Old 03-21-2012, 07:31 AM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
How much will gears help 0-60 time?
Not that it is bad now, but I'm just wondering what kind of 0-60 time I can expect to pull by going from stock 3.27 gears to 3.70? (see sig for mods)
E.T. is offline   Reply With Quote
Old 03-21-2012, 07:45 AM   #2
2011 SS
2011 SS's Avatar
Drives: 2011 SS M6, LT's, CAI, SLP LM II's.
Significantly, although you have to be able to put that to the ground, your acceleration is going to be totally different it will be like driving a different car. You need trailering arms toe rods and drag radials to put that down, dont forget though when you start getting traction things start breaking. Now onto what you want to know, guessing by your mods that probably puts you in the 385 rwhp or so if you can drive I can see you putting down a 3.8-4.3, sixty time.
2011 SS is offline   Reply With Quote
Old 03-21-2012, 08:02 AM   #3
SixGracing
SixGracing's Avatar
Drives: 2010 2SS/RS LS3 A6
A 3.8 to 4.3 60' time? Serious? Is he driving a bus or a Camaro? Seems like an incredibly slow 60' time. A 2.0' is barely acceptable for a camaro. At least I thought.
SixGracing is offline   Reply With Quote
Old 03-21-2012, 08:04 AM   #4
IROCanSS
Drives: 89 IROC 350
No way hes 385 rwhp... hes A6 (obvious by the 3.27 rear gear) with intake, catback exhaust and a scanner tune, so with his mods, hes 330-350 rwhp MAX.
He won't come close to 385 without headers, hiflow cats and a real tune... not taking anything away from Ted's tunes, just 385 from an A6 is damn good so it takes a lot to get there!
Furthermore, you dont usually need to worry about breakage on the A6 cars, much less drivetrain stress than on the M6.
OP: I had (HAD) 4.10 gears... it was BLISS untill they exploded. Gears are GREAT on these cars but VERY expensive. Have you priced them yet?
Old 03-21-2012, 08:08 AM   #5
MikeOD
Drives: 2010 M6 2SS
He means 0-60 mph, not 60 feet.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 03-21-2012, 08:16 AM   #6
scottywheels
Drives: 2010 A6 SS/RS
What kinds of gains have you auto guys seen in the gear swap at the track.? I have gone 1.60 60 ft already with the stock 3.27 gears
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built
scottywheels is offline   Reply With Quote
Old 03-21-2012, 08:17 AM   #7
SixGracing
SixGracing's Avatar
That makes more sense.
Old 03-21-2012, 08:19 AM   #8
SixGracing
SixGracing's Avatar
That's a tricky question. I think you start running into tire and suspension issues when you start moving up in gears. If you change gearing, you are more than likely going to have to spend money on suspension mods to make the car hook. You might get worse times from the spinning.
Old 03-21-2012, 08:39 AM   #9
2011 SS
2011 SS's Avatar
Sorry, I have an M6 so I'm always used to giving advice about what I think my car would be like if I had done said mods, I no clue Autos had 3.27 gears, I'm sorry.
Old 03-21-2012, 08:41 AM   #10
2011 SS
2011 SS's Avatar
I meant 0-60 times, and you drive an automatic that may be why you think a 2.0 is barely acceptable, I can't get less than a 2.6 without DR's, but this is my FIRST manual car.
Old 03-21-2012, 09:04 AM   #11
E.T.
E.T.'s Avatar
Yep, I was asking about 0-60, not 60'.
Haven't dyno'd so I can say what I'm putting to the wheels. I know gears aren't going to add any actual HP, but from what I've read, it will make the car feel a lot stronger, and that's what I'm concerned with. It's nice that these care will do 170+, but I'd rather have that seat of the pants feeling when driving around town and staying within legal limits.
I saw that the 3.70s run about 6 or 7 hundred online, but I have a gear/trans shop right around the corner from me and they are working in getting me a quote. I think they said labor would run about 80 bucks an hour.
Old 03-21-2012, 09:19 AM   #12
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
I saw no gains in my sixty (not 0-60, but it's a good indicator) when I went from 3.27 to 3.45. But I'm sure a bigger gear like 3.73 or 3.91 or 4.10 would make a difference. Personally, I think 3.73's (or 3.70, whichever) are a good all around gear for a bolt-on automatic.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 03-21-2012, 09:26 AM   #13
scottywheels
I dont care about spining, I have a pure slick on the car and suspension.
SOLD
Old 03-22-2012, 03:56 PM   #14
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I've only been to the track once-- before my suspension mods and got a 2.2 60' on all-season tires and 4.10 gears on the first try. Did you ease into the throttle or were you spinning your tires?... Anyway, gears made a night and day difference in the get up and go factor for me--still my favorite mod, to date!
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
Look what they dropped off at my work for me! Miraclewhip Camaro Photos | Spyshots | Video | Media Gallery 49 09-09-2011 06:35 PM
Camaro Fest 2 Who's GOING????? comm17 California Meets and Events 271 04-14-2011 03:45 PM
Pre-Camaro5 FEST...FREE TUNING & DYNO TIME!! Qwkss V8 Bolt-Ons & Tunes 2 01-28-2010 12:54 AM
