sjm autoprod
Old 03-19-2012, 06:23 PM   #1
Cypher106
Drives: 2SS/RS
What do i HAVE to replace when i buy a new Cam?
Well as the title says, im thinking about buying a MTI stage 3 Cam for my 2012 SS and am not completely sure on what i HAVE to replace in order to not break internal parts from the new cam. please help.
Cypher106 is offline   Reply With Quote
Old 03-19-2012, 06:28 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
send email or call MTI. they should know what you need.
Old 03-19-2012, 06:36 PM   #3
cmb74656
cmb74656's Avatar
Drives: 2011 Camaro 2SS/RS CGM/BLI A6
Depends on how radical the cam is. Lifters can be re-used on a mild cam. Valve springs would have to be replaced with a radical cam. Just remember: You must remove the heads before removing the lifters on LS series engines.
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back.
FUTURE: long tube headers, front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings.
WISH LIST: Edelbrock E-Force SC, LS3 conversion
cmb74656 is offline   Reply With Quote
Old 03-19-2012, 08:21 PM   #4
Harleyfatboy
Harleyfatboy's Avatar
Drives: 2010 lt1 rs 2009 Harley fat boy
Do not put the old lifters on an new cam. It will wear out the new cam.
Harleyfatboy is offline   Reply With Quote
Old 03-19-2012, 08:31 PM   #5
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
Disregard this^^^ when it comes to modern engines. Roller lifters do not set wear patterns.
Ucantctchme is offline   Reply With Quote
Old 03-19-2012, 08:37 PM   #6
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
To be safe I would Replace the Springs & Lifters and Push rods just because you are more then likely getting a more aggressive Cam then what is currently in the car (otherwise it would be pointless)
The "HAVE" to's... Depends if you are Manual or Automatic.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-19-2012, 09:15 PM   #7
Blu808
Blu808's Avatar
Drives: Hankook Formula Drift Camaro
Send a message via AIM to Blu808 Send a message via Yahoo to Blu808
Hi,
When you upgrade your cam, we recommend you upgrade the following parts as well:
Camshaft
Comp 921 Dual Valve Springs
Hardened Pushrods
Titanium Retainers
Seats
Seals
Heavy Duty Timing Chain
We can offer you a cam package and give you a nice discounts on all these parts. Feel free to PM or call us for more details!
Blu808 is offline   Reply With Quote
Old 03-19-2012, 10:28 PM   #8
Jason 98 TA
Drives: Camaro
You won't change lifters when you swap camshafts. The cam, good
Pushrods, and a quality spring kit like the prc double spring kit. You will also need a gasket kit.
Jason 98 TA is offline   Reply With Quote
Old 03-19-2012, 10:33 PM   #9
Ject
aka Patrick
Ject's Avatar
I hate to disagree with yeah Jason but if he has an automatic car... I would like to think the lifters are a "need" to replace ... at least the 8 that are AFM.
If he has mentioned if he has an A6 or M6 I've missed it.
Old 03-19-2012, 11:24 PM   #10
mikeSS
mikeSS's Avatar
Drives: 2015 c7
whats with all this talk of lifters... pretty simple. l99 change them ls3 no need.
Old 03-20-2012, 01:13 AM   #11
2010abmss
2010abmss's Avatar
Drives: 2010 ABM SS
Vengeance takes it a step further and replaces the oil pump with a melling high volume pump and the comp trunion rocker upgrade
Sold 2010 ABM 2SS RS. Kooks, Corsa CB
2010abmss is offline   Reply With Quote
Old 03-20-2012, 06:38 PM   #12
Cypher106
Drives: 2SS/RS
I have a l99 engine. if i could find a package for all of it that would be awesome, exspecially at a decent price.
Old 03-20-2012, 07:08 PM   #13
Blu808
Blu808's Avatar
PM or call us, we can set you up with a package deal for a cam and LS3 conversion.
Old 03-23-2012, 12:18 AM   #14
mth35115
Drives: 2010 Camaro rs/ss inferno orange
With the auto, MTI recommends the Stage 2 cam, unless you want to change the torque converter. I run the stage2 cam with AHR longtube headers, good power and great sound. Added a Magnson Supercharger with the same combo more power than most will ever use.
HOT ROD SS
MTH35115
mth35115 is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Replace oil pump or shim during cam install? Lee123 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 03-03-2012 10:38 AM
JANNETTY RACING INJEN COLD AIR INTAKE GROUP BUY JANNETTYRACING V8 Bolt-Ons & Tunes 163 01-03-2011 08:50 AM
VVT Cam Specials! yyz28 Engine Internals 17 10-19-2010 12:29 AM
Why you can't buy a new car directly from the manufacturer scotchsride09 Off-topic Discussions 13 02-14-2009 06:15 PM
