| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#26 |
![]() Drives: Red 1SS Join Date: Oct 2010
No, you won't need to run cooler plugs. If you look at the info label that comes with the kit (the emissions and belt info label that you are suppose to stick under the hood) it tells you to use the stock sparkplug gap as well.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune |
#27 | |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
#28 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
It might look pretty...aka attention to detail...but it is clearly Third of the big three...and by FAR. Big three being a Maggie, Edelbrock or Whipple. I don't count Kenne Bell cause I hate em.
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
#29 | ||
Serious Sleeper
Drives: 2010 CGM 2SS/RS M6 Join Date: Nov 2008
Whatever, I just like em
Drive-by Fact of Life: After Monday and Tuesday even the calendar reads... W T F ![]() *************************************** |
#30 |
I Wanna Go Faster!!
THat's all that matters. Ever run your car at Jackson?
#31 |
Read the ngk website,its a good read.....
#32 |
2010 ABM RS/SS with a Procharged LS3, Flowmaster exhaust. |
#33 |
Use the Factory Plugs.......
2010 SS/RS LS3 M6.. Eforce,Janetty tune, JRE fuel upgrade, ZL 1 fuel Pump, ADM FPC , ID 850 injectors,Roto Fab CAI, MSD wires,JBA Long Tube 1 7/8 headers Borla S exhaust,MGW short throw shifter,PLX gauges Kenwood touch screen nav, Polk Audio Speakers, 2 1200 Amps, Fusion 12" subs, Complete Vehicle Dyna matted
#34 |
![]() Drives: 2007 Corvette C6 615 rwhp Join Date: Dec 2011
I think colder plugs will be needed. I don't know anyone running factory plugs on blown cars.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam E Force SC, ARH 1 7/8 headers, cats and x-pipe, NPP with M2W 160 degree stat, Dual fans, Casper fan switch, 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace ID 850 injectors, 3.0 pulley, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc 2800 stall 724 RWHP @ 6500, 866 Lbs Torque @ 3700, Tuned by FEDERAL 10.42 @ 133 (on old build, new untested) |
#35 |
When I supercharged my car, I researched on here, and many people said stay with the stock plugs. Not everyone said that, but enough to convince me to keep them. And so far no problems with the stockers
#36 |
Serious Sleeper
Looks like, not not a simple question on the plugs. I tend to believe what NGK's website says. I don't plan on drag racing, I just want a performance weekend car that still has near stock mpg manners . I plan on getting this bolted up this coming weekend and am waiting on the fuel up grade kit from Jannetty. The plugs I can pick up anywhere so thats not an issue.
This whole supercharger thing got started when me and my wife went to Starbucks for a coffee and I parked way out. Before I could get out and past the the rear of the car a mid 2000 model Mustang GT came pulling in one spot over on the passenger side. He had his car running and his window down, I could tell he had flowmasters and they sounded good. I gave him a thumbs up and hollered, "sounds good". He shut his engine off and asked me to repeat what I said. When I told him, he said," Oh, I thought you wanted to run me." He asks me what kind of mods I had on the Camaro and I said, headers and a cai. "Well it wouldn't have been much of a race, I have a supercharger on mine." That still bothers me and that was 6 months ago. Oh and HufferSS, no on Jackson, thats a serious camaro you have there.
#37 |
It amazes me someone would think that you could run a stock plug with a blower that adds over 100 hp
. Take notice that gm droped the heat range from the ss to the zl1,better yet why would they go to the trouble to make all these heat ranges if one size fits all...Ive seen a ton of motors destroyed from the wrong heat range,ive yet to see a bad motor from a cold spark plug...
#38 |
I think the main vioce that said keep the stock plugs has now changed to say use the ZL1 plugs,which are coolder ,you may want to do a plug change....
#39 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
![]() Quote:
We do Recommend ZR1 Plugs for all supercharged Gen5s Do they make more Power, NO Do they Run better NO, just makes you feel good that you changed something ![]() Remember the ZR1 Plugs are designed for 630 Crank HP but we run them at 1200 Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#40 | |
Serious Sleeper
I'm gonna We do Recommend ZR1 Plugs for all supercharged Gen5s Thanks
#41 |
where are you planning on hooking up your Catch can? I don't think it will fit on the pass side...
2011 2SS/RS L99
2009 Cobalt SS 1979 Z28 Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495 MY BUILD THREAD ![]() |
#42 |
D/s ....easy install with eforce.
#43 |
![]() Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
What is part number on the ZL1 plug
#44 | |
#45 |
#46 |
Serious Sleeper
Thanks guys
Order Details: ------------------------------------------------------------------------ Quantity: 8 Item: 41-104 - SPARK PLUG
#47 | |
Serious Sleeper
I've seen em mounted fwd of the eng battery terminal, that looks good to me.
#48 | |
![]() Who called who out?
#49 |
I've seen that too, but I have the RotoFab window washer replacement there. I am running out of room! lol
2011 2SS/RS L99
#50 |
LOL,ok last comment,your still buying a set of plugs,maybe the wrong heat range but your still buying a set ,I would think the sparkplug companies recomendation would be a great one.just wanted to give the members another voice .nothing against you Ted you do great work ,I just disagree with running a stock plug in a modified engine,I would think spark plug companies would rather have one part number LOL
| Thread Tools | |
| Edelbrock e-force supercharger $4500 | stock00ss | Forced Induction | 11 | 11-09-2011 04:40 PM |
| Edelbrock E Force Supercharger Issue | PJ droopy pants | Forced Induction - V8 | 27 | 01-10-2011 08:21 AM |
| Edelbrock E Force Supercharger w/BMR Springs & Sub Frame Connect Under $7000.00 | Xplosive Performance | Forced Induction | 1 | 01-05-2011 02:41 PM |
| Edelbrock E-Force Supercharger Kit w/Stainless Works Headers | Xplosive Performance | Forced Induction | 0 | 12-20-2010 09:07 PM |
| Edelbrock E Force Supercharger Installed and Tuned! | PJ droopy pants | Forced Induction - V8 | 61 | 07-16-2010 12:48 PM |
