JDP Motorsports
Old 03-10-2012, 07:00 PM   #1
ewoolsey
Drives: Victory Red 2011 Camaro SS/RS
Smile Buying sway bars and need advice
Hey guys first of all if anyone has a set of front and rear sway bars that they wanna sell pm me with a price and model. Canadian sellers would be awesome. Also I am looking for some advice on what sway bars are the best. I'm looking for a set that are pretty stiff and have adjustability. Any input is appreciated.
ewoolsey is offline   Reply With Quote
Old 03-10-2012, 07:22 PM   #2
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
i dont have them for sale, but i am using the hotchkis sway bars front and rear and i love them! the rear one is adjustable in 3 ways. pretty good price too!
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 03-10-2012, 07:26 PM   #3
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
I have the Eibach Pro-Kit with 1 inch drop springs front/rear and the front/rear sways. The front/rear are 3 way adjustable. I have them set in the middle for street use, however, I tried the tightest setting and holy shit.....cornered and handled very well. For the price you can't go wrong....
FFPM73
FFPM73 is offline   Reply With Quote
Old 03-10-2012, 08:17 PM   #4
ewoolsey
I'm kinda worried about getting the eibach springs cuz not many people have them. I'm worried they won't be stiff enough. I'm looking for something pretty stiff. Plus they're cheapness worries me. Is it a big deal the you can't adjust the front bar on the pdafts?
Old 03-10-2012, 08:36 PM   #5
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Love my Pfadt sway bars and you can adjust the rears. If you are on a budget just get the rear bar.
bajamoon is offline   Reply With Quote
Old 03-11-2012, 04:41 PM   #6
toehead93
Drives: 2014 2SS/1LE
I plan to upgrade to ZL1 sway bars, end links, and LCAs. All of these parts are less than any after market option for sway bars only and i get the added benifit of sporting the new more efficient FE4/5 LCAs on my 2010 SS.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 03-11-2012, 06:21 PM   #7
toehead93
I was going to do both front and rear ZL1 bars but it makes sense to have an adjustable rear bar. Im pretty novice so I can probably get away with the stock ZL1 bars for now.
2010 2SS A6 - sold.
Old 03-11-2012, 06:25 PM   #8
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
Drives: Black Camaro 2SS/RS
I have pedders and they are pretty stiff. I have the complete pedders pace car package.
NYJETSFAN is offline   Reply With Quote
Old 03-11-2012, 06:54 PM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Pedders here. Have the front 27mm and rear 32mm with their endlinks.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-11-2012, 11:53 PM   #10
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
How do you like it?
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, Apex Catch can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 501/535 on a conservative tune. Oh and Forgestar 20's
Nutro is offline   Reply With Quote
Old 03-12-2012, 12:47 AM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
How much are the ZL1 bars? Unless they are dirt cheap, it doesn't make sense to go that route, especially when you know you want an adjustable set. You can grab a good set of bars for around $400 new and much cheaper if you find a member selling them used. Most places offer a package price that saves you quite a bit of $$. I have the Pfadt stage II and it saves you $150 on a set of bars and drop springs.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-12-2012, 03:22 PM   #12
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Davenport Motorsports in Calgary is probably going to be able to give you the best pricing locally on any Camaro parts you could be looking for. They're a little far from you in Edmonton, but Namala and his crew at Davenport are absolutely worth the drive. We never hesitate to send customers in Alberta over his direction... they're also a Camaro5 forum sponsor!
You may want to take a look at our Stage2 Camaro package. It includes front and rear sway bars, including an adjustable rear sway bar to help you dial in the balance of the car... it also includes drop springs to give the car a more aggressive stance and overall improved handling.
One thing to keep in mind about the ZL1 sway bars is that the rear bar is NOT compatible with the 2010 or 2011 rear lower control arms. The ZL1 sway bar package moves the endlinks outboard of the shocks, and the 2010 and 2011 cars do not have provisions to bolt the revised bars onto them. If you're looking to move to ZL1 sway bars you will need to upgrade to 2012+ rear lower control arms as well, and at that point if you're swapping rear lower control arms you probably want to move to an adjustable bar package at the same time.
We are working on a sway bar package specifically for 2012+ rear lower control arms to take advantage of the new revised sway bar geometry. You can find more information here: Pfadt Racing 2012+ sway bars
Old 03-12-2012, 04:01 PM   #13
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
BMR swaybars are one of the most noticeable handling improvements you can do for your 5th Gen Camaro. From the factory, GM did a decent job with spring rates and swaybars but the Camaro begs for more roll resistance to counteract the car's excessive weight. BMR recognizes this need and has a solution that not only increases roll resistance but does so with very minimal decrease in ride quality.
BMR takes advantage of today's technology by manufacturing it's swaybars from tubular steel, a process started in Europe and adopted by most current auto manufacturers today.
All BMR swaybars are cold formed, a chosen manufacturing process that doesn't involve heat, resulting in more consistent "memory" retention. A key feature in BMR's swaybar design is the adjustable rates, allowing multiple settings for varying driving styles. From the factory there is inherent understeer in this platform. Rather than just make larger OE bars with the same problem, BMR's solution is biased front-to-rear roll resistance, resulting in a neutral overall balance. For instance, by simply replacing the rear bar only and using the first hole, you effectively neutralize understeer without changing overall roll resistance. Adding the front bar and choosing a stiffer rear setting increases overall roll resistance.
Countless hours were put into developing and testing the ideal rates for our bars, taking this platform to a whole new level of driving excitement!
BMR Swaybar Rates:
FRONT
Hole 1 (Boot-Leg end of bracket)
98% stiffer than OE bar
Hole 2 (Center)
146% stiffer than OE bar
Hole 3 (Flat end of bracket)
214% stiffer than OE bar
REAR
Hole 1 (Outer hole towards end of bar)
99% stiffer than OE bar
Hole 2 (Center hole)
173% stiffer than OE bar
Hole 3 (Inward hole towards curve of bar)
301% stiffer than OE bar
All of this for under $400...
BMR guy is offline   Reply With Quote
Old 03-12-2012, 05:17 PM   #14
toehead93
All of the parts required are about $400 for new parts, this includes FE5 endlinks and LCAs which are both improvements over the FE3 setup. I can't afford both aftermarket bars and endlinks now and I'll be able to save more if I can wait to find a set of take off sway bars. For now I don't forsee any need for a rear adjustable bar but in the future I can pop a Pedders or Pfadt FE4/5 bar in back and still benifit from the FE5 geometry.
2010 2SS A6 - sold.
bar, bars, buy, buying, sway
