Old 03-16-2012, 06:00 PM   #1
Cyber2SS
Drives: 2013 M6 ZL1 2012 Shelby Cobra
hurst install
I'm currently taking the old shorter out but seems like i have to remove the drive shaft bolts to let it drop or move to get my stock shifter out. I dropped the trans support but the shifter is still hitting the shaft. Is that what i have to do?
Cyber2SS is offline   Reply With Quote
Old 03-16-2012, 06:30 PM   #2
badazss
SS-500HP
badazss's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Send a message via AIM to badazss Send a message via Yahoo to badazss
Hi there
You should have to remove your driveshaft
I did mine and all I did was remove the boot removed the clips then have some one move the shifter to the side so you can take the pin outnumber
It is real tight there and you need to be Careful make sure you have a swivel socket or there is a possibility you could strip it
It me a hr to install mine also do your self a favor and read the directions
Denny
2ssrs m6 Red jewel tintcoat
Daily Driver 05 silverado ext cab z71
My Build Journal
http://www.camaro5.com/forums/showthread.php?t=103089
badazss is offline   Reply With Quote
Old 03-16-2012, 07:42 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Not sure if this will help but here you go
Old 03-17-2012, 12:33 PM   #4
Nessal
Drives: Exige, Miata, Ghia
Push the linkage that comes from the transmission to the side. The shifter should clear it with A LOT of space left over.
Nessal is offline   Reply With Quote
Old 03-17-2012, 12:34 PM   #5
Nessal
Oh by the way, I know that the hurst video says to drop the transmission support down an inch or so. I have no idea why they tell you to do this as it doesn't help one bit.
Hurst billet shifter install ? 2012REDSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 02-26-2012 07:20 PM
HURST Products! New Order Feeler! AutoAgenda Transmission / Driveline 12 12-12-2011 07:33 PM
The New and Improved Hurst Shifter alfie43 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 08-11-2010 11:47 PM
Hurst Shifter install pointers Carlos Garza V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 12-23-2009 02:09 PM
Can I get some Lube with that Hurst install? SSOOCH V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 11-07-2009 07:42 AM
