Emblempros
Old 03-12-2012, 02:53 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
tranny wine
Ok so I have noticed a wine sound coming from under my car. It does not change with different engine speeds just the faster the car goes the louder it gets. I know its in the tranny and not the rear end cause when I have the car in 5th you can really hear it throught the stick. If i keep it in 5th and push on the shifter to the right its twice as loud and you can feel it through the shifter. It does the time in 3rd and 6th but not as bad. I have the hurst shifter in it so I put my stock one back in just to see if it would lower the sound down and it did a bit but it came back to the same as with the hurst shifter. I put the hurst back in and its so damn anoying!!! I check the fluid and its good. I have Royal Purple in it. I just changed the fluid about 3k miles ago. I also had Royal Purple in it as well.
2010_camaro is offline   Reply With Quote
Old 03-12-2012, 02:39 PM   #2
rick@tandtperformance
rick@tandtperformance's Avatar
Drives: Corvette
Is the noise still present in 4th? If so, it has to be a bearing. Take it to a dealer soon!
rick@tandtperformance is offline   Reply With Quote
Old 03-12-2012, 05:34 PM   #3
2010_camaro
you can hear it in all the gears. I took it up day and they said its normal it just my shifter thats making it louder. I told them it just started. I had them give me paper work on it stating i was in there with a complaint about the tranny and I was told its good. So im going to drive it untill to blows apart
we added some extra protection from the FL heat for my A6 tranny (pics inside) bumblebeecamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 38 12-29-2012 12:11 AM
Auto Tranny Fluid Question camslambam V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 16 04-15-2012 02:24 PM
Seperate tranny tune in addition to an engine dyno tune? Fireslayer Tuning / Diagnostics -- engine and transmission 27 11-28-2011 09:04 PM
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 08:25 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 09:28 AM
