Old 03-14-2012, 10:56 PM   #1
byrosol
Thunderclap
byrosol's Avatar
Drives: 2010 Camaro SS IBM (LS3)
Time has come to put on exhaust
Hello everyone, the time has come for me to throw on my exhaust this weekend.
It is a Magnaflow Catback exhaust 16580. I'm putting it on my IBM 10 SS LS3 Camaro.
I'm posting just in case if anyone had tips for me this weekend.
I will be doing this myself with a couple friend's help. From what I see on the install sheet, it doesn't look hard at all. The hardest part looks like removing the factory exhaust, but I could be wrong.
I'm taking my car to a hobby shop which has all the necessary tools and lifts.
Anyone have any input?
Thanks in advance.
Byron
byrosol is offline   Reply With Quote
Old 03-14-2012, 11:57 PM   #2
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
You are correct about the hardest part. The stock cat back comes off in one piece. It's rather heavy and akward. Spray the rubber exhaust hangars with some soapy water. It makes them much easier to slide them off. Especially the rear ones above the mufflers. It a bit of a tight fit reaching up there. When do the install make sure you get all the parts fitted together loosely and push up on the front to make sure you clear the plate which goes under the pipes. You can also check in the DIY section of the forum. I'm sure there are several exhaust installation threads with pictures.
bpoirier is offline   Reply With Quote
Old 03-15-2012, 12:38 PM   #3
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
That was the only thing that I could think of as well.
Old 03-15-2012, 01:16 PM   #4
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
You said it very well - just throw it on.....EZ!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 03-15-2012, 01:29 PM   #5
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
WD-40 is also an excellent alternative to soapy water on the rubber hangers.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 03-15-2012, 02:45 PM   #6
byrosol
Thunderclap
byrosol's Avatar
Ok thanks everyone, I will keep that in mind.
Old 03-15-2012, 04:26 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's a couple DIY's in that section. A quick search in that section should bring them up.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 05:11 PM
MRT v2 Installation + tips. mypuppysirius Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 34 03-14-2012 08:15 AM
SOLO Performance Camaro CONVERTIBLE Cat-Back Exhaust Kit GOINGSOLO2 V8 Bolt-Ons & Tunes 18 12-20-2011 07:17 PM
How Much Faster ...... shockandawe Camaro ZL1 Forum - ZL1 Specific Topics 119 10-29-2011 09:11 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 02:20 AM
