Old 03-16-2012, 04:21 PM   #1
jsherm007
Always drop the top
jsherm007's Avatar
Drives: 2014 Stingray Vert 2LT z51
Clutch fluid leaking, pooling up slowly in husky mats!
Taking to dealer on Monday. Anyone else experience this? Can it be causing damage while driving? Is this linked to my break fluid, this affecting stopping?
jsherm007 is offline   Reply With Quote
Old 03-16-2012, 04:35 PM   #2
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
Check the master cylinder level. Both the clutch and brakes operate from the master. Haven`t heard of this happening before. Definitely take it in to get fixed. I know there have been problems with the cap leaking on the master.
Bo Tie 1 is offline   Reply With Quote
Old 03-16-2012, 04:42 PM   #3
Bo Tie 1
Bo Tie 1's Avatar
Hey you want to be careful about not getting any brake fluid on any painted surfaces.
It will eat the paint. In case you didn`t know.
Old 03-16-2012, 06:32 PM   #4
jsherm007
Always drop the top
jsherm007's Avatar
Here are some pics of what I am seeing:
Old 03-16-2012, 06:45 PM   #5
Bo Tie 1
Bo Tie 1's Avatar
Wow that is some major leak. I dont think i would be driving it.
Have you checked the fluid level?
Old 03-16-2012, 06:49 PM   #6
jsherm007
Always drop the top
jsherm007's Avatar
I just took it to dealer today, on way home from picking up daughter at preschool. Got ride home with their curtsey shuttle. I didn't want to drive it like you said, and no point to drive home (past dealer) then park it all weekend, and drive back to dealer. So they have it and can do what they need to do Monday morning.
Now I have to drive my 02 vette all weekend :(
Old 03-16-2012, 06:50 PM   #7
jsherm007
Always drop the top
jsherm007's Avatar
Actually what really sucks is my FARK came today, and I have all my audio stuff, and no car to install it in!
Old 03-16-2012, 06:55 PM   #8
Bo Tie 1
Bo Tie 1's Avatar
Iam sure they will get you all fixed up and back on the road.
At least you have another awesome car to drive. Good Luck!
Old 03-17-2012, 01:31 AM   #9
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Wow. How long has it been leaking? It looks like it has been for a while.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 03-17-2012, 07:52 AM   #10
jsherm007
Always drop the top
jsherm007's Avatar
It had a little drip Wed, that I though was just condensation cause weather here in MN is unusually warm and humid... Then Friday it let loose!
Old 03-19-2012, 09:58 AM   #11
jsherm007
Always drop the top
jsherm007's Avatar
Update: dealer had to order a new clutch slave cylinder. Part not available till tomorrow.
Old 03-20-2012, 06:36 PM   #12
jsherm007
Always drop the top
jsherm007's Avatar
Dealer couldn't 'get to my car today' because for some reason by 1p the 'technician had gone home'
Are you freaking kidding me? Never had a dealer give me that excuse before. So 'tomorrow by noon' they should have my car done.... ugh.
Old 03-20-2012, 06:47 PM   #13
Bo Tie 1
Bo Tie 1's Avatar
Man that sucks! Hope they fix you up tomorrow.
Old 03-21-2012, 11:12 AM   #14
jsherm007
Always drop the top
jsherm007's Avatar
Sooooo...Leak fixed! Apparently fluid didn't drip behind mat!
However, I did mention to them a shake in the steering wheel as well... Turns out both front tires were 'egg shaped' on the balancer. So they had to order 2 new 20" tires for me. I should get the car back tomorrow! That will be the 7th day without my car! But glad the dealer is being thorough!
Do you think that the car needs a separate Clutch Fluid reservoir 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 620 09-04-2017 07:59 PM
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
