Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Suspension / Brakes / Chassis
Old 03-16-2012, 04:23 PM   #1
Drives: 2010 REDLINE EDITION#46
timing bushing
does this have to be done.when replaceing springs..if so can any tell me what to do.. pics would really help thanks
MUSCLEIT is offline   Reply With Quote
Old 03-16-2012, 09:38 PM   #2
Drives: 2010 SS2 Camaro
It is critical. The bushings will act as springs if they are deflected, as they would be if you install drop coils.
Camaro427 is offline   Reply With Quote
Old 03-16-2012, 11:37 PM   #3
caverman's Avatar
Drives: '69 SS Convertible
This should be a sticky....
Build Journal
Old 03-17-2012, 12:34 AM   #4
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
You guys are dead nuts on. Thank you. I also noticed we need to update that thread with the newest OEM and Pedders alignment specs.
Here are the newest FE2, FE3, FE4 and FE5 OEM and Pedders Alignment Specs.
Bush Timing
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
---Inner Control Arm Bushing
---Inner Radius Rod
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 09:11 AM
Finally official! 2012 new v6 engine. bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 66 08-24-2011 10:49 PM
Detroit Speed vs. Pedders usmcjlp Wheels and Tires Talk Sponsored by The Tire Rack 35 07-22-2009 12:14 AM
