Old 03-12-2012, 12:07 PM   #15
TheBlack-CyberGray-Pearl
TheBlack-CyberGray-Pearl's Avatar
Drives: 2011 Cyber Gray Camaro
I checked the bolts, they are all very tight. And it's just during the heavy vibration of cold start..
it doesn't really sound like a metal vibration if that makes sense... It sounds like what a loose plastic panel vibrating would sound like, but i'm pretty sure i did't move any plastic pieces...
Any other ideas??? I know this is a hard one to answer because it's defiantly something you have to kid of hear, but i figured that it doesn't hurt to ask.
BBk LT Headers/ Injen LT CAI/ MRT v2/ RX Catch Can/ Black Ice Insulator/ Trifecta Tune/
TheBlack-CyberGray-Pearl is offline   Reply With Quote
Old 03-12-2012, 12:11 PM   #16
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
Like u said id have to hear it...its probably something so easy u dont know what it is..check the extensions on the o2 sensora maybe the connectors are hitting something when u start it up? Did u tie them down to somethink? I kbow mine were to loose so i tied thwm down
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 03-12-2012, 12:31 PM   #17
bmorecam
What kind of vibration? is it vibration that's accompanied with rattle, knock, etc.. or just slight vibration only? if is only vibration than that's normal. After header your car will vibrate a little more especially for the first start up and in cold temp.
Old 03-12-2012, 12:33 PM   #18
bmorecam
never mind, just saw your post. Just remember that aftermarket headers will be alot noisier vs factory cast manifold. You are probably hearing new engine noise with more vibration which is normal.
Old 03-12-2012, 12:49 PM   #19
Yeah, it sounds like its something on the dash/ again/ a plastic part, but i can't figure it out because it only last for about 5 seconds during the begging of the cold start... This is going to be an adventure trying to figure it out.
Thanks for your ideas/ input so far!
Old 03-12-2012, 08:14 PM   #20
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Did you try to reuse any of the factory heat shields?
If so, make sure there's room around them.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 03-12-2012, 08:39 PM   #21
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Forgot about those...i didnt reuse mine..
Old 03-12-2012, 08:40 PM   #22
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
+1 on the heat shields...
hapisok is offline   Reply With Quote
Old 03-12-2012, 08:41 PM   #23
usa1camaro1969
Neither did I, but I know others have, and had a rattle on initial starts.
-Ricky Bobby
Old 03-12-2012, 08:44 PM   #24
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I left my heat shields off too. More of a pain than anything.
Old 03-12-2012, 08:44 PM   #25
I didn't reuse the main ones that go over the headers but i'm going to check the heat shields connected to the factory gaskets. After thinking about it, one of the might've gotten bent in a little bit so hopefully it's that.
Thanks for the ideas guys!
Old 03-12-2012, 09:27 PM   #26
rtcat600man
That is a good thing to check. I know I had to bend my driver gasket pretty good to clear the headers.
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 69 08-19-2017 11:09 PM
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
SNEAK PEAK! 2010 camaro RS V6 gains 33HP and torque with install of BBK headers! brothersperformance.com Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 138 02-21-2011 04:27 PM
Can I install a Maggie TVS2300 without Headers? speed racer Forced Induction - V8 19 04-12-2010 06:37 PM
