Jason 98 TA
Old 03-15-2012, 07:59 PM   #1
ccrognlie
ccrognlie's Avatar
Drives: 2011 Camaro 1SS Black on Black
LS3 Cam Worth it or Not
So here is the questions I have before I drop the cash and I figure you guys are the experts more so than I.
1) Is a cam worth the Money
2) Will reliability suffer from installing one.
3) Anybody have any issues after installing one.
4) How big is enough?
I'm doing long tube headers, hi flow cats, and a cam kit and I'm having a local trusted shop installing these and sounds like the car will put up some pretty good dyno numbers..
Thanks for any info u guys can give..
Chad
K&N Typhoon CAI, Flowmaster AMT 3" Cat Back, 22" Giovanna Kilis Wheels, BMR Split Drop Lowering Springs, Marker & Brake Light Tint,
ccrognlie is offline   Reply With Quote
Old 03-15-2012, 08:10 PM   #2
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
It all depends on what you want out of your car. If you are looking for a big HP number, put in a big cam, ported heads and all the other mods you mentioned. If this is a daily driver, you need to find a balance point between HP and driveability. Figure out your goals, then call some of the vendors here on C5. They will be happy to talk about your options. I would suggest talking with Andy at ADM. He has a great reputaion and is the only person I would trust for this kind of work, but I'm sure there are lots of other very qualified shops represented here on C5.
Good luck with your project.
stso634 is offline   Reply With Quote
Old 03-15-2012, 09:09 PM   #3
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
Call up lethal racing good shop and great customer service their goin be doin my work in the next month. But in my opinion if you doin a cam swap don't go with am ls3 cam.
InfernoSS454 is offline   Reply With Quote
Old 03-15-2012, 09:20 PM   #4
TORKED
Pick a "streetable" cam kit. Livernois Motorsports has what u need and coined "2C." I have that set up with a CAI, long tube headers, 3" mid-pipe and 3" flow masters...that's it. 464 rwhp. F-ing LOVE it. Great chump-chump-chump at the stop light.
There are plenty of places to get what you want, but I recommend getting tons of technical information before you tear into a an installation.
TORKED is offline   Reply With Quote
Old 03-15-2012, 09:22 PM   #5
InfernoSS454
Is that through a manual.
Old 03-15-2012, 09:26 PM   #6
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
I'm betting it is...
The OP hasn't stated whether he has an LS3 or L99 yet..
just says he want's an LS3 cam which could go in either engine. Makes a difference...
Old 03-15-2012, 09:29 PM   #7
ccrognlie
ccrognlie's Avatar
AM LS3 Cam?
Old 03-15-2012, 09:34 PM   #8
mikeSS
mikeSS's Avatar
Drives: 2015 c7
the reasons why i say reliability will suffer little. is because you cant just go to your local chevy dealership for work. and i wont trust half the dealerships to work on my cammed camaro.
Old 03-15-2012, 09:38 PM   #9
InfernoSS454
I was actually asking if torked was an ls3 or l99.
Old 03-15-2012, 10:08 PM   #10
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
rough idle blower cam by jannety racing 470 rwhp...and leave room to go di in the future. I you are 110 percent sure that you wont go FI theres other big head/cam packages but if a blower is even a possibility I would go with this. BTW its also my dd.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-15-2012, 10:12 PM   #11
InfernoSS454
Oh u an ls3 wantn to know if a cam is worth it yes. I thought u might be an l99 asking if an ls3 cam was worth it my bad.
Old 03-15-2012, 10:14 PM   #12
jcollins91106
Drives: 2010 2ss m6
Is a cam worth the Money----its costly but withbthis camn its mild until about 2800 rpm's and then its a beast
2) Will reliability suffer from installing one---I have had 0 problems...reliability is also alot in the insatll and TUNE!!!!
3) Anybody have any issues after installing one.----None here.
4) How big is enough? The jre 470 cam is one of the biggest blower cams that I personally wanted for a dd. I needed a mean cam with street manners as I drive 40-60 minuts in heavy traffic home from work 5 days a week.
Old 03-15-2012, 10:20 PM   #13
The 2010 Sin
weaponsinc.com
The 2010 Sin's Avatar
Drives: 2014 Lifted 1500, 2013 2SS CRT
The biggest thing I tell anyone and everyone that asks these questions is
"Don't modify your engine if you're not willing to pay for the consequences of it failing. All things will fail eventually and if you don't do all of the supporting mods that need done at once you're setting yourself up for failure. P/V clearance checks, good springs good rods, check lifters, rockers, replace to melling oil pump, upgrade fuel pump (depending on cam size), tune done by a very qualified tuner, and obvious suspension and diff bushings to accept the added power without bad deflection."
Here's why I say this. My 1st cam was installed in my car two years ago tuned by a local tuner. After four months I started developing a small tick (thought it was nothing). The tick turned into a frozen lifter, flat spot on the cam and a bent exhaust valve.
2nd Cam - Installed by a different shop (very well known on camaro5), Pistons were flycut, valve replaced pushrods checked, melling pump installed, and lifter and rockers checked, Glad they did because I had a rocker set that was loose. Professionally tuned by Chuck Anders ChucksLSXTuning, Diff Bushings upgraded to pfadt, and I've had it over 10,000 miles of hard spirited driving and its been with me every step of the way. Things will fail. Stack your $ because insurance and warranty dont exist! ;-)
The 2010 Sin is offline   Reply With Quote
Old 03-15-2012, 10:27 PM   #14
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
LS3 CAM AND HEADERS DYNO ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 02-13-2016 06:15 PM
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 11:42 AM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 02:11 PM
Upgraded your cam in your LS3? What are your specs? Happy? papabearcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-26-2010 04:53 PM
LS3 Cam Package makes over 500rwhp!! Late Model Racecraft V8 Bolt-Ons & Tunes 45 07-19-2009 01:58 PM
