BeckyD @ James Martin Chevy
Old 03-13-2012, 01:21 PM   #1
blackswan
blackswan's Avatar
Drives: Yes
Problems with SS manual trannies?
Someone told me recently there was an "issue" with the manual trannies on the SS's. Did a search and couldn't come up with much, anyone know what this might be in reference to? Assuming GM stepped up and fixed it but want to ensure a friend's experience isn't a bad one.
blackswan is offline   Reply With Quote
Old 03-13-2012, 01:30 PM   #2
GlennP
Drives: 2011 Camaro 2SS
Probably the second gear grind or the fact that it clunks around a little bit. The latter is not an actual issue though.
I have a 2SS manual, problem free
GlennP is offline   Reply With Quote
Old 03-13-2012, 01:41 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Some of the early 2010 builds (pre 24,000 vin #'s) had some output shaft problems. The TR6060s in general have pretty weak synchros.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 03-13-2012, 01:46 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
No problems with mine.
Old 03-13-2012, 02:19 PM   #5
CCbusa09
CCbusa09's Avatar
Drives: '06 Tacoma, '11 Durango, '12 SW 1SS
No issues with mine!
I have owned many mustangs in the past and all had less that desirable traits with notchiness and grinding, so I was a liitle hesitant to order my Camaro until I watched this reassuring video:
2012 1SS LS3; Borla S type axle back and CAI, Inc. cold air induction.
CCbusa09 is offline   Reply With Quote
Old 03-13-2012, 04:15 PM   #6
cowjazz
Drives: 2010 2SS
No problems with mine at 33,000 miles.
cowjazz is offline   Reply With Quote
Old 03-14-2012, 09:55 AM   #7
Waterboy2b98
Waterboy2B98
Waterboy2b98's Avatar
Drives: 11 2SS M6.
My 2011 SS grinds every time I shift into second about 3500 RPMs, sucks because its sounds like I cant drive a stick if I have to take off fast. Yall are lucky not to have issues. Dealer is not helping at all with issue. I will have to take this into my hands and change the fluid myself.
Waterboy2b98 is offline   Reply With Quote
Old 03-14-2012, 12:35 PM   #8
Nessal
Drives: Exige, Miata, Ghia
The problem with that video is that the guy mentioned that they use carbon syncros which isn't entirely true. From my understanding, only the 2012 had carbon syncros from factory and maybe even some very late production 2011. I'm sure they help relieve some of the grinding problems but a lot of people still have the grinding problems.
Nessal is offline   Reply With Quote
Old 03-14-2012, 02:54 PM   #9
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
Search- 2nd gear grind. Mine grinds only when the transmission is cold.
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 03-14-2012, 03:28 PM   #10
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
The grind issue does not seem to have a pattern as to what cars are affected, although it exists in the Challenger and Mustangs also, since they run the same manual tranny. Its probably not as big of a problem as the internet makes it out to be. But to those that have it? It sucks. Mine will be a little tempermental when cold, but I don't drive it in cold weather that much. My biggest concern was to try and get a smoother and faster shift into 2nd and 3rd at the drag strip. I have tried the Red Line D4 ATF fluid in the trans. with good results so far.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-14-2012, 04:41 PM   #11
Nessal
I wasn't aware that the Mustangs ran the same transmission. I thought it was the T56? I think the GT500 has the Tremec though right? The real question that I have are if the Viper guys are having this problem as I heard they use the same TR6060.
Old 03-14-2012, 05:36 PM   #12
TornadoSS
WICKDSS
TornadoSS's Avatar
Correct the Mustang GT500 has a tr6060. I pulled some info from wiki, so who knows how accurate it really is....http://en.wikipedia.org/wiki/Tremec_...n#Applications
Old 03-14-2012, 10:21 PM   #13
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
Mine works great under normal conditions, I put in royal purple tonite and it does shift better but a 1-2 at red line will still grind if I pull fast like old school, if I do normal semi-fast shift its always good. Guess its just the way it is.......
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 03-14-2012, 10:35 PM   #14
midnighter
Drives: nothing
WTB 2010 camaro ss service manual sherifdude Manuals, Literature, Workbooks, Brochures, Etc. 2 03-10-2016 12:19 PM
Stock SS Parts – AZ Available edneyens Local Marketplace 5 05-16-2011 08:58 PM
Camaro5 invites you to say thanks to Camaro assemblers and tour the Martinrea plant! Hylton 5th Gen Camaro SS LS LT General Discussions 646 12-23-2009 04:41 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 11:05 AM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 10:46 PM
