HeadlightArmor
Old 03-19-2012, 04:27 PM   #1
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
My cam choice for the LS3
Cam only M6 choice of mine goes to:
http://www.compcams.com/Company/CC/c...csid=1402&sb=0
Have it cut on a single bolt core and with a 114+4 instead of the 113+4
Old 03-19-2012, 06:11 PM   #2
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Looks like a really good cam. Dont do a single bolt though change the timing gear set to a three bolt its added insurance.
IDEALG is offline   Reply With Quote
Old 03-19-2012, 06:50 PM   #3
SC2150
I would get the one for the LS3 though due to the can sensor location change from the GenIII.
Old 03-19-2012, 06:54 PM   #4
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Thats exactly what my cam is but 114+2
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-20-2012, 01:25 PM   #5
Bo White
Bo White's Avatar
Does it have good manners down around 1000-1200rpm in 1st and second?
Old 03-20-2012, 03:07 PM   #6
MikeOD
Drives: 2010 M6 2SS
I disagree http://www.camaro5.com/forums/showthread.php?t=210400 ...I have a 3 bolt in my car, but it just happens to be what my cam is, didn't really particularly matter to me either way, I just made sure I got the right sprocket for it.
The cam sensor provision on an LS1 or "Gen 3" cam makes no difference in a Gen 4 V8. The LS3 and other Gen 4 V8's cam sensor reads the cam sprocket, not the cam itself. I wouldn't be surprised if most of the cams people put in their gen 4 engines have a gen 3 cam sensor pickup on them...mine does...the cam works fine though because the sensor in my timing cover still see's my sprocket, and I run a proper Gen 4 sprocket.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-20-2012, 03:14 PM   #7
MikeOD
Drives: 2010 M6 2SS
OP, my cam in my car is 226/234 .600/.600 114+4...so very very similar. Obviously the lobe profiles must be different as you're going to have a little more lift with the added degree of duration.
Anyways, my car idles at 775 RPM very nicely, and drives really smoothly in the 1000-1200 RPM areas. I do have a minor surge at 1500-1600 RPM under extremely light load (kinda a pain in the ass when going 30-35 mph) but I'm still working on the tune, and I think I will for the most part be able to mellow that out.
The car hasn't been back to the dyno yet, and I'm still being cautious with my rev limiter set to 6900...the car pulls right up to the limiter HARD, so I think I'll be shifting a little north of that.
Old 03-20-2012, 04:40 PM   #8
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Same Cam here... but for an A6 with a stall.
Same characteristics obviously, but my surging is around 15-20 mph at very, very light loads when I roll out of my neighborhood trying to manage volume.
Good rattle/roll at idle.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim.
Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C.
1100 7/02 Ordered
3800 8/09 Order produced
4200 8/13 Shipped
6000 8/24 HOME!
brantley847 is offline   Reply With Quote
Old 03-20-2012, 04:41 PM   #9
Bo White
Bo White's Avatar
Yeah, was thinking on having my tuner set the limiter at 7000rpm since I figured it would pull all the way to it. Ive hit my stock limiter a couple of times with the stock cam lol.
Old 03-20-2012, 06:02 PM   #10
MikeOD
Drives: 2010 M6 2SS
I did the same...if I only drove it by feel with the stock cam, I drove it into the rev limiter, especially in third...I guess my reflexes just knew how fast to shift to second and third, but in 3rd and 4th gear, when you can actually begin to feel the power curve, the stock cam pulls right to the stock limiter.
I'm only worried about the bottom end dealing with the RPM a little bit. I've seen way way way less rod bolt problems on the newest Gen 4 engines as compared to the old original Gen 3 engines...my valvetrain should be stable at 7100-7200 RPM, I'm just so happy to be driving the car again, since it sat for almost 4 months this winter.
...I have a set of Katech rod bolts for it...but I don't really want to pull the engine out to change them...and you can't get the oil pan out with the engine in the car.
Old 03-21-2012, 09:00 AM   #11
CGT
Drives: 2011 SSm6
I agree, I haven't seen an aftermarket 3 bolt cam core that didnt have the cam sensor reluctor on it. If there's no sensor back there to read it, it makes no difference.
CGT is offline   Reply With Quote
Old 03-21-2012, 09:18 AM   #12
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
My cam is in that range too. It's a eps 226/234 lsa 113. With the eps tune, it's perfect. Plenty of sound and power and drives like stock...very pleased.
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 03-21-2012, 10:26 AM   #13
Larz29
Larz29's Avatar
Drives: 2010 camaro ss LS3 cyber grey
I think I'm going with the tsp 225 230 cam. Sounds like a good overall daily driver, and I'll probably get another 100 hp with it.
Larz29 is offline   Reply With Quote
Old 03-21-2012, 12:39 PM   #14
Bo White
Bo White's Avatar
100hp off the cam and what else?
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
427 LS3 cam? briancb1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-13-2011 12:01 PM
Katech Torquer LS3 cam test results Katech Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 11-08-2010 05:42 PM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 03:11 PM
