Old 03-13-2012, 11:54 PM   #1
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
H&R springs sag in rear?
Ive got H&R sport springs installed. had them for 2 years now. car has 8k miles on it and the rear seems to keep sagging. they are suppose to be 1.4" drop front and 1.3" drop rear. but im getting 1.3" front drop and 2.3" rear drop.
whats it look like to you?
I contacted Tirerack where i bought them and they sent out a reply saying to check to make sure all the springs were in the upright position and in the right location. asked for before and after measurments, and pics of the side view of the car. hope they can help me out. im sitting at 660mm in the front and 641mm in the rear. measureing from the bottom of the rim to the center of the fender
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 03-14-2012, 02:03 AM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Looks like you may have cut your rear bump stops and you weren't supposed to. Did you?
SUX2BU is offline   Reply With Quote
Old 03-14-2012, 08:42 AM   #3
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
it was 2 years ago. I remember cutting 2 of them per the install instructions. but couldnt tell you what ones they said to cut. I'll look into it
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 03-14-2012, 10:44 AM   #4
Rich@BSP
Drives: wife says to many
The chassis sits on the springs not the bump stops.
Rich@BSP is offline   Reply With Quote
Old 03-14-2012, 10:59 AM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
The bump stops will not effect static ride height. As mentioned above the chassis is supported by the springs themselves, the bumpstops are there to provide a cushion between the body of the shock and the fork to prevent the strut assembly from bottoming out suddenly.
Don't worry about it being a bumpstop issue. If the car keeps getting lower there is something else at play here.
Old 03-14-2012, 04:52 PM   #6
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
im waiting for a responce from tirerack about the problem. will update once they tell me what to do.
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 03-14-2012, 10:11 PM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
If the car has been that low ever since you installed the springs then they may have lowered the car too much. If it has gotten progressively lower over the last two years then the springs may just be sagging. This happens with low quality springs.
I've installed hundreds of lowering springs on dozens of different type cars. There have been a few cars (mine included) that the springs lowered the car so much that it actually sat on the bumpstops. Therefore, if you cut the bumpstops that the car is literally sitting on, guess what happens? The car goes even lower.
Here is a couple of pics to prove my point.
Before cutting bumpstops
AFTER cutting bumpstops
Old 03-15-2012, 10:30 AM   #8
Rich@BSP
If your car is setting on the bump stops your handling sucks and is not safe. You should be setting on the springs and have the struts or shocks control josue.
Old 03-15-2012, 10:38 AM   #9
Atti2de
Móderator
Atti2de's Avatar
Drives: 2SS/RS
I have had H&R springs to almost two years with no problems. I know not much help...
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
Atti2de is offline   Reply With Quote
Old 03-15-2012, 10:42 AM   #10
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I'm pretty sure he corrected this issue. I dought he's ridding around sitting on the bump stops (lets hope not). That would be a very rough ride. I think he was just showing the pictures to demonstate what the O.P. is describing.
Old 03-15-2012, 06:46 PM   #11
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
whats your rear ride height from the bottom of the wheel to the bottom of the fender? my rear sits lower than the front.
H&R asked if i had cut the rear bumpstops and if so how much i cut. It was 2 years ago and i dont remember. I told them i followed their instructiions and if it said to cut them then i must have but am not certain. does H&R install call for cutting rear bumpstops?
Then they wanted to know the gap between the center of the wheels center cap to the fender lip on all 4 corners. my ride isnt rough, my rear end is very bouncy and doesnt bottom out. i dont think bumpstops are the issue, i think the springs are crap
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 03-15-2012, 07:45 PM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The issue was corrected the same day. I just posted those pictures to show you and PfadtRacing that these cars do in fact sit on the bumpstops when you lower them too much.
The rear end is very bouncy because it is sitting on the bumpstops. That is how my car felt before I cut the bumpstops.
ANY car lowered as much as mine in that first picture IS sitting on the bumpstops if they weren't cut. That WILL give you a bouncy ride. That is why i recommend 1.0" to people.
Old 03-15-2012, 07:57 PM   #13
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
I can push the rear down with ease even with it sitting so low. It hasn't always been this low. I think its gotten worse over time. No comparison to my buddys detroit speed springs. Even with almost the same drop rate. But his isn't sagging
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 03-15-2012, 08:14 PM   #14
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
the day i installed the springs the rear dropped 1.5" since then its dropped almost another full inch. maybe it is riding on the bump stops, but that would only mean the springs themself are the problem right? its not suppose to drop that much with the springs i have
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! Apex Motorsports Suspension / Chassis / Brakes 273 04-25-2016 06:17 PM
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
H&R SPRINGS 1.4 F 1.3 R..... Moayyed LS3 Suspension / Brakes / Chassis 8 09-04-2011 04:22 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
