Vivid Superchips
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 03-11-2012, 12:51 PM   #1
Brett64D
Brett64D's Avatar
Drives: 2010 2SS/RS L99
DIY for changing the shift indicator light on an automatic??
I did a search but could not locate this mod, anyone do this already? Thanks.
Brett64D is offline   Reply With Quote
Old 03-11-2012, 03:18 PM   #2
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Hurst-Comp-Shifter-2010-Camaro-inst.pdf
This was the steps that I used. It is for changing the shift plate to a a Hurst plate. Use steps 1 to 10 and disregard 11 on. Get you some very small diameter shrink tubing so you can insulate the led leads. After putting the led into the holder you can solder solder the connector. They are a resistor on the yellow wire but I do not now it value. I used my own resistor. After you put in your new led reverse the procedure.
Caddy
Caddy
Caddyroger is offline   Reply With Quote
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 7 03-15-2013 09:03 PM
AUTOMATIC with TAP SHIFT... stymie Camaro ZL1 Forum - ZL1 Specific Topics 74 02-24-2012 06:17 AM
Raptor Shift Lights @ KY SPEED Brody Audio / Visual / Electronics/ Gauges / Nav 2 12-16-2011 07:20 AM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
Did Camaro (automatic) reviewers use tap shift ? trudawg660 5th Gen Camaro SS LS LT General Discussions 30 11-09-2010 07:55 PM
