Old 03-20-2012, 08:18 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Forged Internals Ls3
Im looking to Forge out my engine/bore it out to get it ready to handle my twin turbo setup. Any brand in particular youd recommend?
Nighthawk89 is offline   Reply With Quote
Old 03-20-2012, 09:46 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Brand of what, internals, or twin turbos....im assuming internals. I wouldnt necessarily bore it out but hone out the cylinders a bit to 4.07" and add a 4.00" stroker crank. Shoot for about 416 - 418 cubes. Callies Compstar crank and callies h-beam/I beam rods and Wiseco or Diamond forged pistons. Think about coating the pistons with ceramic tops for a little extra strength. This will be a start What boost are you looking at and what is your final HP goal?
ARP hardware and ACL coated bearing etc. etc. etc
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-21-2012, 03:41 PM   #3
EFI
EFI's Avatar
Drives: something faster than you
Don't bother boring it out, you need all the sleeve thickness you can get. Also don't bother with a stroker crank, you don't need that for a turbo car. Keep the stock crank unless you plan on putting down more than 7-800hp.
Put your money towards the pistons and rods (callies, diamond, wiseco, eagle, scat) all make good products and on other misc parts like head studs, fueling etc.
EFI is offline   Reply With Quote
Old 03-21-2012, 03:51 PM   #4
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
For twin turbos, I'd sell that motor complete. Then send an engine builder like Nelson or Pro Line and pile of cash and your first born.
That's not going to be a DIY project. For massive TT power you want a pro engine builder that specializes in TT LS motors.
Just my opinion.
New LS3 416cu Forged Motor SlowLS3 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 27 02-15-2012 11:13 PM
Forged Internals Alaskan_SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-11-2011 05:14 PM
Brand New Lingenfelter Built Forged Piston LS3 ADM PERFORMANCE V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 07-06-2011 06:48 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
