Cold Air Inductions
Old 03-22-2012, 08:53 AM   #15
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Originally Posted by USArmy View Post
Forum friends,
Just a little of my experience with Monster clutches so that you DO NOT MAKE THE SAME MISTAKE!!!!
Although I was not experiencing any kind of issues with my car, I recently replaced my factory clutch because I wanted to maximize HP to the ground. I looked around and called Monster Clutches. They assured me that the Level 3 was my best choice for my HP and that my daily driven car would still keep the good manners when driven around in the city while perfoming like a beast at the track. I gave the clutch the proper "break-in" in accordance with Monster's break in instructions during the first 500 miles (not highway, but city stop and go miles). My car currently has 1100 miles on the Monster clutch and I could not be MORE disappointed...the clutch makes a horrible and embarrasing noise EVERY time that you take off sounding as if your throwout bearing was in need of replacement. The billet flywheel that came with the package appears NOT to have been balanced. This clutch combo creates a vibration at speeds over 65 that resemble a car with a bent driveshaft... I am just giving you a word of advice...DO NOT BUY MONSTER CLUTCHES!!!! After wasting the money, I am ready to throw this piece of junk away and install an ACT or McLeod combo. Any other GOOD suggestions?
Sorry your having issues,give the guys at monster a chance to make it right,im sure they will.I would like to thank you for your service and allowing me to enjoy the freedom i have,thank you.If you decide you want to go a different way please give me a call,you will not find a better clutch than the StreetSlayer and it may be a little more up front but it will save you money.If you decide you would like a StreetSlayer i will pay for your install and thank you again for your service
Hendrix-Engineering is offline   Reply With Quote
Old 03-22-2012, 10:33 AM   #16
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
Newmoon, I have the 500 mile break in all finished and have had the car to the track once. The Monster Level 3 clutch is performing flawlessly, I'm not throwing real high HP at it but it feels as though it will take plenty more with no effort at all. Also for the break in they recommend more of a stop and go style driving if possible for the first 500 miles to get a heat cycle built up in the unit and then cool down.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 03-22-2012, 11:24 AM   #17
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Bull,
Our Z06 has a McLeod and you are right, it is REALLY smooth. I wanted to cut corners and dumped $796 only to put this piece of junk where it belongs...in the trash can! Six weeks later, I am looking at spending the amount of money that I should have spent in the first place. Does your RXT fit the Camaro like OEM? Is your Camaro a daily driver? Thx!
It bolted up just like stock. You do need their flywheel however, cant use the OEM flywheel. My car is not a daily driver but i do drive it daily. After we put the clutch in my first thought was something was wrong because the pedal feel was so light. I love this clutch.
funny thing is, the guys that run monster clutch are also called SNL Performance. They're in Ft worth and i have taken my car there for a few things and they always do great work. Outstanding work actually!
So the guys that run Monster Clutch Co, install a McLeod RXT in my car! I was promised by them that their new Monster Twin Disc was going to go in my car. Turns out the clutch had some machining issues on the flywheel. I did not want a single disc installed in my car. Rather than installing a sub par product, they installed a competitor's clutch, Mcleod.
They will make it right. And dont drive the Monster Level 3 like a stock clutch. Beat on it and it will be much better
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-26-2012, 11:13 AM   #18
USArmy
Drives: 6.2 Liter Supercharged, LS3
Hendrix-Engineering,
Thanks! Sorry for the late reply as I was out of town. Please PM me with the clutch model needed to support my current RWHP, price, what's needed, etc. so that I can still have fun at the drag strip as well as use it as a daily driver.
6.2 Liter Supercharged, 6-speed manual, Hurst Short Throw Shifter, Airaid Cold Air Intake, 1 7/8 powder coated Kooks Headers, 3" MBRP full catback exhaust (T304 Stainless), BMR Differential Bushings, Spohn Performance Trailling Arms, BMR Fabrication Rear Cradle Bushings (Delrin), G-Force 1400HP Axles, Kenne Bell Boost-a-Pump, Nitto 555R Drag Radials, custom tune
USArmy is offline   Reply With Quote
Old 03-30-2012, 10:39 AM   #19
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Old 03-30-2012, 12:57 PM   #20
camaros and vettes
Drives: 2010 IBM Camaro 2008 Corvette
me too, has a little shutter to it but with it being aftermarket and able to handle more hp i am good with it. just my thoughts though.
camaros and vettes is offline   Reply With Quote
Old 03-30-2012, 03:56 PM   #21
Heliwrench
Heliwrench's Avatar
How many miles have you had it?
...and plenty more
Old 03-30-2012, 04:30 PM   #22
camaros and vettes
less than 200
Old 03-30-2012, 04:48 PM   #23
DandD
DandD's Avatar
I've got about 1000 miles on mine now and I'm going back to the drag strip tomorrow for the second time on the level 3 clutch. I am completely satisfied with the clutch, although I am not running high horsepower (probably 420 rwhp) for my current needs it is great.
Old 04-02-2012, 11:01 AM   #24
newmoon
newmoon's Avatar
Drives: 2013 Boss 302 RR
Update on my clutch to this point. Have maybe 300 miles on it and the 1st gear engagement shutter is still there. I can't say I am really happy about it, but hopefully once fully broken it it will diminish. Still haven't given it a full throttle blast yet.
2013 Boss Mustang - Present Toy
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 04-02-2012, 10:38 PM   #25
camaros and vettes
Guys you need to remember this clutch is made to support 700hp, it will not be as smooth as stock. It is going to have a little shutter to it. I'm not an expert but I think any clutch designed to hold this power will be the same with out spending mega bucks. Just my 2cents. The harder I am with minus the smoother it is. Try higher revs on take off and faster off the clutch pedal.
Old 04-02-2012, 11:43 PM   #26
Heliwrench
Heliwrench's Avatar
Yep I have to rev it a lot and it's happy. If I revved the stocker like that it would have stunk! This one just takes it.
...and plenty more
Old 04-03-2012, 09:38 AM   #27
Hendrix-Engineering
Our clutches dont have to be beat on to be smooth ,you can beat on them whenever you like but they never ask for it
Old 04-03-2012, 10:14 AM   #28
Heliwrench
Heliwrench's Avatar
He said without spending mega bucks
It was a big toss up for me between the monster and yours and it just came down to price at the end. Maybe next time!
...and plenty more
clutches, level 3, mistake, monster, racing
Monster Clutch ztsmith86 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 20 03-07-2012 08:36 PM
Street Slayer Brought to you by Hendrix Engineering Hendrix-Engineering V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 12-08-2011 05:32 PM
Street Slayer brought to you by Hendrix Engineering Hendrix-Engineering Transmission / Driveline 2 12-08-2011 03:55 PM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 10:39 AM
Anyone using a Monster clutch? HRC V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 11-18-2010 08:39 PM
