Tom Henry Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Chevy Camaro vs... Comparison of Chevy Camaro versus its competition. *NO STREET RACING STORIES*
Old 03-16-2012, 05:58 PM   #1
Maniature
Maniature's Avatar
Drives: Camaro 2010 1LT(batman edition)
10 V6 CAMARO VS 3000GT VR-4
camaro:
flowmaster super 44
DT shorties
VR intake
Vmax TB
trifecta tune
3000GT:
i think it has a stock TT
and a nice aftermarket exhaust lol
thoughts?
Maniature is offline   Reply With Quote
Old 03-16-2012, 06:13 PM   #2
Nessal
Drives: 2011 SS/RS
Dont they do low to mid 14's?
Nessal is offline   Reply With Quote
Old 03-16-2012, 06:28 PM   #3
Deki
Deki's Avatar
Drives: 2011 Mustang GT
When they were new, they were doing low to mid 13s at about 104mph. If it's a good running example, and he has a turbo back exhaust, he will pick up a few mph. That being said, I've never seen anyone that had a VR-4 that had an aftermarket exhaust that also didn't have a tune. With a tune and TB they will hit high 12s pretty easily.
2011 GT Premium//Performance White...a little modded
Deki is offline   Reply With Quote
Old 03-17-2012, 12:55 AM   #4
S8ER01Z
Drives: Camaro Z28
This.
What's the modded v6 Camaro run? Any numbers?
2001 Camaro Z28 M6 (MTI Lid/FRA, LS6 Cam, BBK LTs)
S8ER01Z is offline   Reply With Quote
Old 03-17-2012, 01:05 AM   #5
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Coming from owning a 3000gt vr4 and still currently do, most that have jut an exhaust won't have a tune. They aren't flash able ecus except 99's which is just being done within the last year. So most people won't spend the money on an ecu unless they are fully modded, turbos injectors and the rest.
Stock boost is 9psi but can be turned to 14 psi no problem and they are quick. The long gears I think are an advantage for the vr4. 3gear stretches to 180km/h.
Caswell239 is online now   Reply With Quote
Old 03-17-2012, 01:46 AM   #6
Rock36
I just like V8s
Rock36's Avatar
Drives: 2007 Corvette Z06
Tune or not, my understanding is also that these cars were mid 13s stock, so you have some catching up to do from the get go... If he is tuned then the goal post just gets moved farther is all.
Any plans to actually run each other at the tack.
"Anyone know who sells the driver mods?"
2007 Corvette Z06: Le Mans blue, 2LZ
Rock36 is offline   Reply With Quote
Old 03-17-2012, 11:26 AM   #7
Nessal
Drives: 2011 SS/RS
Quite impressive for such a old car. My cousin has the SL version which is the non-turbo and that car is a real slouch. I know they are heavy cars, but I think they are around the same weight as us.
Old 03-17-2012, 12:00 PM   #8
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
If he has a good running example he probably has an advantage. That said, your car with its mods under the right conditions is perfectly capable of a mid to high 13 1/4 mile.
Give it a go and have fun!
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 03-17-2012, 08:28 PM   #9
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2010 2SS and 2004 WRX
He could also make you look real slow from a dig. AWD puts power down immediately. Race on a track (in a straight line) and you're probably ok unless he has mods.
JamesNoBrakes is offline   Reply With Quote
Old 03-22-2012, 09:19 AM   #10
SS King
SS King's Avatar
Drives: a Panty Dropper
V6 vs a vr4. the vr4 is going to kill you hands down it wont even be a race
SS King is offline   Reply With Quote
Old 03-22-2012, 09:28 AM   #11
IROCanSS
Drives: 89 IROC 350
THIS... probably.
Twin turbo AWD V6 with 300 hp and 307 ft-lbs weighing in at 3700 lbs
VS
V6, rear wheel drive with 312 hp and 273 ft-lbs weighing in at 3800 lbs with a few mods.
It could be close but its the launch thats going to kill you.
Old 03-22-2012, 10:29 AM   #12
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 2012 LFX/2011 EcoBoost F-150
Originally Posted by IROCanSS View Post
THIS... probably.
VS
With his mods he should be about 350 hp and 305 ft-lbs at the crank and right around 3700 lbs. I think in the quarter he might take a stock one, but there just aren't many of those around that haven't been tuned.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-Drag Radials-CircleD 4000 Stall-GPI Fuel Enrichment System
586 RWHP & 606 RWTQ @20 psi on 93 Octane (unlocked converter)
1/8 mile -- 7.158 @ 102.10 (20psi)
Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 03-22-2012, 10:46 AM   #13
KMPrenger
KMPrenger's Avatar
I don't understand how you can say this. The Vr4 should be quicker off the line due to its AWD, but I've seen magazine tested times of between 13.7 to 14 flat in the quarter mile.
This modded V6 is perfectly capable of that. In a 0 - 60 race or stoplight to stoplight race the V4 has the advantage, but really past that its pretty equal.
weight is 3781lbs...basically equal or slighly more than a Camaro V6. The OPs car should be roughly 30 to 50 lbs lighter than stock.
Next time think about it a bit more before you write off the V6 too soon.
Old 03-22-2012, 05:50 PM   #14
SS King
SS King's Avatar
I'v owned a Stealth RT TT its the same motor as the VR-4 and from personal experience it will smash a v6 camaro -Just sayin and now i own a SS I. I test drove the v6 before i got my ss and it felt like a slug compared to my RT TT. Maybe its the AWD I don't know but me being behind the drivers seat in both thats where my experience comes in. Have you been behind both?
I'm talking stock for stock here no mods. I did not realize you had some work done so the outcome could differ
Old 03-22-2012, 07:12 PM   #15
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
Back when I was in high school... I was obsessed with the 3000gt vr-4. But I think I would bet on the camaro. The 3000 is also heavy but awd helps alot
Indy Bumble Bee is offline   Reply With Quote
Old 03-22-2012, 07:35 PM   #16
KMPrenger
KMPrenger's Avatar
Unfortunently, well never get to see the outcome of so many of these versus match ups!
Old 03-22-2012, 09:09 PM   #17
GretchenGotGrowl
Again, everything I read has the stock Stealth/3000 running from 13.9 to 14.2. With that wouldn't "smash" or "kill" a stock V6, much less the OPs car.
Build Thread
Old 03-23-2012, 07:35 AM   #18
Stew
Drives: 92 Lumina/01 Dakota 4.7 HO swap
Is your reading limited to old mag times?
Stew is offline   Reply With Quote
Old 03-23-2012, 07:43 AM   #19
GretchenGotGrowl
No! My point is they offer no other evidence except their personal experience. Show me some timeslips of a stock 3000 or Stealth running better than the bolt-on V6 in the fast list. He's got a good set of mods and like I said originally he might take one in the 1/4 mile.
Build Thread
Old 03-23-2012, 07:52 AM   #20
IROCanSS
Drives: 89 IROC 350
I'll buy that...
Don't try to talk sense...
Don't pop a spark plug, its not worth it.
The 3000GT TT and the POS Stealth (do any of these actually still run?) are NOT that fast. PERIOD. Yes AWD helps but I remember in High School.. mid 90s, I drove a 92 Corvette and my buddy had a 93/94ish VR4... he thought it was hot shit... I used to wax the floor with his car. Keep in mind, a 92 Corvette was only 300 hp.
After thinking it through, the cars would be VERY close AS DESCRIBED HERE.... A tuned VR4 will eat up the V6... but thats not what we are talking about!
Old 03-23-2012, 08:18 AM   #21
GretchenGotGrowl
I'll buy that...
Exactly. How many untuned ones are still around? I'm guessing the untuned ones have never seen a track, either.
Build Thread
Old 03-23-2012, 09:05 AM   #22
KMPrenger
KMPrenger's Avatar
hehe
Old 03-23-2012, 10:21 AM   #23
S8ER01Z
Drives: Camaro Z28
Do you realize how hard it is to get information like this? These cars were on the drag strips before the internet had message forums. The mags were just as poor then as they are now when it comes to track talk (5th wheel back then, gps vbox today)... The only reason I have timeslips from my stock LT1 Camaro is it was still stock in 2001 when I was running it... otherwise scanning a timeslip to post on the internet in the 90s was not something that happened on any regular basis.
Some of us were around when these cars were running around on the streets and hitting the tracks.. unless my memory is just that bad I know what I saw.
Old 03-23-2012, 10:44 AM   #24
GretchenGotGrowl
Being in my 50s, I remember them well, too. The stock ones were fast for their day, but not any faster the V6 the OP has.
Build Thread
Old 03-23-2012, 12:54 PM   #25
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I really don't know, but I get the winner against my Sky Redline ...
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 10:38 PM
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 449 04-24-2013 07:52 AM
SEMA Show 2010 - New Camaro Products Showcase - pictures & descriptions! Sean@Phastek Camaro Photos | Spyshots | Video | Media Gallery 59 06-23-2011 12:56 PM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
