Erik@Torq
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 04-12-2012, 09:38 AM   #26
The 2010 Sin
CorkTulsa.com
The 2010 Sin's Avatar
Drives: 2010 2SS BLK, 2013 2SS CRT
I have these too and they're a gorgeous awesome product.
The 2010 Sin is offline   Reply With Quote
Old 04-16-2012, 12:04 PM   #27
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
How are these holding up?
Trying to figure out if these require a voltage regulator like what AAC installs on theirs.
Old 04-16-2012, 09:23 PM   #28
BilJ
BilJ's Avatar
Drives: 2012 2SS/RS
I've been wondering the same thing....anyone know?
BilJ is offline   Reply With Quote
Old 04-17-2012, 01:15 AM   #29
Klepton
Klepton's Avatar
Drives: 2011 2SS/RS, LS3, SW w/ IOM package
Originally Posted by jsherm007 View Post
I bought a set of P13W lights to replace mine, not from OP vendor, and they work great but won't 'snap' into lighting socket. Wondering if this is normal for aftermarket bulbs? I'm waiting to hit a bump and have the clip come off!
If you are referring to the connection to the housing, you can double up on the o-rings by installing the stock bulbs' o-rings over these LEDs as was suggested to me; it will definitely tighten the connection.
However, if you are referring to the connection between the bulb and the socket, then from what I've read it seems to be a common problem with P13W LEDs regardless of the manufacturer/vendor.
As far as I know, these do not have a built-in voltage regulator. I used them with a plug-n-play harness I purchased from a member.
As I had mentioned previously, you have 3 options when using LEDs for your DRLs. With these specific bulbs, however, you will have to go with options 2) or 3).
Otherwise, you can go with option 1) and purchase AAC's bulbs...which are twice as expensive and might be a bit bluer. I'm not sure who, if anyone, else sells them with a built-in voltage regulator.
Klepton is offline   Reply With Quote
Old 04-17-2012, 01:20 AM   #30
xVengeancex28
xVengeancex28's Avatar
Drives: 2010 IOM 2SS/RS
looks alot better!
xVengeancex28 is offline   Reply With Quote
Old 04-17-2012, 04:05 AM   #31
Ph4r
Top Down Fun
Ph4r's Avatar
Drives: 11 2SS/RS IOM Vert
I haven't had any weird problems yet, no flashing, no dimness or uneven light, and I haven't blown out a bulb yet either.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2012 Chevrolet Cruze 1LT/RS - SIM, Manual 6Speed also! Thanks to BeckyD!
Ph4r is offline   Reply With Quote
Old 04-17-2012, 08:54 AM   #32
BilJ
BilJ's Avatar
Drives: 2012 2SS/RS
Thanks Klepton and Ph4r.
Old 04-17-2012, 09:29 AM   #33
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Yea I'm planning on using 2SSRS's harness. I'm just wanting to know how they are holding up seeing as it's been almost a month since this thread was made and I've read about the led versions burning out after only a couple weeks because of the PWM without a voltage regulator.
These two things are exactly why I don't want to buy them from AAC. Their plasmas appear to be in the 6k range while V-Leds have a 5k set. And I don't appreciate the $50 price hike for adding something that appears to be simple.
Old 04-20-2012, 08:25 PM   #34
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
I have used v-leds for the rest of the LED's on my car... good stuff!
I am honestly not convinced that the PWM will damage LED's besides AAC's... PWM is a normal way to control LED's... search it on Google. The only reason I can think of besides bad LED's and assembly, is if the PWM signal that the car is using is too noisy or too fast/too slow for the AAC LEDs...
Toasty is offline   Reply With Quote
Old 04-21-2012, 09:58 AM   #35
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Originally Posted by Ph4r View Post
It's not so much of a harness as just a piece of wire I soldered to a diode and then attached to two wires. I used the idea of the AAC "Harness" $10 wire they offer, but I added a $1.50 diode into the wiring so that the Front Side Markers aren't turned on during the day (without the rears). This makes the DRL's Always ON, and if I want the Halo's on, I turn the knob one spot to Parking and then I have Halo's, DRL's, All Side Markers, and Afterburner effect on my Technostalgia LED Tails all on. One more click to headlamps and it turns on the HID's with everything else on also. This also enables me to have the DRL's on still with the High Beams too!
DRL (Blue) -> Diode -> Front Side Marker + Wire
Put the Bar or Line side of the Diode to the DRL Wire.
Please post the Diode specs you used. I have the LEDs installed and I want to wire up for the same effect you have. Thanks.
One-Bad-ZL1 is offline   Reply With Quote
Old 04-21-2012, 10:33 PM   #36
CUPRA
CUPRA's Avatar
Drives: 2011 2SS/RS - IOM/CGM Stripes
I had the same issue with mine. I wondered if they would unclip as well... but so far I haven't had any issues with them. I even filed down the housings a little to try and get them to fit a little better. Guess I did it just enough!
2011 - 2SS/RS - IOM/CGM Stripes • CUPRA • Ordered: 4/10/2010 Mine: 7/1/2010 - 426BHP+CAI
CUPRA is offline   Reply With Quote
Old 04-22-2012, 06:33 AM   #37
Ph4r
Top Down Fun
Ph4r's Avatar
1N4001 I had them at work, but here is a Radio Shack Link for a pair (just what you need)!
You aren't the first to ask this, so I'll add it to Post #1 Also ::
My Build Thread
Old 04-22-2012, 10:11 AM   #38
atma
dildo
atma's Avatar
Drives: 2012 2SS/RS LS3
I've had 'em for over a month now and they continue to work just fine
atma is offline   Reply With Quote
Old 04-22-2012, 12:17 PM   #39
RocTrux
RocTrux's Avatar
Drives: Summit White 2011 2SS/RS
I don't know about these but I got my DRL's from these guys half the price of AAC's they sell plasma and LED's and the LED's do have a built in "smart drive" so they call it. I'v had them on for a few months with no problems I did have to send one pack right after I got them tho but they replaced it with no problem they fit tight but don't snap all the way in like most others. I do have the V-led switchbacks for my turn signals/running lights and they work great.
http://autolumination.com/headlights.htm
RocTrux is offline   Reply With Quote
Old 04-22-2012, 06:01 PM   #40
SilvrRS
SilvrRS's Avatar
Drives: 2010 Camaro 2LT RS
Mine as well don't fit that secure into the DRL Housing. When you guys say double up the o rings, where exactly do you put the 2nd one? Anybody have a pic of this??
SilvrRS is offline   Reply With Quote
Old 04-22-2012, 08:37 PM   #41
Klepton
Klepton's Avatar
I don't have a pic of it, but you simply roll the stock o-ring (which is bigger) on top of the v-leds one. It fits snugly over it.
Old 04-26-2012, 03:12 PM   #42
Bills96TA
Drives: 2 Camaro's, 1 T/A, 1 Ferd
I hate to ask this but after reading everything I am still a little unclear. What part number do I order and do they plug right in IE, unplug my stock DRL and these plug in the same connection. I have a 2011 2SS btw, my wife hates the yellow DRL compared to the HID headlights.
12 F150 FX4 EB
11 2SS
96 TA - 12 years of "stuff"
95 Z28 LS1 conversion
Bills96TA is offline   Reply With Quote
Old 04-26-2012, 03:19 PM   #43
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If your car is an RS, you need the P13w.
If it is not an RS, you need the 5202.
And yes they just plug in.
Old 04-26-2012, 03:49 PM   #44
Bills96TA
Cool thanks, I think all 2011 2SS's are RS's.....I think.
12 F150 FX4 EB
11 2SS
Old 04-26-2012, 04:10 PM   #45
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Here ya go check the pics on this thread.
http://www.camaro5.com/forums/showth...=214660&page=3
FASTER than my SS....for now
2500HD (with a couple parts)
Originally Posted by Coyotekiller View Post
I wonder if this could be why my car idles like its retarded...
GaBoy25 is offline   Reply With Quote
Old 04-26-2012, 04:10 PM   #46
vroomapunk
Crystal Red Tintcoat FTW
vroomapunk's Avatar
Drives: 2012 CRT 2SS/RS Beige interior
Nope, u can get a 2ss, non rs
Old 04-29-2012, 03:07 PM   #47
GaBoy25
GaBoy25's Avatar
Thanks to the people or person who showed how to trim the tabs so the bulbs click in and the suggestion of doubling up the orings of the old stockers and this worked great as well. Thanks guys install went great and better yet they look awesome! Better than I had imagined. For the money....awesome mod.
Mod link pics for orings and tab trimming on my previous post. Hoping that it helps someone else as it did me.
Old 04-30-2012, 10:40 PM   #48
markgws6
markgws6's Avatar
Drives: 2011 Camaro 1LT/RS
RocTrux. Can you show us photos of your LED DRLs in comparison to the halos/HIDs?
I'd like to see how much of the blue like the others have. I have the AACs plasmas and have been thinking of getting different ones because they are a little too blue and and I don't care to be a cop magnet.
markgws6 is offline   Reply With Quote
Old 05-03-2012, 01:19 PM   #49
Ph4r
Top Down Fun
Ph4r's Avatar
I hear from a little birdie that they have a few of these in stock and that existing orders are shipping out... by a few, I mean very few - early birds need only apply.
My Build Thread
Old 05-03-2012, 03:28 PM   #50
Bills96TA
Hmm, didn't know that, how do you tell the difference?
12 F150 FX4 EB
11 2SS
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 402 05-02-2013 08:11 PM
My AAC Plasma P13W LED DRL Bulbs with Harness Installed Peace234 Cosmetics and Lighting Modification Discussions 33 08-12-2011 01:06 PM
AAC Plasma DRL's installed mekc57 Cosmetics and Lighting Modification Discussions 27 03-31-2011 11:02 AM
Installed AAC Oracle cool white xenon DRLs & new black bowtie topgun1 Camaro Photos | Spyshots | Video | Media Gallery 8 04-04-2010 01:04 AM
FYI - Rally Stripes Will Be Factory Installed talwell Camaro Price | Ordering | Tracking | Dealers Discussions 13 08-28-2009 09:35 AM
