BeckyD @ James Martin Chevy
Old 03-16-2012, 12:16 AM   #1
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Area under the curve(avg horsepower)
I've seen a ton of dyno graphs and positive reviews on cams, but have any of the shops actually taken the time to see which cam delivers the best power curve, and not just the best number? I know the Mustang dyno's always show average hp, which would be a good indication, but has anybody really looked at this? I realize there are tons of variables, but cars with the same mods and tires with different cams would show a lot.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 03-16-2012, 12:31 AM   #2
Avenging Orange
Avenging Orange's Avatar
Generally the smaller cam will produce all its power under the curve. My '04 LS1 GTO had a Thunder Racing TR220.........Only laid down 335rwhp, but it was all under 5500rpm. My '06 had a Comp 228/232, didnt start pulling till 4000rpm.
Lesson from our Aussie brothers.........keep it small, keep it tight. They would run like 216-220 duration with tight lsa (108-110).
Also, check out GM High Tech magazing...they often do LSx cam comparisons
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 03-16-2012, 09:10 AM   #3
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Yep, keep it smaller... these guys are putting to large of a cam in there cars in my opinion, to much weight and not enough gear! My 217/228 on 112 is going in tomorrow! Should pull hard all the way through to about 6400.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-16-2012, 09:27 AM   #4
InfernoSS454
InfernoSS454's Avatar
Drives: 2010 camaro ss
So your saying any cam bigger than that is a waste on this car.
InfernoSS454 is offline   Reply With Quote
Old 03-16-2012, 09:34 AM   #5
newmoon
newmoon's Avatar
Drives: 2013 Boss 302 RR
Good to see somebody is paying attention
2013 Boss Mustang - Present Toy
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is online now   Reply With Quote
Old 03-16-2012, 10:02 AM   #6
Bad70supreme
Yes and no... if you are going with 4.10s and a drag tire setup, and or big stall for an auto then no point. If your are staying with stock gear for a few years to come, mabey just some drag radails, mostly street car then keep it small. The hole point is to match your setup... stock heavy weight car, heavy 20" rims, and 3.42 gears and running a big cam is a big missmatch of parts!
Why do you think so many guys have a hard timing running solid times with these big cam's... they dont have anything down low to get moving.
Old 03-16-2012, 12:06 PM   #7
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
Sure, yes, no, and 100%. or something like that.
Being a company that has been focused on road racing for most of our time, we have to focus in on making power in the RPM ranges we operate in, and for a road race car that is a much broader area than say a drag only car.
Also, and this would have to do with power under the curve as well, is when doing upgrades you have to think about where YOU drive the car. If you spend most of your time idle to 4500 RPM, then there is no point in putting a big cam that is 3000-7200 RPM because you'll never see any of the benefits of it. At the same time....if you are a mile runner...why would you want to worry about anything under 3500 RPM? If your never there...no point in focusing in on that range.
....this not only is related to cam profile but also modifications in general.
I thought you would find this interesting.....when dealing with forced induction and power under the curve.
To make this even more biased towards a centrifugal I chose a LS7 vs LS9 so the ATI has a bigger stroke and cube engine to start with. The E-force cars I have done so far have been auto cars (manual car on the lift right now getting one). The LS9 uses basically a very similar TVS setup to the E-force unit, so it was used to compare.
LS7 (blue curve)
  • LG 1 7/8 Headers
  • LG G7X3 cam
  • RPS clutch
  • 8 rib drive, 8 psi boost
LS9 (red curve)
  • LG 1 7/8 Headers
  • stock cam
  • lower pulley 11 psi boost
Same tire size, same diff ratio used in both cars (3.42)
You can see how the blowers make boost in different ways. Almost 200 ft-lbs toque difference. Notice the LS7 ATI setup pulls more top end HP, just not the low end...even with the longer stroke and bigger displacement.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 03-16-2012, 12:12 PM   #8
nycoupe11
Drives: 2011 2ss/rs Summit White
I went with a VVt-2 cam and once i put a converter and gears in...the thing will flyyyyy
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
nycoupe11 is offline   Reply With Quote
Old 03-16-2012, 12:26 PM   #9
Bad70supreme
Unfortant that most people dont understand that, big cams sell... people always want to go as big as possible and dont understand how it all works. I dont know everything but I after years of trying different things I think I have a pretty good idea of how to choose a cam. These 230-240 duration cams dont start pulling till higher RPM, they make big numbers and they work, but without all the supporting mods they are going to run slower in short burst on the street, no power under 4000k and not going to run big numbers at the track like they should. These cars in basicly stock form should be setup with a cam that will pull from hard from down low and rip real hard from say 3000-6500 in my opinion.
If you look at some of the G8 and GTO guys, some of the most respectable cam only times are ran with small cams and actaully run good MPH.
Old 03-16-2012, 12:32 PM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This is where VVT has it's major advantages. Gives you the "under the curve" numbers and also highend as well. It doesn't give the same highend as nonVVT but you get a good combination of both.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-16-2012, 01:14 PM   #11
InfernoSS454
So all cams have their place and a 230/240 duration with a big stall will still haul @$$. Right?
Old 03-16-2012, 02:36 PM   #12
Unobtainium
Fabricator
Thanks for all the replies, and thanks to LG for the graphs too.
I certainly see the benefit of the positive displacement blowers. I always worry about IAT's after a long pull though.
I really don't want a car that doesn't have any fun factor under 4000, and I think that's what these big cams accomplish. The blower is an interesting case though. Will a smaller cam be worth the overall cost? Ultimately the car will be TT, and not 1000whp.
Hopefully there is a company that sells a milder cam that will work good for turbo later.
Roto-fab CAI
ARH LT's
393whp L99
Twin Mini's...soon
Permagrin...Always
Old 03-16-2012, 03:57 PM   #13
Bad70supreme
If your TT then you are limited to a point, the TT will make sick power! I would suggest talking with a vendor about running a smaller cam that will work with a TT later, They can cook something up for you I am shure.
Old 03-17-2012, 08:19 PM   #14
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
A manual can handle more cam, if you can handle the loss in low end torque.
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Bay Area Dealerships (my opinion) Mindz USA - California 41 11-07-2011 08:21 PM
How about a Pace Car Specific area..... autoguy 5th Gen Camaro SS LS LT General Discussions 5 05-14-2011 02:59 AM
Cruise meets in the London, St. Thomas area Blacamaro Canada 26 08-04-2010 01:21 AM
Area 52? Are post-10K VINs stuck in QC too? ZombieEatsYou Camaro Price | Ordering | Tracking | Dealers Discussions 0 06-20-2009 10:28 AM
Houston 2010 Camaro Caravan... Camaro Launch Events in your area? rolnslo 5th Gen Camaro SS LS LT General Discussions 21 04-15-2009 05:46 PM
