sjm autoprod
Old 10-22-2009, 12:03 AM   #99
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
12.84
ran a 12.84 tonight with just the muffler delete
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
Old 10-22-2009, 12:05 AM   #100
1320junkie
Drives: The Imperial Army
SG thanks a million for staying on top of these
Old 10-22-2009, 09:32 AM   #101
D R
FORSALE 800hp LPE Camaro
Drives: 07 LPE Escalade , 10 LPE Camaro SS
Send a message via Yahoo to D R
Here are some times slips, first two are from last month when the car was stock. The other 4 are from last night after getting it back from Lingenfelter. The first run I was late on the light due to trying to foot brake it and get a feel for what the brakes would hold. I was running the DR 305/35/20 @ 20psi, 60 foots weren't too bad (I was slipping some out of the hole and going into second), so there is more to be had by lowering down to 12-17psi.
Shortly after the first run (last night) someone oiled down the track by staying in the groove almost the entire length, hence the clean up process began. After waiting forever, we ran then got right back in the staging lanes to run again, and once more before leaving. I was at or near 200 degrees (coolant) each run, so I'm sure there is some time to be saved next spring when I can let it cool down in between runs, and find the sweet spot for air pressure.
D R is offline   Reply With Quote
Old 10-22-2009, 11:46 AM   #102
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
Right lane is me, 13.171 @ 110.539 ( DA 1084) corrected would be 13.025 @ 111.75. Stock tires air pressure air box.
Muffler Delete that is all( should not be considered a mod) but oh well
LS3 6k miles on it.
Sacramento Raceway 10/17/2009
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 10-22-2009, 11:55 AM   #103
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
did your car come from the factory with mufflers?, yes it is a mod and also weight reduction!
Old 10-22-2009, 03:42 PM   #104
D1BADZ
hmmmmm
D1BADZ's Avatar
All i can say is Driver Mod...... im a 300 lb dude and can pull these #s.
weight reduction my ass./
Old 10-22-2009, 05:32 PM   #105
jamesfl
BAD 4SS
jamesfl's Avatar
Drives: 2010 2SS/RS with ground effect
DR's description
His description says 2010 SS LPE, I assume at that pace he has a 550 or 570.
Procharger P1, Kooks LT, Corsa Cat-Back, AEM Meth injection, 2800 Stall, BMR trailing arms, DashDAQ computer, etc....
jamesfl is offline   Reply With Quote
Old 10-22-2009, 06:02 PM   #106
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Based on LPE's website the 570 package includes:
Package includes:
- TVS2300 intercooled supercharger system
- Black powder coated finish
- Based on OEM Eaton supercharger unit
- Properly sized fuel injectors
- Fuel system upgrades
- 160 Degree thermostat
- Kenne Bell Boost-a-pump fuel pump voltage booster
- Lingenfelter High Flow Air Intake
- Professional installation, testing and calibration
- Chassis dyno report before & after installation
- Excellent drivability, highway mileage not adversely affected
- Lingenfelter 3 year/ 36,000 mile warranty
- Lingenfelter fender badges
I just wanted to make sure I put his time in the correct 1/4 mile fast list.
Old 10-24-2009, 11:29 PM   #107
Three-D
Drives: 69 Z/28
Tires used on the pass: Stock
Performance Mods (if any): None
Category submitted for: Bone Stock (LS3, M6 w/1600 miles)
Three-D is offline   Reply With Quote
Old 10-25-2009, 05:24 PM   #108
JP2010SS
JP2010SS's Avatar
Drives: 2010 Camaro SS2
2010 SS2 track times
60ft 2.0
1/4 12.69
MPH 112
Kooks 1 7/8 3"outlets, off-road pipes with GMP exhaust
Street tires
AFE CAI
HP tune
M6 LS3
429HP
430Tq
JP2010SS is offline   Reply With Quote
Old 10-25-2009, 06:46 PM   #109
69Bird
69Bird's Avatar
Drives: 1969 Firebird, 2010 Camaro SS
Tires used on the pass:Stock
Performance Mods (if any):TVS 2300, ARH LT with Cats, CAI. LS3 M6
Category submitted for:Power Adders
60'.............2.1120
330'...........5.3436
660'...........7.7925
660’ mph...94.96
1000'..........
1320'..........12.0566
1320’ mph…120.51
Name of the track:Fayetville Motorsports
Date of pass:25 Oct 09
Weather conditions: (include Density Altitude, if known): 64F 50%humidity
2SS RS CGM LS3, 11.97@119mph with Pirelli lined fender wells
69Bird is offline   Reply With Quote
Old 10-29-2009, 02:20 PM   #110
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
108.641 mph bone stock L99
I believe that is the highest mph for a bone stock L99 (not that it matters to get on the list) Im just pointing it out........
2ss rs auto (L99)
Tires used on the pass:stock
Performance Mods (if any):none
Category submitted for:bone stock (even has the factory oil)
car#3313
reaction . .099
I1..........2.079
I2..........5.758
I3..........8.770
MPH (I3).83.267
I4..........11.313
E.T........13.445
MPH.....108.641
Name of the track:sacremento
Date of pass:10-28-09
Weather conditions: app. 60 deg.
kaler is offline   Reply With Quote
Old 10-29-2009, 04:04 PM   #111
Stang Stomper
Drives: a Camaro...in my dreams
Originally Posted by Red SS View Post
Here's our slip from today.
Mods are: Kooks complete exhaust
Cold Air Inductions intake
Jannetty tuning
and on the stock tires
Nice 60' !
Stang Stomper is offline   Reply With Quote
Old 10-31-2009, 05:18 PM   #112
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
First time at drag strip. #3738
Just for others who have not gone: Long Pants, closed toe shoes, no tanktops or shorts and the BIGGIE....... Snell 2000 or higher approved helmet required for cars running 13.99 and under. Only $20 to give it a try.
Mine was a snell 85, could not use and only got to make one pass, BIG BUMMER!
Traction control off, 1000rpm launch, let the trans do the shifting. Stock tires, roto-fab CAI, Corsa cat-back exh.
Was against a Challanger SRT8. My reaction time was slow, I was looking at all the stuff and trying to see his lights. Found out you can't. A little bit of wheel spin. Next time I will paddle shift myself. The computer shifted around 4500, which was too soon and it kind of bogged. I beat him in most catagories, but he passed the line first.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 01:31 PM
