JDP Motorsports
Old 03-11-2012, 01:57 PM   #1
meltyface
meltyface's Avatar
Drives: 2010 1SS CGM LS3 w/ blk rally
Lowering car questions
I've been thinking about lowering my car now that I replaced my 21" wheels with 20s. I'm thinking an 1" drop would give the give the perfect stance. I've got two questions however:
1. What is the best/most dependable brand of springs ya'll recommend?
2. Do I need to buy or do anything additional when lowering the car, or is installing the springs all that's required?
Installed mods:
Kooks 1 7/8" headers w/ high flow cats, Borla x-pipe, Borla Stinger exhaust, Cold Air Inductions CAI, markers, tail and reverse lights plus parking light blackouts, body colored bowties, body colored SS emblems, Passport 9500 radar detector (a must have), Kenwood DNX9960 radio w/ metra kit. Matte Black Giovanna Dalar 5V: 20x8.5 & 20x10 wheels
Mods in the future:
Relocating guts of "shark fin" and removing it, cam, super charge/turbo?...unsure what after that...
Gotta have MORE power!!
meltyface is offline   Reply With Quote
Old 03-11-2012, 02:05 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
1) They're all about the same. Find a brand that falls within your budget.
2) You need to get an alignment afterwards. Then having a spring compressor helps with the install but isn't really needed.
Click to view my build thread
Old 03-11-2012, 02:13 PM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
this.
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 03-12-2012, 03:42 PM   #4
meltyface
meltyface's Avatar
Is it true that if you lower the car more than 1.25" the handling will suffer? Also what is the max I should lower the car to, or probably what clearance should I keep so that I don't screw up my car when I drive it?
Installed mods:
Mods in the future:
Old 03-12-2012, 03:55 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Handling doesn't suffer at all. The problem with going much lower than 1.25in is that you may need aftermarket camber bolts for the rear. The fronts seem to have more adjustability than the rears. I've yet to hear of anyone that couldn't get factory alignment with Pfadts 1.25in springs. I use their street performance specs which give you a combo of good handling and good tire wear. I just turned over 20k on the stock Pirelli's, if that tells you anything, besides the fact that I don't do a lot of burnouts.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
White Lightning....The Story Begins CamaroKid300 Member Car Journals 406 05-31-2015 09:11 PM
Sooooo...I guess I'm sending the car to Livernois! rdblan2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 86 10-17-2011 01:48 PM
Getting Antsy Doc 5th Gen Camaro SS LS LT General Discussions 26 08-19-2009 12:49 PM
