HeadlightArmor
Old 03-21-2012, 11:52 AM   #1
yessitsfast
yessitsfast's Avatar
Drives: 2010 camaro
header help
just want to say hi to the family here at c5 and ask for some help/tips on my header install. I have been struggling with this install for about 2 days now, the problem is that the back two bolts on the headers(driver side) got really really hard to turn and are about halfway in. I got scared and stopped turning them so i went to the pass side and started with the middle bolts and they are doing the same. Btw how are you guys working around all the crap on the pass side? I got the stock manifolds out no problem
yessitsfast is offline   Reply With Quote
Old 03-21-2012, 12:02 PM   #2
yessitsfast
Drives: 2010 camaro
PIMP IN DISTRESS
Old 03-21-2012, 12:07 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Try using some WD-40 on the bolts. Might help. Also, for the rear driver's side bolt. I used a 1/4" drive with a short extension to get it out. You might also have luck trying with a swivel socket
Click to view my build thread
Old 03-21-2012, 12:32 PM   #4
yessitsfast
Drives: 2010 camaro
ok wd 40. i got them out no problem its going in with new headers that is a pita. every bolt but the last two spin easily and freely in i just dont want to force them. i talked to a few people and they say maybe the holes on the flange are off a tadd or i cross threaded them by letting the headers hang on the nuts while tightening
Old 03-21-2012, 12:40 PM   #5
J-ROD-210
J-ROD-210's Avatar
Drives: 2010 Camaro SS/RS RJT A6
best to go with two people for install. I had my 13yr.old son help me with the passenger side cause he has smaller hands to get in there. The driver side was a breeze.You might not be aligning the headers right or not supporting them properly.Use a floor jack to hold them up,put all the bolts in with blue loctite then torque them starting from the middle out and alternating from front to back. On the passenger side,I held up the headers with my hands(for better adjusting)while my son put in the bolts
J-ROD-210 is offline   Reply With Quote
Old 03-21-2012, 12:44 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Take one of the bolts out and inspect it. Make sure it doesn't look like you have already cross threaded them.
If all looks good take the bolt and touch them up with a wire wheel on a bench grinder to get and gunk off. Then put some anti-seeze on them before going back in. Other that that you my have to take the header back off and run a tap back up in there to clean out any threads you might have bugered up.
BTW: which brand of headers are you installing?
Build Journal
Old 03-21-2012, 12:47 PM   #7
yessitsfast
Drives: 2010 camaro
m.b.s headers and plenty of jackstands. my helper bailed after two hours im 2 days in now. i looked at the bolts and i can see the treads some of them not as sharp but they dont look stripped to me
Old 03-21-2012, 12:55 PM   #8
yessitsfast
Drives: 2010 camaro
just hope i dont gotta get a tap and re thread them.
Old 03-21-2012, 01:00 PM   #9
J-ROD-210
J-ROD-210's Avatar
Oh,when i took the bolts off I cleaned them real good with wire brush. Hmmmm,I used the barbeque pit wire brush It worked just fine
Old 03-21-2012, 01:02 PM   #10
yessitsfast
Drives: 2010 camaro
thanx man this is kicking my butt so the bolts should screw almost all the way in by hand right?
Old 03-21-2012, 01:10 PM   #11
J-ROD-210
J-ROD-210's Avatar
Dont know where u at but if your close. I wouldnt mind going over and giving u a hand. Off from work today and just chillin
Old 03-21-2012, 01:19 PM   #12
Synner
Drives: not stock
Are you reusing the stock bolts and if so did you remove the thread lock on it? I put antiseize on new stainless bolts because the stock ones fought me the whole time coming out and the threads looked like crap.
Old 03-21-2012, 01:21 PM   #13
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
What I did was put the pita ones in first and they threaded in easy with a short well socket and a flex adapter...I would take the bolts out and blow the hooles out with compressed air, their might be a little crud in there.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 03-21-2012, 01:42 PM   #14
yessitsfast
Drives: 2010 camaro
sorry took so long to reply the fight continues! yes they are stock bolts the ones that came with the headers are cheap looking and feeling so i reused stock gaskets and bolts. another member recommended scrubbing the bolts clean i will try that and maybe some pb blast
Kooks stepped headers vs ARH ...?? Nito Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 01-08-2014 05:57 PM
Here we go. Stepped headers or uniform size? Raptor626 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 10-27-2011 01:22 PM
Texas Speed 304 Stainless Header Kits Pics & Info! Jason 98 TA V8 Bolt-Ons & Tunes 109 07-18-2011 04:33 PM
AR Header Sale!!! Ragin Racin V8 Bolt-Ons & Tunes 15 06-27-2011 05:11 PM
Ceramic coating ? GreyLS3SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 11-20-2010 06:36 PM
