Old 03-19-2012, 12:11 PM   #1
Jason 98 TA
Drives: Camaro
Highest Flowing LS3 Cylinder Head Available
We're finalizing the new 263cc version of the PRC LS3 aftermarket casting cylinder heads right now guys! The good news is 380cfm with a runner that is the same size as stock & better than stock valve drop! Look for heads cam power numbers to never be the same very very soon!!
Jason 98 TA is offline   Reply With Quote
Old 03-19-2012, 02:03 PM   #2
CGT
Drives: 2011 SSm6
Same valve sizes as the smaller version? What is the MCSA of both versions?
CGT is offline   Reply With Quote
Old 03-19-2012, 05:54 PM   #3
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
That number sounds great, especially if it was at a realistic lift # like .650".
I'm assuming this is a CNC package for that casting?
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 03-19-2012, 07:06 PM   #4
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Hell yeah
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 03-20-2012, 11:06 AM   #5
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
So what was the point of me buying the 250cc versions?
You advertised the 250cc runner to be an advantage due to added velocity...then make a stock size runner casting and claim it to be the best ever?
I am confused...
Black 2016 1SS A8 NPP
Drag Pack, CAI, Headers, Mamo Ported MSD Intake, Pray Ported TB, Shrader RSD, E85
Best ET- 10.85
Best Trap- 125.39
ULTRAZLS1 is offline   Reply With Quote
Old 03-20-2012, 12:44 PM   #6
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Is there an option for smaller combustion chambers to up the compression like your other cylinder heads?
Edit: Also, are these the heads that you were working on that would accept an LS7 intake manifold?
Kyle2k is offline   Reply With Quote
Old 03-20-2012, 01:33 PM   #7
HaubSS
HaubSS's Avatar
Drives: '11 IBM 2SS/RS LS3/M6
Jason,
I did just purchase my TSP 229/236 camshaft and will be having it installed within the next 2 weeks, so if you need a test dummy....I can be that guy.
Looking forward to seeing the dyno results of these heads.
2011 IBM 2SS/RS - LS3/M6 - Grey Interior
Full bolt-ons + TSP 229/236, 112 LSA
Tuned by BROOKS PERFORMANCE
BMR Stage 3 suspension
MRR 288 - 20x10(+35), 20x11(+43)
HaubSS is offline   Reply With Quote
Old 03-20-2012, 02:46 PM   #8
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I am confused...
Old 03-22-2012, 10:17 AM   #9
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Bump for unanswered questions...
Old 03-22-2012, 11:40 AM   #10
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
No offense to anyone,
But you guys all must play with yourselves
you got guys with 800 + horsepower before these heads even came out.
They're blowing axles and drivesshafts and clutches trying to get thier car to hook up...
i mean how much horsepower do you really need? all the horsepower and torque in the world wont make you the fastest without the right drivetrain to back it up. and even with the right drivetrain there always too much horsepower and torque around for it to handle.
IDEALG is offline   Reply With Quote
Old 03-22-2012, 01:52 PM   #11
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Because there are only so many ways to increase power on a naturally aspirated setup?
Old 03-22-2012, 02:07 PM   #12
MA2010SS
Drives: 2010 Camaro SS
I'll try to keep this answer simple, it all depends on your camshaft, if the heads flow 380CFM at what point are they providing the best flow numbers .700 lift??? A lesser flow numbers say 340CFM head work excellent with a .600 lift. If you have that same .600 lift cam working with the 380CFM head, the heads will outflow the cam. It will come down to the best combo of heads/cam.
Hope this helps
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 03-22-2012, 02:25 PM   #13
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Hope this helps
Very true, and keep in mind it isn't always about the flow numbers. Valve angle, port velocity, etc also factor in...I will say that it isn't necessarily a bad thing that heads can outflow the cam either- just don't be looking for the holy grail and upgrading every time a set of heads with 5 more cfm come out.
Old 03-22-2012, 03:43 PM   #14
MA2010SS
Right on, it's always about the combo that is put together and what the end goals are...mild, full race...etc
NEW LS3 Splayed Valve Heads FTI-EDC Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 10-31-2011 07:54 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
LSX owners: AFR Cylinder Head Owners FTI-EDC General Automotive + Other Cars Discussion 0 11-10-2006 06:54 PM
