Old 03-20-2012, 11:34 AM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Doing my Kooks LT install... any words of advice before I get started?
I doing my Kooks LT's and high flow cat install this weekend. For those of you that have been through this... anyone have some words of advice? I will be doing this in my garage with the help of my bro.
Thanks
newagemuscle is offline   Reply With Quote
Old 03-20-2012, 11:37 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Whenever you think you have the car jacked up high enough - raise it another click on the jackstands. The rear header bolt on the driver's side is a PIA. If you have a swivel socket or like a 1/4" drive it makes it a lot easier.
Click to view my build thread
Old 03-20-2012, 12:06 PM   #3
Cpanthers85
Drives: 2011 Camaro 2SS RS
if your headers have the dual bungs for the O2 sensor and the wide band, make sure if you are not running the wide band, that the O2 sensor goes in the front one, not the rear one. You will know it fit because the O2 sensor will have more than a fingers width clearance. My headers came backwards and it was a PITA to fix it once I had the headers all bolted up.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 03-20-2012, 12:19 PM   #4
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Make sure your local dealer has at least one 02 sensor in stock,there is a good chance one will get fubar when removing them. Put a small amount of anti seize on the 02 threads when re installing.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 03-20-2012, 12:33 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
I took a sharpie and put a little arrow next to where the dip stick went in. When I intially looked at it I said..."easy, right in front of the starter"....but because everyone mentioned what a PITA it was to find after it was out I decided to put a mark anyway. That saved my butt! Even with the mark you'll still have a little issue with getting back in properly but at least you'll know where it goes. This is a must IMO. Put a mark next to where it goes!
I know this sounds stupid but no one ever mentioned that the dip stick is bolted to the block right around the spark plugs. I assumed it was underneath and took me a little to figure out it was unbolted from up top...not underneath.
Other than the dip stick, the only other real issue I had was getting the steering knuckle back on to the gear box. Trick is to make sure to spread apart the clamp that connects it to the gearbox. I had to hold the steering knuckle up against the side of the car while someone else used a screwdriver and hammer to try to bend the clamp out a little. Goes back on pretty easy once you do that. That was on a set of ARH headers though. You may not have to take the knuckle off for KOOKS. That cost me a good 30-45 min to deal with. If you can get the driver's side in with the steering in tack you'll save some time but don't beat up your headers trying to force it up there. That ceramic coating is beatuy and you don't want to scratch it up. Take off the knuckle if needed.
If you can warm the car up, then get it up on stands or a lift, immedially break loose the O2 sensors. The extra heat in the exhaust should help get them loose.
When you put the rear O2 sensors back in, go a head and un-plug them. Otherwise the wires get all twisted up. The plugs have a safety latch type thing. Slight pain to get off. I think I just cut them and didn't put the safety thing back on. It's a little piece of plastic so easy enough to cut.
Make sure to use Anti-seeze on your bolts and O2 sensor threads when putting them back in. Also, I took the header bolts and touched them up on the the wire wheel of my bench grinder. Just takes the top layer of junk off so they'll go in easier.
Edit: post up if you have to take the steering knuckle off or not. I didn't put my KOOKS on because I got a package deal to install with purchase. If you don't have to take the knuckle off that would definatley give KOOKS a slight advantage over ARH for those trying to decide on which one to buy.
Build Journal
Old 03-20-2012, 01:31 PM   #6
wbdinger
wbdinger's Avatar
Drives: NSMNJW=2010 CGM 2SS/RS LS3
#1 disconnect the negative battery cable on the battery as to not short out the exhaust on the starter post !
DYI Oil Catch Can, DYI dash ABL, DyI fender "V"emblems, ACC Plasma DRL, DYI Painted red SS on steering wheel, DYI CGM painted bowties on wheels, DYI Clearcoated Brake Calipers, Eibach pro 1" lowering springs, GM Heratige grill, GM skipshift eliminator, GMPP 92206992 Exhaust, 2-10" Kenwood subs w/350watt pioneer amp, RiderGraphics hood spears/gill outlines, 9x20 wheels-custom silver,weather tech mats, ARH 17/8 headers and cats. Tuned by Davenport Motorsports.
wbdinger is offline   Reply With Quote
Old 03-20-2012, 01:50 PM   #7
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2012 Silverado LTZ
Use OEM header gaskets, not Kooks gaskets.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome Torq-Thrust wheels. 546/rwhp & 522/rwtq Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 03-20-2012, 01:54 PM   #8
Cpanthers85
+1
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
MY BUILD THREAD
Old 03-20-2012, 02:46 PM   #9
mpyle007
mpyle007's Avatar
Drives: 2011 Camaro 2SS L99
ditto. Buy two extra o2 sensors. If you don't need them take them back. Disconnect the battery cable and be careful not to hit the headers on your spark plugs if you dont fully remove them. Install is easy though. Buy a tirque wrench if you dont have one to torque the bolts down to factory specs. I didnt put my o2 sensors back in because they were bypassed.
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop
TSP Long tube headers w/ high flow cats and full x-pipe
GMPP axle back exhaust system
Custom Dyno tune by ARD (Advanced Racing Dynamics)
BMR 1.4" Springs all four corners
"There is no replacement for displacement"
mpyle007 is offline   Reply With Quote
Old 03-20-2012, 02:50 PM   #10
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
+2
Also, when taking out the factory O2 sensors, if they get tight coming out, then turn them back in and go back and forth until they are out. 97 times out of a hundred you can get them out this way without needing to replace them. Then as has been mentioned, use anti-sieze when you reinstall them.
Also use anti-sieze on the header bolts. Many people use lock-tite, but you can screw up the threads if you take them out and in again. There is still some factory lock-tite inside the threads in the head, adding more will just make it more difficult and could cause problems down the road.
We always use GM exhaust gaskets and Kooks bolts with anti-sieze.
Feel free to call, email, or PM us anytime!
- Jeremy
JDP Tech is offline   Reply With Quote
Old 03-20-2012, 03:28 PM   #11
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I managed to get the one O2 sensor off that was stubborn by using wd40 and an open ended wrench. I got it to move a bit, sprayed with wd40, wiggled it and kept going. Eventually worked its way out. Had to clean up the threads quite a bit, but it worked.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-20-2012, 03:45 PM   #12
MikeOD
Drives: 2010 M6 2SS
Other than disconnecting the steering shaft from the rack (which is easy), in order to slide the header in, and then putting it back when I was done, I found the Kooks longtube install to be very very smooth sailing on my car. No problems or issues at all, everything fits great.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-20-2012, 08:15 PM   #13
newagemuscle
Philippians 4:13
Just picked the OEM ones on the way home from work.
Old 03-20-2012, 09:09 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I found this article reallllllly helpful when I did my brothers lt's
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
The Elimination Game: Camaro colors Ant Cosmetics and Lighting Modification Discussions 2739 04-10-2014 10:37 AM
Kooks Long Tube Headers and Exhaust Install & Dyno - 411 RWHP - Phastek Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-09-2012 07:07 PM
LT install and JRE tune tylerSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 12-30-2011 12:05 PM
What Else is needed to Install OBX LT Headers? oso305 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 19 12-16-2011 07:26 PM
