Old 03-20-2012, 09:24 PM   #1
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Pfadt Springs Popping Out
Hello all! I have been having a problem since day one I had my springs installed. Everytime I raise my car on the lift or jack it up to work on it my springs pop out of the little pad they sit in. Anyone know how I can resolve this?
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 03-20-2012, 09:36 PM   #2
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Hmm do they make any noise when driving? What brand are they?
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is offline   Reply With Quote
Old 03-20-2012, 09:39 PM   #3
V6owner
V6owner's Avatar
If I do not pop them back in then yes they hit the end link, but if I pop them back they are fine until I lift the car up which they pop out again.. They are Pfadt
Old 03-20-2012, 10:22 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
IMHO, your springs don't have enough pre-load. The upper strut nut is supposed to be torqued to 52ft/lbs.
This hard to measure because you have to hold the center of the strut with a Torx wrench to keep it from turning with the nut- making it impossible to use a torque wrench, and you have to have the new spring compressed enough for the nut to be adequately seated.
I think you need to remove your struts and tighten down the 24mm upper strut nut to hold your springs in place when the car is lifted.
Old 03-20-2012, 10:52 PM   #5
HaubSS
HaubSS's Avatar
Drives: '11 IBM 2SS/RS LS3/M6
+1
This was my first guess as well.
2011 IBM 2SS/RS - LS3/M6 - Grey Interior
Full bolt-ons + TSP 229/236, 112 LSA
Tuned by BROOKS PERFORMANCE
BMR Stage 3 suspension
MRR 288 - 20x10(+35), 20x11(+43)
HaubSS is offline   Reply With Quote
Old 03-21-2012, 12:11 AM   #6
V6owner
V6owner's Avatar
Hmmm. Alright thanks man
Old 03-21-2012, 02:22 AM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
That's not what's wrong.
There have been a lot of threads like this about PFADT springs. The springs have too short of an uninstalled height.
SUX2BU is offline   Reply With Quote
Old 03-21-2012, 07:07 AM   #8
garcmol
garcmol's Avatar
And.... the V6 struts are a little bit longer/taller than the SS struts. However, SS struts will bolt right on.
Old 03-21-2012, 07:52 AM   #9
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 03-21-2012, 12:13 PM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
There have been a few SS guys with the same problem.
Old 03-21-2012, 12:37 PM   #11
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
There are a couple undocumented differences between the V8 and V6 shocks, one of which is the V6 droop length is longer than the V8 is. The change was rolled in sometime in the 2010 model year, so some V6 shocks will work fine, but some do not. When on a lift the weight of the wheel can fully extend the shock and allow the spring to come unseated from the top mount. As soon as this came to light we discontinued sales of drop springs to V6 users until we were able to revise a V6 specific spring package which is just about ready to go. In the mean time you've got a couple options here:
1. Be careful when you put the car in the air that the spring gets properly seated in the upper mounts. During normal operation you shouldn't see a situation where the shock is at full droop.
2. Move from the V6 rear shocks and pick up a set of V8 rear shocks. The ride quality is going to be extremely similar between the two shocks, but the V8 will have a shorter droop length to keep the spring captured between the upper and lower mounts.
Let me know if you have any questions! You can email me directly to jarrett@pfadtracing.com or give one of our techs a call at 1-888-972-2464.
Old 03-21-2012, 01:58 PM   #12
bhall82
Drives: 2011 SS/RS
Personally from what i've seen and heard sounds like a spring load issue with Pfadt. They make great products for a vette but the camaro is a little diffrent animal. Just IMO though.
Good luck op
bhall82 is offline   Reply With Quote
Old 03-21-2012, 03:38 PM   #13
BDH
Drives: 2012 1LT-RS
Hi Jeff...what about V6 convertibles? What are your thoughts please. Thanks.
BDH is offline   Reply With Quote
Old 03-21-2012, 03:51 PM   #14
PfadtRacing
We are really close to having a V6 specific spring kit that will work for both the coupes and convertibles. If you wanted to get parts immediately you could also move to the V8 shocks and run the springs we currently offer, but given that we are extremely close to having the V6 specific springs ready to go you may want to hold off.
Pfadt Stage 2 Performance Handling Package Is Now $600 Shipped At APEX Motorsports!! Apex Motorsports Suspension / Chassis / Brakes 167 08-09-2012 06:05 PM
Pfadt-ening things up Phase 2: Drop Springs robertway Suspension / Brakes / Chassis 34 05-02-2010 09:56 AM
Pfadt GROUP BUY! Springs / Sways / Mounts IPS Brandon Suspension / Chassis / Brakes 18 11-23-2009 03:46 PM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 06:41 PM
