| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#26 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
Excellent George....look at you being sneaky....I had no idea your car was up North. Will you be ready for Pony Wars?
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
#27 |
Banned
Drives: black Join Date: Mar 2012
#28 |
G200 Pilot
Drives: 2010 Camaro SS/RS purchased 5/2010 Join Date: Dec 2010
That's the plan! Things didn't work out at previous shop, forcing me to send the car to Ted for completion. But, it's all Ted's stuff and recommendations in there!
#29 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
What are the similarities between a 500rwhp camaro and a 1000rwhp camaro???
They both run 13s teheehehehehehee |
#30 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
am I the only road couse car going for 1000?? seems like everyone just likes the drag strip!
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
#31 |
![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Probably because it will be easier to hook at the track. 1000rwhp on a road course will be hard to do, at least I think so....
MODS:
Whipple 2.9L SUPERCHARGER 666RWHP 562TQ ADM Stage 2 Cam ADM Dual Fuel Pump System ADM CAI ADM Boost & Air Fuel Ratio Gauges Patriot Performance Dual Valve Springs Hurst Short Throw Shifter KW V1 Coilovers Stainless Works Full Length Headers & Full Exhaust Elite Engineering Catch Can Forgeline GA3 Satin black wheels 20x9.5-20x11 |
#32 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS L99 Join Date: Nov 2009
I think this thread is a little unfair for those automatic guys. Especially if they are running a convertered 4L80E with a 9" with big slicks and a tall gear on a mustang dyno. A 940RWHP auto is making the same power as a 1000RWHP manual and that is with a stock drivetrain, tires ect. The margin will be even worse with a conveter,4L80E, 9 ", gears, tall tires ect, ect... I think you need a 9.9 ET and below thread. Lets see how many manual cars make that list.
#33 |
H-Town Camaro Club
So where's the list
I see a couple of dyno sheets here......and I want to see Russ's sheet too...
#34 | |
need....more....hp
#35 |
![]() ![]() Drives: 2010 Camaro 2SS/RS - L99 - CGM Join Date: Apr 2010
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein |
#36 | |
Mmmmm...nitrous.
Awesome...this is your car?
![]() There's one sheet posted, but I'd like to get more info (see above). I'm not worthy. If I get there I'll post it up. ![]() Guys...can we please not turn this into a dynos are crap and the only thing that matters is your slip thread? I get it. 1000 RWHP means nothing to some if you don't have great numbers at the track. I also know that you can do many different things to get your car to go faster, and HP is only one of them. We already have an official quarter mile thread and an unofficial one. This is simply a fun way to see who's car made 1000+ on the dyno. Nothing more. Quote:
#37 |
![]() Drives: 2011 CG 2SS Join Date: Oct 2009
To poke where I see poking is due
... Ok, ok I'll add some information to this post since George does not post here personally: George Abad 2010 Camaro 2SS ECS Hardcore Edition Package: - ECS RHS 427ci Forged Motor featuring ECS Diamond Pistons - ECS Supercharger Kit - Featuring Vortech YSi, 10-Rib Direct Drive - ECS Fuel System - Triple Walbro Pumps; Feed + Return; Adj. B/R FPR. - Pfadt Suspension: Coilovers, Subframe Bushings, Complete Poly Bushing Around Vehicle. - DSS 9" Conversion Kit: 3.70 Gears - RPS Triple Clutch - ARH LT Headers, 3x3" Hi-Flow Catted X-Pipe - Stock Mufflers Stock TR6060 Transmission. GM High Tech Performance Magazine - Sleep-On-This |
#38 |
#39 |
I do what Robert does
Drives: 427 LSX- with TWINS Join Date: Jan 2007
subscribed
#40 | |
Banned
the blue line on the dyno sheet is rwhp. redline on dyno sheet is torque. green line on dyno sheet is boost. brown line on dyno sheet is air/fuel far left side of the dyno sheet has numbers from 300 to 1000 which is horse power. notice how the highest point of the blue line on the dyno sheet lines up with the 1017 point on the far left number column. weight is 3900 with 1/2 tank of gas and no driver. vortech ysi 17.5 pounds of boost. 427 rhs block 9 inch rear which eats up more rwhp than the chevy rear 4.11 |
#41 | |
Wow...there is the big ongoing discussion about running cats with high HP/Tq applications. No problems with cat failure? Are these the ARH hi-flow cats that come with their standard header kit? What size headers?
DSS 1400HP axles, DSS driveshaft.
BMR driveshaft loop, 1" lowering springs, sways, trailing arms, toe rods, links, total suspension pro-version poly bushings. 1 7/8 ARH long tubes, 3" cat back, Dynomax VT axle-back. Edelbrock E-force SC with 3.25" pulley, JRE e-force fuel rail mod, 850cc Dynamic injectors, LPE twin fuel pump, JRE rough idle blower cam kit, Roto-fab e-force intake, RX catch can. Jannetty Racing Tuned: 622 rwhp / 582 rwtrq |
#42 | |
Mmmmm...nitrous.
Yea...I know what the lines mean. Just didn't see the number. ![]() Looks like you're the first one going up. |
#43 | |
Mmmmm...nitrous.
![]() What's his C5 member name? |
#44 | |
214-228-8782
![]() Drives: 2013 ZL1 #138 Join Date: Oct 2008
#45 | |
214-228-8782
Old but good....More coming 2012
#46 |
Matt how did that stock tr6060 hold up with all that power... let me guess one dyno pull.
#47 |
Mmmmm...nitrous.
Good to see you in here Andy. I'm sure we'll see some more of your builds on the list. Which C5 member is this? Can you give me some more info?
#48 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 1LT SIM; 91 B4C sleeper Z Join Date: Aug 2009
Alright, I'm checking in!
Wait, oh I see, 1000....... well gotta run.... ![]() Very cool seeing this "elite" bunch!
#49 | |
is that ??? SSmagna.... Chris from Tejas |
#50 |
Yes, That is Chris' (SSMagna) ADM's 1st Twin Turbo Car.
| Thread Tools | |
| Official Capital District Camaros of N.Y. Thread | CDCNY | USA - NY / NJ / PA | 292 | 05-14-2013 11:09 AM |
| H-Town Camaro Club Wins Best Club Award at Chevy Expo - (Mega Pics) | mlee | Camaro Photos | Spyshots | Video | Media Gallery | 94 | 02-22-2012 10:07 PM |
| Club Day at Speedworld in January on a Sunday | chellzers | USA - Southwest | 0 | 01-03-2010 04:39 PM |
