sjm autoprod
Old 03-20-2012, 07:01 PM   #1
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
HELP...Power Steering sudden loss =(
So I was driving today and lost my power steering suddenly while going down the Verrazano Bridge over here in NY...almost ate the wall but steered clear, pulled over and shut her off. Checked under the hood, all levels were okay.
Only strange thing, there was a little bit of white stuff polka dotting the engine bay, looked like paint overspray but brushed right off.
I restarted the car to see what was up, power steering worked fine. I drove it to get it off the shoulder of the highway, everything was perfectly fine...
So confused...
Any help would be wonderful as to what happened?
Sean
YOUNGnRECKLESS is offline   Reply With Quote
Old 03-20-2012, 08:04 PM   #2
YOUNGnRECKLESS
Building the Beast
Drives: 2010 VR LS3
no ideas? =(
Old 03-20-2012, 08:12 PM   #3
Drakin
Drakin's Avatar
Drives: 2011 IOM 2SS RS
Possibly an intermittent rack problem...or maybe the shaft broke on the pump...I've seen gm trucks do that..easy way to check is take the serp belt off and see if you can pull the power steering pump pulley out...
You would think if it was the power steering shaft broken it would have no power steering..
Anyway there’s a couple ideas.
Drakin is offline   Reply With Quote
Old 03-20-2012, 08:15 PM   #4
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Pressure relief valve in the pump stuck open.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-20-2012, 08:39 PM   #5
YOUNGnRECKLESS
Building the Beast
Drives: 2010 VR LS3
thanks guys...just makes me wonder since the second I restarted the car it worked flawlessly again.
But I think it was power steering because it became super hard to turn the wheel. checked it at a dead stop and I basically needed to pull it with all my weight to turn it...
at first kinda seemed like the steering just locked...weird feeling
Old 03-20-2012, 09:01 PM   #6
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
Take it in to the dealer, there is a bulletin for a pump problem.
Old 03-20-2012, 09:53 PM   #7
jmaynard
Drives: 2012 Camaro SS2
+1 or an air bubble.
jmaynard is offline   Reply With Quote
Old 03-20-2012, 11:44 PM   #8
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I don't think you ever lost power steering. You won't notice a loss of power steering if you are driving down a road going at a normal/decent speed. It will be noticeable going at slow speeds though. My guess is a piece of debris got stuck in the steering rack area and prevented you from making turns. When you stopped, the debris fell out.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 03-21-2012, 02:23 PM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
YOUNG, I would have to suggest you get this checked out by your dealer. Hopefully they can ease your mind in regards to this issue for you. Let us know how things go for you.
Jeff Morris, Chevrolet Customer Service
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Power steering cooler leak? Macrackie 5th Gen Camaro SS LS LT General Discussions 0 04-09-2011 11:34 PM
Wow. Lost power steering sexystreetmachine Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 12-12-2010 05:27 PM
