HeadlightArmor
Old 03-13-2012, 04:20 PM   #1
EM1/SS
Drives: 11 2SS/RS M6 vert
radius rod bushing removal
What's the trick to getting the left radius rod bolt out? Do I need to remove the washer bottle?
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 03-13-2012, 04:22 PM   #2
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
yep that's what I had to do there are two bolts up on the frame rail. Just undo them and you should have enough clearance to pull the bolt out.
Old 03-13-2012, 04:31 PM   #3
EM1/SS
Thanks
Old 03-13-2012, 05:45 PM   #4
EM1/SS
That worked.
Old 03-14-2012, 09:07 AM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Old 04-22-2012, 11:13 AM   #6
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
how do u remove the ball joi.t
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You値l never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-22-2012, 12:14 PM   #7
Synner
Drives: not stock
Lots of rage and a really big hammer. Very tough on jack stands due to lack of leverage.
Old 04-22-2012, 12:46 PM   #8
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
and hit the tip of it? wouldnt that messin up the head?
Sent from my SCH-I510 using Tapatalk 2
Old 04-22-2012, 04:07 PM   #9
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Originally Posted by Comrando View Post
If you can have someone pry on it and then hit it once, it shouldn't mash it up. Big hammer and hit it with everything you've got.
The more times you hit it the more it will mash the stud.
ok i did this..not luxk i messed up the gead of the joint and the boot went up..does that mean ita ruined? thwre has to be a didderent tool to remoce these things then a pickle fork..??
Old 04-22-2012, 05:20 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
i give up..i cant get this thing off..im assunibg the boot can.be.put back since.it.moves up? all i wanna do is get the ball join off the.pxikke fork does not work
Old 04-22-2012, 05:46 PM   #11
Synner
Drives: not stock
You leave a nut on to clean the threads if you booger them up. But yeah you have to beat the snot out of it. Heating up the knuckle can help too. I was unable to do it on stands even with a 5lb hammer, needed to take it someplace with a lift so you could swing that hammer.
Old 04-22-2012, 06:00 PM   #12
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
unflortunetly i dont have any where to bring it.. so i need to do it here..the threads didnt mess up but the bottom of it sis where a socket fits i assume..i dont know.but car is.up on stands and i dont know.if the boot is ruined or if the boot goes back in please either
Old 04-22-2012, 06:46 PM   #13
Parag
Drives: 2010 camaro 2SS LS3
i like to use heat. and water to keep each part different temp
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 04-22-2012, 07:20 PM   #14
Synner
Drives: not stock
Boot is supposed to be sealed so probably jacked. I even bent a c-clamp from a ball joint removal kit so I said screw it. I was told an air hammer will do the trick but didn't feel like messing with it any more or buying a tool I'd never need again.
http://www.harborfreight.com/3x-air-...set-97857.html
FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP Info@PeddersUSA.com Suspension / Brakes / Chassis 4 08-25-2013 10:12 PM
BMR Radius rod bushing problem!!!! BAWLZ SS Suspension / Brakes / Chassis 8 10-24-2011 08:15 AM
Reinforce Your Oe Fr. Radius Rod Bushings Yourself Info@PeddersUSA.com Suspension / Brakes / Chassis 8 05-19-2010 11:52 PM
Front radius rod bushing removal tips? sting808 Suspension / Brakes / Chassis 3 05-12-2010 01:32 AM
