Emblempros
Old 03-13-2012, 03:33 PM   #1
asrautox
Drives: 2010 SS
10,000 Miles, is my clutch really starting to go??
I do a lot of city driving and the other day I took off agressively from a stoplight and noticed that my clutch slipped briefly then grabbed. At the next light the whole cabin was filled with burning clutch smell. Since then I've been really babying my take offs. Today I did a quick burnout and practiced my drag launch to get ready for the upcoming season (on private property), and the same thing happened. Brief slip, then go, then clutch smell. This will be my first season at the strip with this car and it is not normally driven very hard. Can it be that my clutch is already going out on me??
asrautox is offline   Reply With Quote
Old 03-13-2012, 03:36 PM   #2
Camaro21
Drives: SOLD - 2013 M6 ZL1
That's what it sounds like I am afraid to tell you..
Camaro21 is offline   Reply With Quote
Old 03-13-2012, 03:36 PM   #3
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Check your fluid, @ 10,000 miles I hope it has been changed once or twice.
Dirty fluid can cause it to have issues.
The Stock Clutch isn't that heafty of a clutch and doesn't take much to burn one out..
it is possible with spirited driving you'll finish the clutch off soon.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-13-2012, 03:42 PM   #4
asrautox
Drives: 2010 SS
The fluid has never been changed because frankly I've never heard of having to change clutch fluid early than 30,000 miles. 10,000 seems pretty short to me, but I'll be sure to go check it now.
Old 03-13-2012, 04:21 PM   #5
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
after seperating my brake/clutch fluid, I am changing it at every oil change. It is simple and easy and isn't a bunch of fluid.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-13-2012, 04:27 PM   #6
Ject
aka Patrick
Ject's Avatar
This
I've always heard and recommended every oil change to change clutch fluid.
Old 03-13-2012, 05:24 PM   #7
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
Originally Posted by Ject View Post
This
How do i change the clutch fluid?
Sent from my SCH-I510 using Tapatalk
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 03-13-2012, 08:22 PM   #8
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Old 03-13-2012, 09:02 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
http://www.camaro5.com/forums/showthread.php?t=34085
Add a separate resivoir. With this I change mine often...especially after drag racing. With as many times as i do it I'm sure it has already been flushed out. I probably need to start using DOT4.
It might be too late for your current clutch though. Upgrade to an LS9 clutch next time but they aren't cheap.
Build Journal
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
V6 w/ 12k miles clutch is out? bnorwood1 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 08-12-2011 11:30 AM
Celebrating 10,000 miles :) Embalmer 5th Gen Camaro SS LS LT General Discussions 57 02-26-2010 09:48 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
