JUICEDMOTORSPORTS
Old 03-14-2012, 07:46 PM   #1
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
What to do about exhaust pipes squeaking?
I checked them on a lift and sure enough its the pipes. The mid-muffler doesn't lay flat on the center brace anymore since I added the axle-back and headers so the whole thing sways( I believe) when I make turns causing it to squeak. If anyone has had this problem or just has some ideas on what I can do to help support the pipes better I'd appreciate it. Maybe tac some hang-out to the pipes or shim the center brace to support the mid-muffler? Thanks.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 03-14-2012, 09:04 PM   #2
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
exhaust shouldnt touch center brace may cause KR and a loss of power. Try loosening catback joints and lifting with a floor jack in the center and re-tightening the exhaust joints to raise it.. If you do not get .5" of space you may want to try adding some spacers to your brace. :-)
The 2010 Sin is offline   Reply With Quote
Old 03-14-2012, 10:01 PM   #3
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
+1 to the last post...I lossened everything while the rear was way in the air, put a small jack with a peice of wood under where the brace is. Jacked it up about an inch and and tiightened everything up... However, once I went to 3" pipes, I did away with the tunnel brace all together. i have not noticed any ossues what so ever by removing it.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-14-2012, 10:27 PM   #4
The SwiftChancelor
I still have the stock resonator from the L99 and I know its fairly heavy but its not resting on the center brace anymore. Maybe the weight of the resonator is playing a part the squeaking sound. I plan to have a resonated x-pipe installed in its place do your think this will help?
Old 03-14-2012, 11:11 PM   #5
jcollins91106
Drives: 2010 2ss m6
a new x pipe will help alot...that stock resonator is a freakin beast...the new x pipe will allow the system to be more flexible and will stay in place better when torqued down
Old 03-15-2012, 12:43 PM   #6
The SwiftChancelor
Cool, thanks for your input.
Old 03-15-2012, 04:34 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The point is, it should have NEVER rested on the tunnel brace. There should be a large enough gap to keep it from resting or even hitting the tunnel brace. If it's squeaking, something isn't tight enough. If it's "thumping" when you drive on bumpy roads, it's hitting the brace. Each has a different fix.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-15-2012, 06:41 PM   #8
The SwiftChancelor
No thumps it just squeaks. I tightened everything the other day and it still squeaked. I'm positive its the exhaust system, from headers to tips. You can shake the pipes right after the cats and before the resonator and it makes the exact same squeaking sound. Hoping after installing the x-pipe that it will make a difference. Like others said I may have to loosen the clamps and jack up the center pipes and then tighten up the clamps.
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 557 12-19-2017 04:31 PM
Back pressure and the camaro... SS>GT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 12-03-2012 04:39 PM
Thinking about going 2.5" the entire System mike.nite Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 01-11-2011 04:57 PM
Black soot in exhaust pipes? rolnslo Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 24 08-18-2010 11:07 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 07:39 AM
