Emblempros
Old 03-15-2012, 07:48 AM   #1
jlanc20
Drives: 2010 Synergy Green Chevy Camaro
Looking to lower...need aligned? camber kit?
I was looking to lower my camaro one inch, im looking to order just the lowering springs but wasnt sure which is the best out there? I was also wondering if i will need to get the wheels re-aligned and would i need to buy a camber kit to straighten the wheels back up vertically? I lowered my last car 2 inches and it kicked the rear wheels out so i had to buy a camber kit...thanks for the help!
jlanc20 is offline   Reply With Quote
Old 03-15-2012, 08:51 AM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
You will need an alignment. You have to dis-assemble the suspension to install the springs. I had MTI put their 1.25 drop springs on mine and they had no problem with re-aligning it to factory spec. Any lower though, and I would be looking at getting a full alignment bolt kit. I'm going to get mine through Pedders this summer because I want a performance oriented alignment and the factory bolts with a drop most likely won't allow it.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-15-2012, 08:53 AM   #3
Eric59
Drives: 2013 Summit White 1LE
Once you install the springs you will have to time the bushings and have the alignment adjusted for the new ride height.
Mods: RX catch can, ZL1 Rockers, ZL1 Grill, ADM Race CAI, OBX 1 7/8 headers, tune
Eric59 is offline   Reply With Quote
Old 03-15-2012, 10:50 AM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Our springs offer a 1.25" drop in ride height, unless you're looking to specifically add caster adjustment you will not need a camber kit or any extra alignment hardware to achieve a performance street alignment. Here is a copy of our alignment spec, a good alignment shop shouldn't have any problems at all achieving our Performance Street settings. This will offer you increased handling over the factory alignment, with minimal impact to tire wear.
Old 03-15-2012, 04:46 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I can vouch for the Pfadt street performance specs. I just rolled over 22k miles on my stock Pirelli's and there's still some tread left. Obviously I don't do a lot of burnouts but that should tell you that the settings aren't hard on your tires.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-16-2012, 01:12 AM   #6
jlanc20
Alright thanks this has helped alot!!
Old 03-17-2012, 02:41 AM   #7
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
You will absolutely need to align your Camaro after it is lowered. It is essential that you also time your bushes.
Bush Timing
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
To reach ZERO rear camber with lowering coils, you will need Pedders eXtreme Range Rear Camber Eccentrics. PDUSACAMREAR You will be able to align to the OE spec green range without them.
Here are the newest FE2, FE3, FE4 and FE5 OEM and Pedders Alignment Specs.
When selecting lowering coils for your 5th Gen I suggest you search around a bit and base your buying decision on trouble free lowering coils with great customer service before, during and after the sale.
Old 03-17-2012, 09:12 AM   #8
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
I thought the front caster is fixed and can't be adjusted, is this correct. If so, what is needed to get the caster to max out?
ssmike is online now   Reply With Quote
Old 03-17-2012, 09:55 AM   #9
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
Pedders make a cam bolt kit that uses the factory mounts for the caster adjustment,you must slot the hole then replace the factory bolt with the Pedders cam bolt.Then adjust away.
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-17-2012, 11:41 AM   #10
ssmike
BliSSard has come!
ssmike's Avatar
That's what I thought. So without the cam bolt your stuck with the factory castor setting. What's the price for the cam bolt?
Old 03-17-2012, 11:43 AM   #11
ssmike
BliSSard has come!
ssmike's Avatar
Bush Timing
Front:
---Inner Radius Rod
Rear:
Step 3.
Step 4.
Step 5.
Pete, do you have this in pdf form? I have the older one and it's a little different. I'm bringing it in for alignment the week after next! Also, can you add a note under #5 above that mentions the need for the Pedders cam bolt for front caster adjustment to be able to reach the spec of 8 in the agressive street spec? Thanks!
Old 03-17-2012, 01:01 PM   #12
JusticePete
VIR Specialist
I'll get a PDF version posted soon
You can pull them down as images from these links
http://sphotos.xx.fbcdn.net/hphotos-...83453935_n.jpg
http://a5.sphotos.ak.fbcdn.net/hphot...90132396_n.jpg
Old 03-17-2012, 01:08 PM   #13
ssmike
BliSSard has come!
ssmike's Avatar
Thanks!
alignment, lowering, suspension
Pedders xa's coilovers(track II kit) and Pfadt camber plates SSambumbia Suspension / Brakes / Chassis 18 02-16-2011 11:03 PM
Rally Stripe Kit Install (Aftermarket) JoeKay Camaro DIY & HOW-TO instructions & discussions 4 09-29-2010 07:13 PM
Finally finished picking my Suspension mws444 Suspension / Brakes / Chassis 38 06-04-2010 02:02 AM
Best prices on Eibach pro-kit springs & question on camber adjuster kit topgun1 Suspension / Brakes / Chassis 4 10-14-2009 07:00 PM
