover
Discussed with shop today, getting mine ordered as we speak. I like the setup it's very clean, and I really like the master switch with LED. Without the added safety of a primary / secondary switch, all I think about is hitting the line lock button by mistake while you're doing 100mph. on the highway.
Old 03-12-2012, 11:04 PM   #26
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I put the SJM a couple weeks ago and install was easy enough. Hardest part was deciding hot to do the wiring/switches. Was going to go with the cruise control setup mentioned above but went a little different instead. I Used the supplied SJM master switch which I installed under the steering at the bottom of the dash. I then installed a Plasmaglo momentary switch in the cigarette lighter socket for a real covert but functional look. When the master is armed, the Plasmaglo lights up to let you know. Install turned out really clean and I am really satisfied with the SJM quality and performance!
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 03-12-2012, 11:13 PM   #27
calbert1999
Camaro SS Lover
I've decided to get a black switch (about the size of a nickel) with a built in LED, and the shifter switch as the momentary. That way I don't have to drill any holes into the interior of the vehicle.
Old 03-12-2012, 11:59 PM   #28
mikepage0007
Drives: 2010 camaro
glad it,s all working out...steve is a good vendor here, has helped me with diffewrent things from bogarts to line locks...had 1 problem with a sticking solenoid and he recalled it asap..
Line Lock... whos got it ? MustangKiller Suspension / Brakes / Chassis 15 01-27-2012 11:35 AM
Line Lock Loc Launch Control Kit? SLO RYDE Suspension / Brakes / Chassis 28 11-30-2011 12:17 AM
tci line lock jam3 Dragstrip and Launch Techniques Discussion 22 08-23-2011 01:22 AM
Line Lock Beescuz Dragstrip and Launch Techniques Discussion 0 03-18-2011 04:08 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 12:58 PM
