SDTW Custom Wheels & Tires
Old 03-12-2012, 01:24 PM   #1
dorfmac
www.macsautodetail.com
dorfmac's Avatar
Drives: 2010 2LT/RS
Interpret Dyno Sheet
Got a baseline dyno this past weekend. Nothing fancy to show off as I haven't done anything performance-wise to my car and everything seems pretty on point, but the only thing I actually understand on this are the numbers 250 and 231.
The rest of it is pretty confusing. I know that there are things you can interpret from the bottom chart, and also based on the slope or curve of the lines, etc. Maybe some of you can lend some further insight?
dorfmac is offline   Reply With Quote
Old 03-12-2012, 01:32 PM   #2
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
Your car an automatic or a manual? Is the numbers shown corrected or raw data?
What would you like to know? Nothing really to interpret as far as I can see, the curves look perfectly normal to me. TQ has a very nice flat curve.
Air to fuel ratio seems a bit high to me, but probably not an issue.
If you plan to mod in the future and want to know what you got, well then getting your baseline run is the best thing you can do since all dynos tend to read slightly different. Also, trying to dyno in similar weather conditions plays a big role, as the car may produce much less power on a very hot day as compared to a cool day, but that is where the corrected data comes into play which should even out the results.
Old 03-12-2012, 01:36 PM   #3
dorfmac
dorfmac's Avatar
Drives: 2010 2LT/RS
A manual, and I assume raw data, but only because I wasn't told otherwise. Not like I would have known what he was talking about if he did mention it
I'm not really looking for anything in particular, I was just wondering if there was anything else TO know outside of the HP/TQ?
Old 03-12-2012, 01:40 PM   #4
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
The air fuel ratio looks pretty lean, but aside from that nothing out of the ordinary.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 03-12-2012, 01:42 PM   #5
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Good numbers - 250 rwhp / 231 rwtq.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 03-12-2012, 01:43 PM   #6
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Looks like corrected numbers to me. Looks lean, but I don't know what normal for a V6.
Now get to modding that thing!!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 03-12-2012, 04:25 PM   #7
KMPrenger
KMPrenger's Avatar
Normal WOT A/F ratio for the V6 is typically around high 11s or low 12s.
If the dyno was one of those magical reading dynos that spit out numbers close to expected drivetrain loss (assuming weather is perfect) than I would have expected close to 260 wheel horsepower for your manual while 250 would have been perfect for the auto.
Those numbers might not be corrected, but no matter its still a decent run.
I don't think you are too far from me. Know of any good dynos in the mid mo area? Maybe I'll run into you at a JC or ozark car show one of these days.....your car is a monster
Old 03-12-2012, 04:33 PM   #8
acowherd
acowherd's Avatar
There is a good guy over in St.. Louis and a decent place in kcmo to get some baseline runs in. As far as tuneing work dsteck in St.Louis is one of the few.
FNSS Racing!
Old 03-12-2012, 04:43 PM   #9
vinman
The BBOMG fill-in husband
vinman's Avatar
So when someone does a run what hp number do you say you have at the rw? The corrected or the actual?
UPSTATE C5 MEMBER
Old 03-12-2012, 05:14 PM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
wow... that is insanely LEAN! Guessing this was just a tail pipe sniffer? Most likely a problem with the probe... don't think you car is really running that lean....
Curves look nice and smooth... clean... The 250 RWHP is a tad lower than I would expect for a manual... Looks like this was the first pull... Did you give the car a nice long cool down before putting the car on the dyno? Did you do multiple pulls? Was this the best?
scrming is offline   Reply With Quote
Old 03-12-2012, 06:21 PM   #11
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
Yea I thought the manual usually gets with 5 hps of 260 plus/minus
Blade is offline   Reply With Quote
Old 03-12-2012, 06:38 PM   #12
bmorecam
I was just at T and T last week LOL. Was you there for the friday tuning day?
Don't look too bad considering you are stock. I say as long as you are pulling 250-260 stock you are fine and very close to accurate. Some dynos stock read 230 for hp.
I was thinking about having my car dynoed there just to see what my car would read on a different dyno but was scared it was going to be another low reading dyno but I might have to make an appointment with tim soon
Old 03-12-2012, 06:40 PM   #13
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
that looks real lean at 2k and lean through the whole RPM band.
2010_camaro is offline   Reply With Quote
Old 03-12-2012, 06:43 PM   #14
Abstrak
Abstrak's Avatar
Drives: 2012 AGM Camaro LS / Team LFX
I should have went up Saturday with yall. Im definitely going to hit Tim up at the end of the month.
Abstrak is offline   Reply With Quote
New Dyno! 960rwhp on pump gas!!! beefcake General Automotive + Other Cars Discussion 22 02-26-2012 09:37 PM
Scrming's Airaid and Injen Dyno results... scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 212 06-28-2010 04:28 PM
AIRAID Dyno Test & Videos For 3.6L Camaro Airaid Filters Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 543 05-26-2010 11:46 PM
Camaro on the dyno today in Concord, NC! topgun1 Camaro Photos | Spyshots | Video | Media Gallery 6 03-19-2010 07:49 PM
69 SS Conv-New Power & Dyno sheet RichieFlorida 1st & 2nd Generation Camaros 20 07-22-2008 04:09 PM
