Old 03-13-2012, 09:47 PM   #1
gorgeous-ss
Drives: 2011 ss/rs
l99 auto trans fluid change(need help)
ok i might just be a little slow today but where is the fill and drain plugs on the auto trans
gorgeous-ss is offline   Reply With Quote
Old 03-13-2012, 10:05 PM   #2
gorgeous-ss
Drives: 2011 ss/rs
amyone?
Old 03-14-2012, 07:39 AM   #3
silver ice 2011
silver ice 2011's Avatar
Drives: 2011 camaro tsp stage 3 vvt
the trans is not a sealed unit the plug at the bottom is where you check level it should just trickel out when full the fill plug is on the driversside top left
LS3KLR
silver ice 2011 is offline   Reply With Quote
Old 03-14-2012, 08:17 AM   #4
silver ice 2011
THANKS TO A JACK WAGON AND YOU KNOW WHO YOU ARE THE PLUG IS ON RIGHT NOT THE LEFT SORRY ABOUT THE MISS GUIDED INFO
LS3KLR
Old 03-14-2012, 08:26 AM   #5
gorgeous-ss
Drives: 2011 ss/rs
So how do you drain it completly without taking the pan off
Sent from my Eris using Tapatalk
Old 03-14-2012, 11:06 AM   #6
gorgeous-ss
Drives: 2011 ss/rs
Bump
Old 03-14-2012, 03:17 PM   #7
gorgeous-ss
Drives: 2011 ss/rs
Anyone have the service Manuel or have done this can u tell me?
Old 03-14-2012, 03:22 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Name:  New Picture.jpg
Old 03-14-2012, 03:26 PM   #9
gorgeous-ss
Drives: 2011 ss/rs
Ok but to drain it completly I would have to drop the pan correct?
Old 03-14-2012, 03:29 PM   #10
PQ
Booooosted.
PQ's Avatar
Correct.
Unless someone has a shade tree trick to do it. But then no way to know if all the sludge is out.
I've already looked into it. Pretty much decided to leave it alone for now. I'd like to change the fluid out.
Old 03-14-2012, 04:09 PM   #11
gorgeous-ss
Drives: 2011 ss/rs
Thanks for the help looks like I'm dropping the pan today
Old 03-14-2012, 04:15 PM   #12
PQ
Booooosted.
PQ's Avatar
Please come back and post how it goes. I might do the same.
Old 03-14-2012, 09:45 PM   #13
gorgeous-ss
Drives: 2011 ss/rs
It was actually fairly easy just opened fill plug and test plug then loosened all bolts and removed all except 1 on each end took one end off and it dropped onto the loose bolt on the other end.
Drained as much as I could that way then took last bolt off and laid the pan on the ground took pan out cleaned it and the magnet
Then put back together and filled
How to Take Care of Your Clutch The Stig V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 10-25-2011 08:46 PM
Trans almost fixed dealer out of manual trans fluid? Dexgto V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 09-18-2011 05:54 AM
Have You Changed Your A6 Trans Fluid? JDP Sales V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 08-11-2011 09:53 AM
Camaro does the Nurburgring test track in 8:20 2sharp 5th Gen Camaro SS LS LT General Discussions 45 07-23-2008 04:17 PM
