HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Vendor and Seller review / feedback / experiences
Old 03-11-2012, 04:17 PM   #15
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Originally Posted by AKA-22 View Post
wow !!! how hard is this to get right.....now im wondering if i got this messed up on my car....pics please of where the hoses go...
It's not difficult.
LS3 - center hose goes to the valley cover nipple low and behind the passenger side of the throttle body. The outter hose will go to the nipple on the intake manifold about 2 inches away from the valley cover one. You are just replacing the U shaped hard line that goes between the two fittings.
L99 - Center hose goes to the hard line that runs from the back drivers side PCV fitting. You could run a longer hose to that back fitting so you don't have to cut the hard line. The outter hose goes to the same as described on the LS3. Again you are just putting the can inline with that run.
The link I posted has great pictures and describes the install for both.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-11-2012, 04:41 PM   #16
AKA-22
AKA-22's Avatar
Drives: ELLE-1
this is a picture of what i would consider to be right installation...
AKA-22 is offline   Reply With Quote
Old 03-11-2012, 08:22 PM   #17
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Hope this helps some of you.....
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 03-11-2012, 11:10 PM   #18
Ace1USMC
Drives: 2011 Camaro SS LS3
Originally Posted by IndeedSS1 View Post
If it didn't seem right, why did you continue? I've skimmed the instructions but don't rememeber where it mentioned hooking up the hoses in the wrong places.
Cause I was even more stupid than the person that wrote the directions in the first place. I fully admit I was stupid to ignore the warning bells going off in my head based off of my own understanding of how essential a PCV system is and how it works. I was plain dumb to not trust myself in this case. STUUUUUUPID. I'm stupid. That's all there is to it. And now I gotta replace a rear main seal on a relatively new car.
Sam
By His wounds...
Ace1USMC is offline   Reply With Quote
Old 03-11-2012, 11:34 PM   #19
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
I agree the paper instruction I had were horrible luckily I was able to find A video on YouTube that made it so easy search YouTube or try the search up top I'm sure you'll find it
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 03-11-2012, 11:43 PM   #20
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I just googled on how to put the RX on my L99 and found a Camaro5 thread with DIY instructions written by SC2150. It was an easy install other than removing the stock hose from the nipples. If I remember right the driver side should go to the center part of the can and the passenger side should go to the outer part of the can basically creating and X with the two lines.
ACE1USMC, did you just remove the RX and bring it back to dealership and say it should be covered under warranty? If not, how much did you pay out of pocket to get it fixed?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 03-12-2012, 12:00 AM   #21
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
The Big question
The big question is why a manufacture would send out a quality product with insufficient or unclear install instructions ? Sound's like several purchasers have felt this way.You should not have to go to you tube or the web to find clear an concise in stall instructions on a product that you purchase.Especially on a product as critical as the catch can is.I received some intall instructions from a vendor on this site once that were the same way.Copied to many times, unclear pictures blurred et'c. so I know how the intaller feels.Too bad this turned out to be a major repair for you.Good luck with it.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 03-12-2012, 12:20 AM   #22
2FST2LIV2YNG2DY
...this is my addiction!
2FST2LIV2YNG2DY's Avatar
Drives: SOLD
I don't know about anyone else but when I install something under the hood I always look for a DIY on here first.
And sorry for your issue with the RX can.
I am here: http://tapatalk.com/map.php?qthwzq
Sent from my iPhone 4 using Tapatalk
5% Tint, K&N AirCharger, Flowmaster American Thunder A/B with 5" Tips, Light Wurkz Orion V2 Halo's, Matte Black Rally Stripes, VR Interior Trim,Viper SmartStart
TEAM LLT
2FST2LIV2YNG2DY is offline   Reply With Quote
Old 03-12-2012, 12:38 AM   #23
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Sam
Hey Ace I got sum good news for ya..I would very seriously doubt that you've gotta replace the rearmain seal,just clean up the mess,may have to do it acouple of times to get it all,but you should be fine.....really...
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 03-12-2012, 01:25 AM   #24
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Yeah the instructions are a damn joke. I scoured the internet and found some instructions. Mine is installed correctly.
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 03-12-2012, 08:35 AM   #25
IndeedSS1
IndeedSS1's Avatar
Sam
I wonder if you will be one that gets lucky and it will seal up on it's own not that the excess pressure has been relieved? I hope it does so you don't have to mess with it.
I had a torque wrench quit working while I was tightening an intake manifold bolt this weekned and snapped it off Stupid me for not realizing on my own that I had passed 89 inch pounds a few turns ago. It's nothing like a seal, but still sucks as this is my daily driver.
Good luck with it
Old 03-12-2012, 11:31 AM   #26
SC2150
WOW!! Have been at the Gator Nationals and just got back....have to say frst I'm sorry, but I can find anywhere in the instructions where it states to install the lines backwards, and I am always available via PM, email, or phone to help any that need....with over 10,000 of these sold and installed over the past9-10 years some do have difficulty and thats why were here to help and this community has tons that always jump on to help.
We continue to update instructions when we get feedback from customers on how they think we can improve them, but the principal of installing a can is pretty straight forward.
I have to ask, why would anyone not contact us for help if they have any doubt?
I have at times even been up at midnight or later helpping customers on the west coast when they need. Again, our appologies for any confusion and please let us know which instructions (different for different makes/models/motors/mods) and what page so we can edit in any way to help.
Old 03-12-2012, 11:50 AM   #27
SC2150
I just read through each instruction and can't find where it states to hook the can up backwards:
2010 Camaro installation
First thing is to understand the concept. The RX oil separating catchcan plumbs simply inline between the intake manifold vacuum nipple (passenger side of the intake manifold snout) and the valley cover fitting on the LS3, or the line running to the rear of the drivers side valve cover:
Note: The center fitting of the can is the inlet, and this will run to either the valley cover fitting (just below the intake manifold vac nipple on the LS3) or the rear of the drivers side valve cover.
(on the LS3 this tube is removed) The outlet is the outer fitting and connects to the intake
Thats the V8 version,
And the V6:
Note: The mount can attach to either the radiator shroud bolt or the bolt shown here that the engine cover stud. With the can mounted, run the hoses as shown. The fittings both turn to orient as needed. The center fitting of the can is the inlet, and runs to the end terminating at the rear of the passenger valve cover. The outlet connects to the intake manifold vacuum source.
These are the instructions supplied with the catchcan kits.....so I'm confused.
I ask if anyone wants to contribute suggestions to improving the instructions please do, but dont attack with such insults. Most here know I go ot of my way to always help any with questions or issues on any subject, all one needs to do is ask.
We may look at something so simple as installing one of these as so simple instructions should not even ne needed, but were looking at it from a tech standpoint and realize even the most simple things can be complicated for those that have no knowledge of motors and cars, but please ask....dont just jump and attack.
Old 03-12-2012, 12:14 PM   #28
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
i concur.
10/28/2010 got it
y2k king is offline   Reply With Quote
Scrming's Rx Catch Can install & review scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 87 07-16-2015 07:29 PM
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 137 08-13-2014 04:06 PM
catch can research shows it's worthless kiteman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 205 04-12-2014 07:15 PM
HELP! Power Reduced Message after installing catch can? CyberDan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 10-17-2010 09:23 PM
