Old 03-19-2012, 09:20 AM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
gears gears GEARS!
Thinking of doing 3.73s on my L99. I haven't been to the track (maybe someday) so it's just DD when the weather's nice. Are the 3.73s a good choice? What's the best brand to go with? As for the install, is this something my dealer can do? Most of the performance shops are a bit of a drive from where I live. Thanks for the advice
E.T. is offline   Reply With Quote
Old 03-19-2012, 03:57 PM   #2
E.T.
E.T.'s Avatar
Just a little update....
Found a local shop that can take care of the install. What do you all think about the LPE 3.70 gears? I've done a bit of reading, and they seem like a very good choice. Is first gear still usable, or would 3.45 be a better ratio?
Old 03-19-2012, 04:48 PM   #3
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I have had the Richmond 3.73s and currently LPE 3.91s in my L99 and can say without a doubt, I would recommend the LPE 3.70s if your looking for a gear set in that ratio range. I would recommend them over the Richmond gears.
The reason, gear noise and strength. I had the spider gear in my posi unit go south and the stress cracked the ring gear on the Richmond set. Not the fault of Richmond. ALso, the Richmond gears, while not loud by any means, had a noticable gear whine at around 38-45 mph. Not bad, and I really did not notice it until I had the LPEs installed and had absolutely zero gear noise of any kind.
Cost a bit more but I would recommend the LPE gears.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 03-19-2012, 05:32 PM   #4
E.T.
E.T.'s Avatar
Thanks man, that's what I was hoping to hear. I was going to order the LPEs online, but my local shop can order them direct from manufacturer (American Axle). If they order them and do the install, they will also give me a warranty in case anything goes wrong. If I supply them myself, they will only cover their work, but not the actual gears.
How did the 3.70s feel on the butt dyno?
Old 03-19-2012, 08:45 PM   #5
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
With the 3.70, 1st gear is still very usable and you will be very happy you chose LPE gears. i wouldn't spend money on 3.45 unless it was very cheap.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 03-19-2012, 08:52 PM   #6
E.T.
E.T.'s Avatar
Cool cool The place that might be installing them said they'll give me a 3-year warranty or something along those lines. Sounds pretty good, just waiting for a quote.
Old 03-19-2012, 08:58 PM   #7
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Gear choice should also be dependent on your modifications and how you drive the car both current and near future. With your current mods, I would suggest the LPE 3.70. If FI is in your future, you might want to consider a slightly smaller gear like a 3.55. Keep in mind that the 6L has a very low first gear ratio making traction a problem. Drag radials will be necessary at the track with this gear change unless you enjoy spinning.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
AAM 3.91 Gears...Very Nice StreetStrip V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 36 06-05-2017 08:44 AM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Question on my blown Richmond's for the experts Eric Baker V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 10-29-2011 10:59 AM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
