Old 03-18-2012, 08:33 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Question Shift point hitting hard? A6 L99
So i recently got my vehicle finally tuned. What i have noticed is that my shift points are hitting hard. Whenever i am driving in "D" the rpm go to around 2500 and you can feel it when it is changing gears by the yank i feel. I dont know if this is normal or not, just dont want to miss up my transmission. Been thinking about gettiing a jannetty tranny tune, only thing is that it will void my engine tune that i got now that i just paid for. Or is this something that my tuner can fix?
lincoln361 is offline   Reply With Quote
Old 03-19-2012, 04:30 PM   #2
Nessal
Drives: Exige, Miata, Ghia
Go back to your tuner and have him/her fix it.
Nessal is offline   Reply With Quote
Old 03-19-2012, 04:53 PM   #3
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
He should be able to fix it.
I have an engine/trans tune from Jannetty and it drives as smooth as stock, shifts more quickly but no jerking of hitting the shift points hard in any way, just good smooth, solid shifts.
Your tuner should be able to adjust this if he knows what he is doing. I hear that the Trans tune can be tricky to get right. If your tuner is not experienced with this platform, you may be in for a ride. I would give your current tuner a second chance but if he does not get it right, get ahold of Ted and he will likely solve the problem.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-19-2012, 05:17 PM   #4
John@AutoAgenda
John@AutoAgenda's Avatar
Drives: 2004 GTO
Sounds like the line pressure in the trans was upped while the vehcile was tuned and if he does not have any experience with adjusting the pressure it could be fatal to the trans if not done properly.
John@AutoAgenda is offline   Reply With Quote
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
L99 suggested rev limiter and shift points BossCitySS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 06-25-2011 12:59 AM
L99 3-4 Shift Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-17-2009 10:22 PM
SS Shift Point PONYKILR V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 03-24-2009 01:41 AM
