BeckyD @ James Martin Chevy
Old 03-12-2012, 01:01 PM   #1
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
V6 calipers question
I got a set of calipers powdercoated, but I need to remove the excess from the mounting holes where the bolts go. Anyone have one around that could measure the size of that hole so I don't remove too much material with a drill bit?
Toasty is offline   Reply With Quote
Old 03-12-2012, 03:17 PM   #2
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
The bolts thread into the caliper. Best bet would be to use the correct size tap to clean the threads out. Don't put a drill bit in there.
Squintz Palladoris is offline   Reply With Quote
Old 03-12-2012, 03:31 PM   #3
Toasty
Toasty's Avatar
I don't think so on the v6 calipers? ... The caliper brackets bolt to the spindle. Those threads are clean.
The holes do not seem to have had threads... they just have a few coats of PC, so the bolts don't go in all the way... the threads pass through, but the unthreaded part doesnt.
V6 Differential fluid change question cb2011rs Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 01-05-2012 06:59 PM
Eibach v6 question xTHExxFALLENx Suspension / Brakes / Chassis 3 12-15-2011 07:16 PM
V6 oil question. xTHExxFALLENx Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 13 11-27-2011 05:18 PM
V6 to V8 Driveshaft Question Amenti V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 09-05-2011 11:32 AM
2012 V6 Question Trailnut Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 04-27-2011 09:27 AM
