BeckyD @ James Martin Chevy
Old 03-15-2012, 04:09 PM   #1
EM1/SS
Drives: 11 2SS/RS M6 vert
Question on lowering the diff to replace bushings
I'm dropping the rear end housing to replace the Diff bushings and have a question on drive shaft removal. I've got the three 18mm bolts off and there is a pilot shaft inside the drive shaft. The directions say to use a pry bar and move the drive shaft forward and lower it. I've pryed on it a bit and it seems to bottom out just as it's about to come off the pilot shaft. I don't want to pry too hard and break something? Do I just put a little more into the pry bar and get it off the pilot shaft?
Thanks
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 03-15-2012, 04:33 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If you remove the carrier bearing mount bolts it will give you a little extra room to allow you to get the clearance you need to slide the driveshaft past the pilot shaft.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 03-15-2012, 05:13 PM   #3
EM1/SS
Are the bolts your talking about the ones that hold the flex joint to the drive shaft?
Old 03-15-2012, 08:47 PM   #4
EM1/SS
I figured out the carrier bearing and got the drive shaft out.
Thanks
Old 03-16-2012, 03:49 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks
No problem. If you have anything else I can help you out with let me know.
T.C. Davis
813-986-9302
Question about alignment parts when lowering the car moultron Suspension / Brakes / Chassis 2 03-01-2010 06:31 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
Frontal lowering question... nUcLeArEnVoY Suspension / Brakes / Chassis 4 10-15-2009 11:24 AM
Lowering springs question newgenss Wheels and Tires Talk Sponsored by The Tire Rack 14 09-07-2009 01:46 AM
MXO/REAR DIFF QUESTION PoleCat2SSRS2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 02-24-2009 08:57 PM
