JDP Motorsports
Old 03-15-2012, 06:28 PM   #1
gorgeous-ss
Drives: 2011 ss/rs
Stainless works headers
Ok so I just picked up my stainless works headers and in the package it comes with high temp rtv for sealing between headers and head face.
Would it be better to use this or the new manifold gaskets that I bought?
Also I'm going to be running catless midpipes but it comes with the port for the 2nd o2 sensors. Should I install the o2 sensors or should I plug the hole?
Sent from my Eris using Tapatalk
gorgeous-ss is offline   Reply With Quote
Old 03-15-2012, 06:46 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I never heard of using RTV on headers!!! I wouldn't use it. Instead use only factory GM manifold gaskets. Some folks re-use the original without any problems. The seal better than any aftermarket gasket.
blazzin1 is offline   Reply With Quote
Old 03-15-2012, 07:06 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I recommend swinging buy your local Chevy dealer and picking up new gaskets.
Old 03-15-2012, 07:08 PM   #4
gorgeous-ss
Drives: 2011 ss/rs
yea i already have gaskets just wanted to ask lol umm how about the o2 sensors?
Old 03-15-2012, 09:41 PM   #5
gorgeous-ss
Drives: 2011 ss/rs
Bump for 02 sensor question
Old 03-15-2012, 09:50 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What about them? They should be reinstalled using antisieze.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-15-2012, 09:51 PM   #7
ss/rs-matt
ss/rs-matt's Avatar
Drives: 2011 2SS/RS LS3
If you get a tune they will be deleted anyway, but if you plan on not getting tuned for a while throw them in. You'll hopefully delay the enviable CEL.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
ss/rs-matt is offline   Reply With Quote
Old 03-15-2012, 10:40 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
The rear O2 sensors will get turned off by a tune but you should still install them. Especially since you have the whole already there. Basically it's a place holder. Somewhere to put them instead of just hanging there. By installing them you'll also be plugging up the whole in the cats.
I would recommend un-plugging them from the stock plug, install them, and then plug them back in. If you don't the wires will get all twisted up from screwing them in. Then zip tie the execess wire out of the way.,
Build Journal
Old 03-16-2012, 07:01 AM   #9
gorgeous-ss
Drives: 2011 ss/rs
Ok one last question lol sorry
When you get headers ceramic coated do you have them do the midpipes?
Old 03-16-2012, 07:50 AM   #10
gorgeous-ss
Drives: 2011 ss/rs
Ttt
Old 03-16-2012, 08:33 AM   #11
MikeOD
Drives: 2010 M6 2SS
It's up to you really...I've seen show cars with the entire exhaust coated, and my car has nothing coated...and anywhere in between. I wouldn't say there's really a right or wrong answer there. I wouldn't expect the coating to last under the car on a daily driver though.
The only thing I suggest to people with header gaskets, is to make sure the header flange is very flat and clean before you install them. Usually they're great, but if you know any machinists, ask them if they have a stone you can borrow for 5 minutes...a very flat stone that a machinist would use to clean a table in a mill, or the bottom of a vice, when rubbed in circular patterns on the flange of the header will make sure it's flat and free of burrs before you install it. I've always done that and run GM gaskets, and I've never had a leak.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-16-2012, 10:20 AM   #12
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
I have the Stainless Works Power LT headers with the catless mid-pipes so the set-up
for what I've read is nearly identical. I re-used my factory GM gaskets and didn't touch the sealant. I did use the bolts they provided. I also installed the second o2 sensors into the catless pipes, why not? It doesn't hurt anything and makes it look legit, I'd rather have it plugged in than just some loose wire I'd have to tie up. Oh, and I didn't coat.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 03-16-2012, 11:50 AM   #13
gorgeous-ss
Drives: 2011 ss/rs
Thanks everyone for your help
Old 03-16-2012, 01:49 PM   #14
caverman
caverman's Avatar
With LTs there really isn't a mid-pipe. It's the header, then the cat (or off-road pipe), and then the cat-back.
Just coat the headers. Don't bother with the cats. Actually, I'm not even sure you could coat the cats without messing them up. Either way, unless you're going for and all out show car where you never drive it and want to show off the underneath of your car, just coat the headers.
Build Journal
Stainless Power by Stainless Works V8 Camaro Headers w/AIRAID CAI Xplosive Performance V8 Bolt-Ons & Tunes 1 11-22-2011 07:29 AM
GROUP BUY! Stainless Works Stepped Headers 15% Off For Camaro5 Members At APEX!!!!!! Apex Motorsports V8 Bolt-Ons & Tunes 2 01-10-2011 07:21 PM
Stainless Works Headers w/BMR Sub Frame Connectors Xplosive Performance V8 Bolt-Ons & Tunes 1 01-08-2011 10:23 PM
Stainless Works Headers and Exhausts - 4 Day Sale! tbyrne V8 Bolt-Ons & Tunes 7 11-29-2009 03:53 PM
