Thread Tools |
Catch me if you can
Fuel injectors, worth upgrading?
Hey guys, I've been seeing that a lot of guys that upgrade their LS3/L99 Supercharged cars they take the supplied injectors and replace them with quality high end versions.
So I was wondering if replacing the injectors on the ZL-1 would either increase (slightly) HP or is it just a better and more efficiant way of providing fuel to the engine?
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
IIRC - LSA enjoys a similar dual-mode (so-to-speak) fuel system, similar to LS9 because the obvious fuel requirements of the SC. We know they're upgraded above LS3-specs', but something that seems new to 'V LSAs, is it seems, perhaps, the injectors may have been changed.
In a current article in GMHTP, ADM was adding their Stage I 'V-upgrade (along with the customer's air cleaner upgrades) and in the final tuning, Andy noted that he was expecting the injectors to reach their repsective limits, as I suppose they have on earlier V' mods', but this brand new 2012 V' didn't seem to approach the current car's limits. The car ended up around 590 RWHP, and it seems like Andy, perhaps, though there may be unannouced '12 changes for LSA, and at least in the Caddy', it seems there's a chance that either they had a ringer for this article, or LSA-V's might be making a little more power (perhaps because ZL1 changes might carry over to V', somewhat). Anyways - unless you are seriously increasing fuel requirements (i.e. adding a top-end kit or more boost), adding fuel may not necessarily be worth the expense, especially if you don't intend on any of the above. I guess we're just going to have to wait :(
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
![]() ![]() ![]() ![]() ![]() Drives: 2010 LPE 650+ CTS-V Join Date: Oct 2008
On the V's with an Upper Pulley and CAI the stock injectors were about maxed out. Most people who have modded their cars with both pulleys changed are swapping injectors. I had headers, CAI and a tune and my stock injectors were hitting close to 100% Duty Cycle. I am not sure if the stock injectors in the ZL1 are same or not.
I am going with the ID850 injectors as they should be good for almost anything I want to do and good for E85 also. I believe we are seeing the stock pumps good up to 650-700rwhp - past that you can run a Boost-a-pump. |
Petro-sexual
Thanks, Speed'
![]() I just wanted to be clear that I was only commenting on the '12 that ADM tested for GTHMP. From the article, Andy reflected exactly what Speed74SS said about the injectors max'ing out. The '12 didn't, which surprised Andy, so maybe ZL1 and CTS-V are sharing more components than GM's announced. The more the better
#5 | |
![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
#6 | |
| Thread Tools | |
| JDP Motorsports' 2010+ Camaro SS Fuel Line Retrofit DIY | JDP Tech | Camaro DIY & HOW-TO instructions & discussions | 14 | 06-16-2013 08:30 PM |
| Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-17-2012 11:24 PM |
| Do you really know SIDI?(spark ignition direct injection) | bmorecam | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 26 | 01-31-2012 06:18 PM |
| Check engine light on | Boricua | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 08-28-2010 01:12 AM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
