Old 03-13-2012, 06:48 PM   #1
EM1/SS
Drives: 11 2SS/RS M6 vert
Another radius rod bushing question
I just got my radius rods out. It was more of a pain in the @ss than I thought it was going to be. I have a set of Pedders inserts to install, but now as I look at them I wonder if I shouldn't get full replacements while I have them out.
I guess I'm wondering if the inserts are going to take the mush out of it. I'm going with full replacements for all the other bushings.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 03-13-2012, 06:51 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
what's the part number for the Pedders bushings? Only asking because I don't think they make just inserts, the bushing is tiny already to begin with.
Click to view my build thread
Old 03-13-2012, 08:37 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
The radius rod bushes are actually quite large. I have the full bushing replacement and i remember it took even the man himself (Justice Pete) some fighting to get the old one pressed out even a little more struggling to get the new one in.
The have the regular inserts and the HD inserts and the full bushing replacement which is what i had. I thing the inserts will tighten up the steering some but on the full bush replacement,
Pete clamped the radius rod in a vice with the new bush and told me to apply force to the other end.....no movement whatsoever. He did the same thing with the radius rod before with the OEM bush and it moved side to side at least 1/2 inch.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-13-2012, 08:39 PM   #4
BullF-16
BullF-16's Avatar
https://secure.merlinsoftware.com.au...rodCode=EP6577
https://secure.merlinsoftware.com.au...rodCode=EP6578
https://secure.merlinsoftware.com.au...rodCode=EP6579
Old 03-13-2012, 09:00 PM   #5
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
I was skeptical of the radius rod inserts too when I saw them, but the improvement is noticeable.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 03-13-2012, 09:17 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here is some info on the radius rod insert and yes Pedders does have them. It's best bought with their Stage 1 Street kit so you get a small discount.
http://www.camaro5.com/forums/showth...ght=radius+rod
I ended up having full bushings put it but not that I was really disappointed in the insert but more of a...while I was at the shop kind of thing. If you have a press it's not all that bad but it's definately more of an install than just the insert.
Build Journal
Old 03-13-2012, 09:17 PM   #7
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-14-2012, 11:38 AM   #8
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
A press will make removing the factory trailing arm bushings a snap. Just find the appropriate sized socket and push it on out.
With our front trailing arm sphericals the reinstallation is a breeze. Just clean up the bore of the arm of any left over pieces of the factory bushing, put on the supplied LocTite retaining compound, slide the bearing in place and install the snap ring. Instead of pressing in a firmer piece of polyurethane that will bind during normal operation of the arm, we replace that bushing with an ultra low deflection spherical bearing. This bearing will allow the arm to freely rotate how that arm was designed to in the factory rubber bushing, but eliminate deflection to help braking and steering response. We know these are going to be installed on street cars, so we use a heavy duty teflon lined bearing for these spherical bearings to prevent any extra noise from being transmitted to the cabin.
Old 03-17-2012, 02:14 AM   #9
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Put the inserts in. Pedders guarantees your satisfaction. Call me if you are anything less than very pleased with the result.
FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP Info@PeddersUSA.com Suspension / Brakes / Chassis 4 08-25-2013 11:12 PM
Pedders Radius Rod Bushing Inserts JohnZ Suspension / Brakes / Chassis 2 01-06-2012 10:53 PM
Pedders Radius Rod Bush Rich D Suspension / Chassis / Brakes 0 08-05-2010 01:58 PM
