JDP Motorsports
Old 03-14-2012, 12:46 AM   #1
thebigassbear
thebigassbear's Avatar
Drives: 2011 camaro 2SS manual
Solo Hi-Flow Installation
I cant get the bolts off connecting the manifold to the cats......i sprayed them with WD40 hoping that it will help loosen them up later. What was easiest for you guys and what size drive ratchets and extensions did you use
thebigassbear is offline   Reply With Quote
Old 03-14-2012, 01:16 AM   #2
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
let me know how the installation goes. My Solo High Flows are coming in tomorrow.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs, Tuned by Rhino79 at GPI.
rberns is offline   Reply With Quote
Old 03-14-2012, 01:18 AM   #3
thebigassbear
well right now its horrible haha
Old 03-14-2012, 01:34 AM   #4
rberns
rberns's Avatar
haha, I suppose it is. I am thinking about having someone else do it. I have little patience when things aren't going smoothly.
Old 03-14-2012, 04:48 AM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
You aren't trying to remove the studs from the stock mid pipes are you?
A soaking with PB Blaster and letting it sit for a while can help with removing the nuts.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-14-2012, 06:57 AM   #6
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
i used every extension I had and a LONG breaker bar to get enough torque on those suckers. thought I was going to break my ratchet.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-14-2012, 07:51 AM   #7
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
I took mine apart for shipping when I sold them. I don't remember it being that bad. Try spraying liquid wrench or some other brand of penetrating oil.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 03-14-2012, 01:25 PM   #8
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
you will want a good 24" breaker bar. I just used my torque wrench, which was about that length I think. I also had a 18" extension to reach down into the engine bay and a swiveling joint before the socket to reach the back bolts. You'll get it. I have no car experience at all and I got it done.
Believe it or not, the hardest part is removing the O2 sensors... go to Oriley auto parts and get a free loan (just need CC for deposit) of a O2 sensor socket (if you don't, you will have to use an open end socket) and use the same breaker bar to remove the sensors. Also buy some anti seize lubricant for the threads when you put the O2 sensors back on...
Oh and I also used PB blaster on the O2 sensors because even with the breaker bar they were not budging because they had seized... I had to replace one sensor @ $70-$80. Don't use a hammer.
cab2g is offline   Reply With Quote
Old 03-14-2012, 03:43 PM   #9
rberns
rberns's Avatar
I just got my Solos in today. I thought they were going to be marked left and right, but I think I can figure it out that the O2 sensor tilt in towards the center.
Old 03-14-2012, 09:18 PM   #10
mtbikerinme83
mtbikerinme83's Avatar
Drives: IMB 2SS/LS3-M6
I just did this install a couple weeks ago. The O2s were easy with the car hot. As far as the OP's question, once I had the right tools, it was easy. First, have the car heated up. Then hit the nits with PB Blaster. Using about 2ft worth of 1/2" extensions, a swivel, and a breaker bar, they broke free and then I used a ratch to get them off the rest of the way. For one of the nuts, it didn't break free of the stud before the stud started to wind out of the factory midpipe. This is no big deal, and once out, I took care of it off the car. The key is having enough extensions to get clear of the engine. I tried everything, every angle and every different socket, wrench, ratchet.... that I had and nothing would work until I went and borrowed anouther extension to get be up by the cowl and clear of the engine so I could hold the extension and put some weight into the breaker bar.
Hope that helps.
IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 03-14-2012, 09:42 PM   #11
thebigassbear
well i finally got the front ones off (one of the nuts started to warp and strip so i had to jam a smaller socket on) now i just need the right extension and a 1/2 swivel socket.....everytime i get a step closer im missing a tool haha but it sucks cause i live 30min from the closest shop
Old 03-15-2012, 12:54 PM   #12
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
trust me I feel your pain. I had my cats off and couldn't get the O2 sensors off so I had to ride my bike to the auto parts store. It was pretty funny actually. But since I took the day off work, I had skipped working out already, so the bike ride was some good exercise.
Old 03-15-2012, 01:02 PM   #13
thebigassbear
well i got mine put in havnt driven it around yet but finally got it
Old 03-15-2012, 04:50 PM   #14
thebigassbear
So I got a CEL I'm guessing it might be wd40 in the pipes or i have messed up the wires on the O2 sensors....thoughts any1?
Solo hi flow cat question 2012REDSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 01-17-2012 07:39 AM
F/s solo high flow cats ls3 kcox2010 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 01-15-2012 07:46 PM
F/S Solo Performance high flow cats ssmike V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 18 06-20-2011 02:03 PM
Solo High Flow Cats Installed Strokedhog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 08-08-2010 02:42 PM
NEW High Flow Cats COMING SOON from SOLO Performance GOINGSOLO2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 414 07-24-2010 05:55 PM
