ADM PERFORMANCE
Old 03-12-2012, 11:05 AM   #1
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
L99 guys with stall and maggie
Alright guys Im going to the track friday to try my new setup!
I have ls3 conv.circle d 3200 stall and maggie and 18'' zo6 rims with nitto nto5r 305.bmr trailing arms.
Been searching looking for advice on launching a stalled auto with maggie! Are yall launching from idle or running rpms up?
Thanks
BowenSS1 is offline   Reply With Quote
Old 03-12-2012, 05:19 PM   #2
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I don't have a Maggie, but I run a 3200 stall.
I would probably start down near idle and see if your tires will hook. If they hook up from idle, then move your rpms up a little and see what happens. I'd move up to around 1k rpms or so at first (nothing drastic). Then you can continue to raise your rpms until you can't hook up anymore or your times are not improving.
I run 20" NT555Rs and they hook okay, but not great. I usually have to launch down near idle. When I try to launch at 1K rpms or higher, I blow the launch with too much wheel spin. In my case, the higher the launch rpm, the greater the chance of blowing the launch.
I'm in need of a better wheel/tire setup to handle my setup (which is just bolt ons with a FTI 3200 stall).
Good luck.
Old 03-13-2012, 02:40 AM   #3
speedmon
Drives: C6 Z06
Does it hook up at the Stop sign if you thump it? Probably not......
Can you start in 2nd gear? If not try to get there ASAP.
This is with an eforce....you're most likely making more power.
Good luck......
Post the video ..... I want to see your burn out.
Wear a helmet.
speedmon is offline   Reply With Quote
Old 03-13-2012, 07:32 AM   #4
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Preload it a bit (like to 1500rpm), then "roll into it" as traction allows.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 03-13-2012, 07:52 AM   #5
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Leave off idle or invest in a 2step for consistent launches. I set my 2step @ 1k on my 2800 stall. Anything higher and it pushes through or blows the tires away. Tons of instant down low torque
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 03-13-2012, 12:34 PM   #6
SGOS252382
SGOS252382's Avatar
Padre
I just can't seem to "roll into it" ever since getting my FTI 3200. I've tried and tried, but my engine/rpms act like I've basically floored the gas and I'm running wide open.
When I was running the stock converter, that's how I always launched (rolling into the gas). That method worked great for getting the tires to hook, especially when I was still running the stock tires. Some of my best 60' were with a gentle roll into the gas.
With the converter, I still roll into the gas to launch (from idle). But as mentioned, my car just screams off the line and some times the tires hook and sometimes I just light up them up.
But I'm also running 20" NT555Rs with little sidewall. A better drag radial may solve my problem.
Old 03-13-2012, 12:47 PM   #7
Padre
Padre's Avatar
Well I'm getting used to the new ProCharger. It was so d*mn fast I couldn't roll into WOT until 2nd gear (this caused problems with the TC). So I'm still earning how to launch a centrifugal supercharger.
However, while still NA I did find a bit of pre-loading did help.
Padre
Old 03-13-2012, 02:29 PM   #8
SGOS252382
SGOS252382's Avatar
Padre
Wow, that thing must be mean. You've got to have a very light sensitive foot to keep the tires under it. (No heavy boots with thick soles).
Old 03-14-2012, 12:39 PM   #9
BowenSS1
BowenSS1's Avatar
Been practicing at a stop sign on a feeder road and with about a 1.5k load a can roll into it with some spin but Im on 22's so when I heat up my 18" nitto they should Hook!!
Old 03-18-2012, 10:49 PM   #10
BowenSS1
BowenSS1's Avatar
Went to track Friday and ran
11.5 in the 1/4 mile
.317 reaction time
1.8 60 ft
120 mph trap speed
Old 03-19-2012, 12:35 AM   #11
speedmon
Drives: C6 Z06
.317 reaction time
1.8 60 ft
120 mph trap speed
I think thats pretty good for a 2 ton car.
Did you pull any weight out? Passenger Seat? Rear Seats? etc.
Is that what you expected?
Did you do a monster burnout.
Where is the video?
Old 03-24-2012, 10:07 PM   #12
BowenSS1
BowenSS1's Avatar
No I didnt do anything to reduce weight and I was expecting at least 11.5 so i was happy to see it in my first pass!!!!
I went back to track Fri. and have new numbers!!
11.3 1/4 mile @ 118mph
1.6 60ft
I AM VERY HAPPY BUT WE WANT 10.999 LOL!!!!
Old 03-25-2012, 03:07 AM   #13
speedmon
Drives: C6 Z06
Where is the VDO? Tell your buddies to shoot an HD VDO and put it on youtube.
How much fuel do you run with?
Do they sell 105 at the track?
At least take out the passenger seat....and the subwoofer in the trunk
l99, launching, stall
2C cam and TC being installed at Livernois to go with my maggie jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 03-19-2011 10:50 PM
Car Back at Livernois for 2c Cam and TC to go with Maggie jsharp Forced Induction - V8 3 03-14-2011 07:35 PM
what stall for supercharged/cam auto jsharp Forced Induction - V8 20 01-14-2011 10:10 PM
