Solo Performance
Old 03-13-2012, 11:26 AM   #1
2011 SS
2011 SS's Avatar
Drives: 2011 SS M6, LT's, CAI, SLP LM II's.
Grind
I was gettin on my car today and hit second and got a bad grind my clutch was in rpms about six grand what could this be? Synchronizers?
Sent from my SPH-D710 using Tapatalk
2011 SS is offline   Reply With Quote
Old 03-13-2012, 12:59 PM   #2
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Do a search on here for that problem and you'll find it is a fairly common problem. My car has no power train warranty left so I changed to Red Line D4 ATF fluid and it help with the fast shifting and 2nd gear grind. Not a cure all but it helped.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-13-2012, 01:32 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I did the same thing and with the D4 it is smoother. I also take about 0.5 second longer on the 1-2 shift and this also helps
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-13-2012, 01:44 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Clutches chatter, gears grind.
Old 03-28-2012, 12:13 AM   #5
leisure
Drives: camaro
figures: GM! hope you're enjoying your bail-out. you won't get another.
gears aren't supposed to grind. no matter what you may hear from GM.
leisure is offline   Reply With Quote
Old 03-28-2012, 02:28 AM   #6
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
You do realize GM doesn't manufacture the transmission right? It's Tremec's fault, not GM's.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 03-28-2012, 08:40 AM   #7
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
This 100% is my experiance also. You can not slam the 1-2 shift at high RPM. Other then this my trans shifts perfect.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 03-28-2012, 09:52 PM   #8
leisure
Drives: camaro
you do realize.....
GM approved of the design and manufacturing of a car that too often grinds into second gear. no notch. grind. no clink. grind.
GM has done little, if anything, to take ownership of the problem. in fact, in most cases... GM tells customers there's nothing wrong. it's natural. characteristic.
equally, if not more, complicit and culpable.
Old 03-29-2012, 12:14 AM   #9
Waterboy2b98
Waterboy2B98
Waterboy2b98's Avatar
Drives: 11 2SS M6.
I just put the Red line D4 ATF in my car trying to get rid of the 2nd gear grind. Does it void the transmission warranty?
Waterboy2b98 is offline   Reply With Quote
Old 03-29-2012, 08:05 AM   #10
TornadoSS
WICKDSS
TornadoSS's Avatar
I doubt that it will void warranty. The D4 meets or exceeds the fluid specs from GM.
V6 AY6 M6 2nd Gear Problem - Report Your Issue Here CAMAR0 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1606 10-25-2012 04:18 PM
2nd gear grind (tr6060) and Redline D4 ATF TornadoSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 04-04-2012 08:15 PM
Hurst vs Factory Shifter and 2nd Gear Grind jtmiller92 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 09-28-2011 08:43 AM
it finally happened...1-2 grind cybergrayls3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 06-15-2011 10:52 AM
Need Tips how NOT to &@!&! grind second gear! xpanda305x Dragstrip and Launch Techniques Discussion 13 04-30-2010 08:16 AM
