HeadlightArmor
Old 03-12-2012, 10:50 PM   #1
Peter
Drives: 2010 Camaro
Question Bad Idea?
ok, I put the drop springs from Pedders on my v6 camaro and I have alot of audio and batteries in the ass end of my car and my back sits about 1/2" lower then my front, it dont look to bad but it will annoy me if I dont fix it. I know the best way to fix it is to get coilovers. But right now I dont have the money for it.
But one of my co-workers said to cut a half loop off my front and that will lower it about that half inch. This sounds like a bad idea to me but has anyone done this or know about it. I have not ever done or tried to do this to any of my vehicles.
2010 JL Audio
Build Thread: http://www.camaro5.com/forums/showthread.php?t=139419
#280 MASTER MECP Certified
MECP - Sales, Basic and Advance Certified
ASE - 6 electrical certified
10+ years car audio installation, sales and manager
Peter is offline   Reply With Quote
Old 03-13-2012, 07:59 AM   #2
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Don't cut those springs,they will not seat properly in the spring seats.What spring# did you use in the rear of the car?
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-13-2012, 09:06 AM   #3
Peter
Drives: 2010 Camaro
220032 front and 220033 rear
2010 JL Audio
Old 03-13-2012, 09:56 AM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
I would avoid cutting any manufacturers springs at all costs. It's just not a good idea.
Old 03-13-2012, 12:12 PM   #5
Peter
Drives: 2010 Camaro
then what options do I have to lower the front some more so it looks level?
2010 JL Audio
Old 03-13-2012, 12:31 PM   #6
garcmol
garcmol's Avatar
Pedders will work with you. DO NOT cut the front coils. Send Bruce (or any of the Pedders vendors) a PM and see if you can exchange your rears springs (220033 1.5" drop) for the 220035 which is only a 1" drop. That way the rear will match the front and no cutting.
Old 03-13-2012, 01:01 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
That would depend on which springs he started with.
Another options is to hit BMR up for a set of their 1.4in drop springs for the front. They are around $130 for just the fronts.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-13-2012, 01:37 PM   #8
garcmol
garcmol's Avatar
True, but that's some more cash. He started with the 220032 up front which is 1.3" drop. Not much difference. Bring the rear up .5" with the springs I mentioned and his wheel gap will be identical front and rear.
Old 03-13-2012, 02:14 PM   #9
I would get with the dealer you purchased the springs from and switch them out to the 220035.it should raise the rear 1/2" .
Old 03-13-2012, 10:12 PM   #10
Peter
Drives: 2010 Camaro
ok I will see what they will do I ordered them from Pedders directly.
I like the way the back sits, so idealy I would rather lower the front more but really dont want to spend more money on it. Plus who would if I did change the front to the BMR would want to just buy fronts. lol
thanks for the help guys Ill let you know what happens.
2010 JL Audio
Old 03-13-2012, 10:13 PM   #11
Peter
Drives: 2010 Camaro
O also does it matter for the BMR since I have a v6 not an 8
2010 JL Audio
Old 03-14-2012, 12:30 AM   #12
axis
Search Ninja
axis's Avatar
On a 2010 model, no.
Halltech CF 102 fed
Old 03-14-2012, 09:52 AM   #13
Rich@BSP
Drives: wife says to many
Call Pete or Deb at Pedders and get the 220035 springs. In the long run you will be mush happier. Too low on a stock shock or strut is not a good idea.
Rich@BSP is offline   Reply With Quote
Old 03-14-2012, 09:58 AM   #14
garcmol
garcmol's Avatar
Plus you've got the additional weight you mention in the trunk. I think the wheel gap up front is perfect!
extended warranty good or bad idea Howard D 5th Gen Camaro SS LS LT General Discussions 28 12-26-2011 09:25 AM
ZEX Nitrous - a good or bad idea? general thoughts.. AdamCzap Forced Induction - V8 5 07-01-2010 08:27 PM
Honda CRZ, bad idea as a hybrid, but...... Stew General Automotive + Other Cars Discussion 8 05-29-2010 11:13 PM
Clear bra protectant - good or bad? jokerswild Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 38 05-12-2010 04:09 PM
415 stroker and 10 psi from a supercharger good or bad idea ls7camaro Forced Induction - V8 30 07-17-2009 01:19 AM
