Old 03-11-2012, 01:29 PM   #1
ryan's camaro
Taeng
ryan's camaro's Avatar
Drives: Fast
LSX engine in V6 Camaro
I'm kind of new to this kind of car stuff but I've been seeing a lot of videos where people replaced their original LS3/L99 V8 Camaros with GM Performance LSX engines. I was wondering, later on down the road when my LFX V6 engine breaks down (hopefully not, at least for a good 15 years), would it be possible to stick one of these LSX engines into my V6 Camaro?
I figure that if a V8 one can fit an LSX, a V6 one can do, same chassis and body. About $10k for a brand new LSX that produces around 700 hp seems like a steal to me!
ryan's camaro is online now   Reply With Quote
Old 03-11-2012, 01:38 PM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
It could be done but you would need to replace the transmission rear end maybe the motor mounts the ride height the wheight distribution. You would need a lot of work time and money invested into it to do that type of change.
Proud owner of litho #179 Click Picture for Build Thread
Old 03-11-2012, 01:41 PM   #3
Synner
Drives: not stock
Plus ECU, pulleys, accessories, wiring, tranny, driveshaft, rear end, tuning.
Old 03-11-2012, 04:28 PM   #4
spyderbuddy
spyderbuddy's Avatar
But 15 years from know who knows?
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 03-11-2012, 04:29 PM   #5
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
It wouldn't be hard to do at all. I dropped my 3.4L v6 out of my 1994 Camaro and put an LT1 in there.
Because the 2010+ Camaro has a front frame such that you drop the entire front suspension + engine and trans out as one piece just like on my 1994, I would imagine all you would need to do is find the following items:
1) Front frame that the motor mounts to from an SS (assumption is that all the LSx engines mount the same)
2) LSx engine
3) LSx accessories (from an SS)
3) LSx compatible transmission (from an SS)
4) Engine wiring harness (from an SS)
5) ECU/PCM (from an SS)
6) drive shaft (from an SS) [this might not be necessary - depends on if the LFX, L99, LS3 have the same driveshafts]
You shouldn't need a new "rear end" since the 2012 rear differential is the same on all models. You might need to get a better gear ratio.
Basically - your best bet 15 years from now would be to buy an SS that was rear ended and then swap all the parts from the SS over to your car.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 03-12-2012, 12:08 AM   #6
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Truth in This Post... One exception though, the v6 auto rear assembly would need to be swapped. It is different.
Is very straight forward as long as you have a donner car to pull the v8 parts from.
2) LSx engine
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 03-12-2012, 01:44 AM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
2) LSx engine
exatcly what ill be doing.
Just need a price on the SS harness and ECU
CAMARO
Old 03-12-2012, 07:55 AM   #8
meissen
meissen's Avatar
I'm almost positive I read that for 2012 the v6 and v8 rear assemblies are the same (minus the gears)
Old 03-12-2012, 11:59 AM   #9
bmorecam
v8 and v6 manual has the same rear. I know this for a fact. I just had my 3.91's put in. Tracy also confirmed for me before I even had my gear change done.
As far as V8 swap. It can be done and shouldn't be as hard as some peoples make it seem to be. If you have the money, of course anything can be done. Most used v8 tranny combo(LS1, LS2, LS3, LS7, etc..) come with ecm and all original wirings. If I ever need a new engine and is not covered under warranty you better believe I will be sticking in a used LS2 or even a LS1. LS3 and other newer engines cost way tooo much.
Old 03-12-2012, 01:41 PM   #10
meissen
meissen's Avatar
Thank you sir - I knew I saw it somewhere but for the life of me I couldn't come up with any good keywords to search and find my proof.
Old 03-12-2012, 02:55 PM   #11
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
This is exactly what I plan to do 10-15 years from now. It is possible, just a matter of getting all the right parts.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 03-12-2012, 02:57 PM   #12
nak3dsnake
nak3dsnake's Avatar
Its really not, most that say it is just think that its a waste of time. They probably haven't ever done an engine/trans swap either. But with enough money, and time you can do whatever you want with your car.
Old 03-12-2012, 06:11 PM   #13
meissen
meissen's Avatar
I can agree with that - having done a v6 to v8 swap, I would only advise others to do it if the car holds a lot of sentimental value to you. Otherwise, it's much easier to just trade in the car for a v8.
Then again with the amount of appearance mods people are doing to their 5th gens, I can see how some would rather just swap engines than have to do all the appearance mods all over again.
Granted, my LT1 is old technology now but for $1,000 I was able to buy an entire LT1/trans/pcm/harness pull out, both doors from the car, the rear hatch, the rear bumper, all 4 rims and tires (including the spare!), both t-tops, and the entire body harness from engine bay to taillights. I spent another $150 on the k-frame. I then turned around and sold my good condition 3.4L v6 for $300, my good condition 4L60e for $300, the rear bumper for $25, the rims and tires for $100, and the t-tops for $100. For a stock swap, it only cost me $325. ...then I cammed it, had the trans rebuilt, new stall, etc, etc.
Old 03-12-2012, 06:19 PM   #14
Kmorpheus
Drives: Green Dream Machine
Just get another v6 and roll all that other money into a twin turbo setup. This is just my opinion on the best way to spend that money.
Kmorpheus is offline   Reply With Quote
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
2012 LSX Challenge Series - 5th Gen Camaro Index-Style Bracket Racing Sean@Phastek Camaro Motorsports Discussions 0 12-14-2011 02:11 PM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
