Jason 98 TA
Old 03-13-2012, 10:25 PM   #1
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Drives: 2010 Victory Red 2/SS
Richmond Gear Howling
Hello.
I'm getting a howling sound from my drive train rear when ever I accelerate or decelerate at cruising speeds. I'm not sure if this has been going on long but I'm pretty anal with my car and it's sounds so I usually pick up on these things pretty fast. I've modded the heck out of it so I'm pushing around 620ish rwhp with an auto and Nittos. Everything shifts well and no other issues other than the howling. Can anyone offer me any advice as to my problem? I added the Richmond 3.73's after we finished the modding. That was about 2 years and 6000 miles ago. Any advice on what to do or check to see if this is something mundane or am I probably looking at time for new gears or worse due to pushing the limits on a OEM drive train?
Thanks.
Pitttbulll is offline   Reply With Quote
Old 03-14-2012, 12:36 PM   #2
Nessal
Drives: Exige, Miata, Ghia
There was another person on here that has this same problem but cant dig up the thread right now.
Nessal is offline   Reply With Quote
Old 03-14-2012, 12:39 PM   #3
Indpowr
Drives: Corvette C6
I had that issue a long time ago. Put in non synthetic and it was much quiter.
Normal to have a little IMO.
Old 03-14-2012, 01:34 PM   #4
bmorecam
I heard richmond gears are noisy gears to start with. I was going to do richmond but I am so glad that I got steered away to lingenfelter, the same company that make gears for LPE is the same company that make factory gears for the camaro.
Old 03-14-2012, 01:54 PM   #5
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Are you sure its the gears? If so, it could be an install issue. I have almost 2 years and 28K miles on mine with no issues. Mine have held together fine and still make no noise.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 03-15-2012, 07:10 AM   #6
Pitttbulll
Pitttbulll
Pitttbulll's Avatar
Thanks for the input.
I talked to my speed shop that did the install and I'm taking it there to have it looked at and evaluated.
I've been wanting to do a little more tweeking and upgrading the torque converter so this seems like a good reason to do that while they check the "howling" situation.
Thanks.
Old 03-15-2012, 09:35 AM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Put Richmond gears my LS1 Z28 and I could never get them quiet. I had one of the best installers in the area work on them and they were still very noisy. I ended up swapping in some gears from an M6 (GM gears) and they were whisper quiet.
So it was the gears and not the installation.
Old 03-15-2012, 10:41 AM   #8
MA2010SS
Drives: 2010 Camaro SS
I have the richmond 4.11's from JRE along with the urethane bushings which resonate the sound more than the rubber bushings would, I also have the whine. I've put about 1200 miles on this rear end and I have changed the diff fluid 7 times. Valvoline twice, Mobile, Penzoil, Royal Purple, Redline shock proof, and finally Lucas. All of the oils were non synthedic except for RP and Redline, all of the weights were 85w x 140w except for Redline that was 250W. The quietest oil that seemed to work was the Lucas, RP and Redline did not last more than 10 miles each before I changed them out. The worst was the Redline, noise all the way through any speed. All oil changes I made I also added 1 pint of Ford friction modifier. Just thought I would share my experiences with you guys.
Cheers!
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 03-22-2012, 12:36 AM   #9
fldrummer
"Black Ace"
fldrummer's Avatar
'Guess I'm just one of the lucky ones.
Old 03-27-2012, 10:40 AM   #10
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Make sure the installer has a housing spreader for installation. Next time add an LPW differential cover with the torque bolts. I had four rear ends built before I got rid of the howl with the LPW cover.
nuptualnemesis is offline   Reply With Quote
LPE gear vs Richmond gear Superbad Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 02-29-2012 04:31 PM
Top Gear host Richard Hammond to get own car show on BBC America. Apex Motorsports Off-topic Discussions 11 07-26-2011 11:04 PM
not enough v6 with gear upgrade bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 58 03-08-2011 10:03 PM
Richmond gear 1/2 install kit AG454 Transmission / Driveline 7 07-10-2010 01:37 AM
Does any 6 speed owners see a need for a gear indicator? OHIOSS 5th Gen Camaro SS LS LT General Discussions 98 10-13-2009 09:36 PM
